OvalDude54 Samba Member
Joined: July 15, 2005 Posts: 215 Location: SoCal- San Diego area (high rent)
Posted: Wed Apr 26, 2006 6:09 pm Post subject: HELP! She'll start warm/hot but not cold! Drains da battery! |
Ok,
I recently bought a 61 single cab. She's a real sweet thing, just havin' troubles starting her (sounds like my old wife) LOL when she's cold.
She starts ok when warm/hot or after being started or running. I know she needs a full tune up (points/plugs/cap/rotor/wires/carb work) but what can I do to at least get 'er goin'? She drains the battery getting started cold!
It's a stock 40HP with stock electric choke, 30PICT and 009.
Where do I start with the least amount of funds and time. I'd really like to drive 'er!
Thanks!!!!!! |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed Apr 26, 2006 6:10 pm Post subject: |
A tune up _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
MedicTed Samba Member
Joined: August 12, 2005 Posts: 2110 Location: King of Prussia, PA
Posted: Wed Apr 26, 2006 6:17 pm Post subject: |
Is the choke working at all, or is it just stuck open? _________________ Ted Wojton
70 VW Bus Westfalia camper
2003 GMC Sierra |
Posted: Wed Apr 26, 2006 6:26 pm Post subject: |
SplitPile
MedicTed!
Thanks! I'll check it out.
Mark |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Wed Apr 26, 2006 7:33 pm Post subject: |
Clean the spark plug tips with a pocket knife, gap them to about .026", and don't strip them putting them back in. File or emory cloth the points and reset them and blow out all the dust. Chip the corrosion off the rotor with a pocket knife and wash them, Pull the wires and push them back in a few times. Change the oil. |
Posted: Wed Apr 26, 2006 7:43 pm Post subject: |
Most excellent Barry Lynn! Thank you!!!!!!!!! Thank you!!!!!!!!
Mark
56 Oval
61 single cab
Manx Buggy
66 K code Mustang
V8 Tundra
New Jeep
old Volvo |
chazwood Samba Member
Joined: February 11, 2006 Posts: 678 Location: The last word in edgewise
Posted: Wed Apr 26, 2006 7:54 pm Post subject: |
I think your accelerator pump diaphragm has a hole in it so it does not shoot that all important squirt to fire things up when you pump the gas. They get stiff and crack if the vehicle sat for very long...pretty cheap and easy to fix. |
Posted: Wed Apr 26, 2006 8:44 pm Post subject: |
Very detailed and simly most simply excellent info Chazwood!
Great thought!
lol Really like your saying.......''the Earth is air cooled''. Gotta love 'em old VWs! It turns heads and gets more compliments than any other car I've ever owned. And, it's so inexpensive and a blast to drive!
I'll replace the carb. diaphram. It does sound like the problem, doesn't it. The previous owner said it was fine.........but it did sit for awhile.
Thanks again Chazwood!
Mark |
Posted: Wed Apr 26, 2006 8:45 pm Post subject: |
THANKS TO ALL YOU COOL VW DUDES OUT THERE!!!!! Much appreciated! |
camperfan Samba Member
Posted: Wed Apr 26, 2006 8:50 pm Post subject: |
It sounds like your carb setting is too LEAN. A warm/hot motor will run on a leaner mixture than a cold motor will. So if your carb diaphragm or small orifices are plugged/varnished up it will be hard to start cold. choke plate will play a role as well . |
Posted: Wed Apr 26, 2006 8:56 pm Post subject: |
LEAN? Is that too much air? I'll make the adjustment.
THANKS!
Mark |
