ski2liv Samba Member
Joined: July 25, 2003 Posts: 122 Location: Philly, PA
Posted: Mon Nov 03, 2003 12:02 pm Post subject: rear brake work newbie questions |
I plan to overhaul the rear brakes.. have a bad cylinder in one so I'm doing em both.
Do I need any special tools? i.e. rear axle nut 46mm tool? Spring pliers for springs?
I am going to replace the springs, hoses and shoes as well since I'm in there. When I do the brake lines.. do I need the special bending tool? I plan to use the metal hose set and do all the brake lines at once (front and back). Are the hoses as simple as unscrewing the old and screwing in the new?
Are there any other parts I should be ordering other than the cylinders, hose kit, spring kit, and shoes?
thanks much!! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19670 Location: Land of Whine and Phonies
Posted: Mon Nov 03, 2003 12:11 pm Post subject: |
I didn't need a bender when I replaced the hard lines on my bus. I would recommend you change the rubber lines as well if it hasn't been done in a while.
I used the old lines as templates for the new lines. Just be real careful and take your tim so as to not kink the line. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Mon Nov 03, 2003 12:13 pm Post subject: |
You will need a socket or the 46mm tool. Spring pliers are a luxury. A tube bender would help alot. You shouldn't need any other special tools. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
69 woodstock vet Samba Member
Posted: Mon Nov 03, 2003 2:17 pm Post subject: |
I just finished the rear end on my '69 and the best thing is all the parts are rather cheap and you don't really need any special tools. However, be ready for a day of dirty knuckle busting work. Make sure there are no small children around to here the words you will scream. I agree with replacing the rubber brake hoses too, they seem to go bad sooner than the metal lines. _________________ Eat dessert first. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Mon Nov 03, 2003 2:56 pm Post subject: |
If you have the later style drums you don't need a 46mm tool to remove them.
Brake hoses are a simply screw fit. To undo the union you'll need 11mm wrenches. At least one 11mm and a crescent wrench.
You may want to replace the spring clips that hold the hoses in place...
Get some anti-seize to put in the barrels of the adjusters so you can turn them easily in future.
The special pliers help but unless you are a clutz you don't need them. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
