TimberwolfZ28 Samba Member
Joined: May 17, 2005 Posts: 197 Location: Battle Creek, MI
Posted: Sun Mar 26, 2006 6:01 pm Post subject: Steering stabilizer on a r&p front end? |
Think there's much need for steering stabilizer on a rack and pinion front end? I have a center load rack unit, and got to wondering if, when I mount this thing, should I fab up some stabilizer mounts and put one on there? |
Nicksan Samba Member
Posted: Sun Mar 26, 2006 6:23 pm Post subject: |
No, its no use in the dirt for several reasons. Toss it out. |
Posted: Sun Mar 26, 2006 6:39 pm Post subject: |
Nicksan wrote: |
takotruckin SUPER Baja
Joined: August 14, 2005 Posts: 2378 Location: stuck in fresno, ca
Posted: Sun Mar 26, 2006 7:03 pm Post subject: |
i would run one. i think jowlz found a pro comp one that should work, check through his thread. _________________ Member of the baja's that don't run club, for now!! |
Posted: Sun Mar 26, 2006 7:52 pm Post subject: |
TimberwolfZ28 wrote: |
Nicksan wrote: |
Do you mean a steering damper? |
Posted: Sun Mar 26, 2006 7:55 pm Post subject: |
Nicksan wrote: |
Nicksan wrote: |
stabilizer/damper, call it what you will
I checked out Jowlz thead and the part number he mentions... now I am looking for a good picture of one. |
dr. awsome Samba Member
Posted: Sun Mar 26, 2006 9:29 pm Post subject: |
I might just be ignorant but why exactly do you want to pull the stabilizer off? _________________ is it time to get out of the dirt and switch to the street? |
Posted: Sun Mar 26, 2006 9:33 pm Post subject: |
dr. awsome wrote: |
I might just be ignorant but why exactly do you want to pull the stabilizer off? |
um, I don't. I'm building a sandrail, using a center load rack and pinion and my question was whether I should add one or not...if it was needed.
Last edited by TimberwolfZ28 on Sun Mar 26, 2006 9:38 pm; edited 1 time in total |
Posted: Sun Mar 26, 2006 9:36 pm Post subject: |
I understand that. I was just stealing the thread and asking why you don't want one with a stock VW box. Sorry for being a jerk with the hyjack _________________ is it time to get out of the dirt and switch to the street? |
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2985 Location: altus, oklahoma
Posted: Mon Mar 27, 2006 6:05 am Post subject: |
try the popeye the sailor method, eat a can of spinach before your drive.... _________________ blank |
jps1145 Samba Member
Joined: March 16, 2005 Posts: 654 Location: Tehachapi, CA
Posted: Mon Mar 27, 2006 7:19 am Post subject: |
The trouble with a R/P center mount or end mount is there is no place really to bolt a damper to. You'll need to custom fab some sort of bracket that clamps to a tie rod or is welded to the rack itself. I think, after using my newly equiped Baja, a damper is a MUST! Especially if you don't have power steering. I haven't really seen anyone fab something for an after market R/P yet. I'm sure it has been done. _________________ Tehachapi, CA
'69 Baja
Vintage Funco single seater
My Baja |
Posted: Mon Mar 27, 2006 5:30 pm Post subject: |
Another thing is that I would hate to put a clamp on my nice, new, shiny aluminum tie rods.......
But will probably have to, I have considered this and it doesnt look to hard to do. |
ThingOw181 Samba Member
Posted: Mon Mar 27, 2006 6:05 pm Post subject: steering dampener |
I would definitely run a dampener. I have the "inexpensive" center load HD rack on my Thing, and with the quickness of the rack you get a ton of feedback through the wheel. Note that in adding the R&P and linkpin front end everything was set so there is only 1/8" toe change at full droop and none at full compression. (so minimal bumpsteer)
I picked up a Bilstein dampener from a motorhome off ebay for $15. I will try and find the part number, but it is a pin end on one side and an eyelet on the other. A clamp-on mount for the eyelet side is available through prowlers (SACO I believe) that was another $20. On the pin side, I welded a tab to my pan head and used the rubber bushings from a pin top shock. It made a giant difference in feel up until I flipped the car. I will be keeping the stabilizer now that it's being fixed.
Hope that helps.
Jordan |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Mon Mar 27, 2006 7:07 pm Post subject: |
if there is no ear on your rack to mount a damper, you could always clamp it to the tie rod using u-bolts and create a mount on the beam for the other side _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
SHMO Samba Member
Joined: July 29, 2004 Posts: 1647 Location: Lynden, Washington
Posted: Mon Mar 27, 2006 8:01 pm Post subject: |
If there is ANY steering arrangement that can benefit from a stabilizer, its a rack and pinion. Like ThingOw181 said, they transmit a ton of steering feedback. On the down side, they will make the wheel even more difficult to turn. I think most of you with fast ratio R&P's know what I am getting at. Actually a combination of that spinach and a stabilizer might be best...lol
SHMO _________________ SHMO's Baja |
Posted: Sun Apr 02, 2006 3:29 pm Post subject: |
close to same topic, what dampner should i use with a stock box? one of the street ones, or is there some off road version? _________________ Member of the baja's that don't run club, for now!! |
takotruckin wrote: |
close to same topic, what dampner should i use with a stock box? one of the street ones, or is there some off road version? |
as far as i know, there's only one. but that's not to say you couldnt adapt a stronger one to suit your purpose _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
SHMO Samba Member
Posted: Sun Apr 02, 2006 3:38 pm Post subject: |
Just keep in mind, a stronger one will make the steering effort a little harder.
