VW1948 Samba Member
Posted: Fri May 05, 2006 2:27 pm Post subject: Which gearbox for 1962 squareback? |
Hi,
I have a squareback from 1962 that has a broken gearbox . Can I use any type 3 gearboxes? Are there different ratios in the gearboxes for different years?
Thanks! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
60DoubleTurd Type 3 Contributor
Posted: Fri May 05, 2006 10:48 pm Post subject: |
Can we see some pics of this 62 squareback and get a VIN from you?? If you dont want to post the VIN here can you email it to me or PM me with it. I like to keep track of how many real 62 squares are out there. Thanks in advance! _________________ Frank
66 L87 Variant Pigalle
SBS #17 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat May 06, 2006 8:00 am Post subject: |
EverettB wrote: |
Any Type 3 swing axle gearbox, 1962-68. |
'67 and '68 would be 12volt systems and would require a change to 12V for the car including the flywheel. Or an adapter bushing to run the 6V starter in a 12V bellhousing. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Sat May 06, 2006 11:13 am Post subject: |
Up to what VIN was the special "stamped" gearbox that I have heard about? _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
Posted: Sat May 06, 2006 7:41 pm Post subject: |
VIN VIN VIN VIN VIN VIN VIN VIN VIN VIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! _________________ Frank
SBS #17 |
Posted: Sat May 06, 2006 8:14 pm Post subject: |
62type3square wrote: |
VIN VIN VIN VIN VIN VIN VIN VIN VIN VIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
0119975
http://www.type3registry.com/reg_detail.php?regid=10221
That is the number that was on the tag in the tire well.
It came off that chassis that I showed in the other post. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
VW1948 Samba Member
Posted: Sun May 07, 2006 10:12 am Post subject: |
Can we see some pics of this 62 squareback and get a VIN from you?? If you dont want to post the VIN here can you email it to me or PM me with it. I like to keep track of how many real 62 squares are out there. Thanks in advance! |
Sorry for late reply, I have been out of town for the weekend. I will get you the vin this week.
The gearbox broke in the 70's and the car was sitting in a garage until late 90's. When the car was left in the garden it was not to rusty... I will check how much rust there are now . As you can see from the picture it needs urgently to washed...[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=273990[/img] |
VW1948 Samba Member
Posted: Sun May 07, 2006 10:18 am Post subject: |
hoss wrote: |
Up to what VIN was the special "stamped" gearbox that I have heard about? |
What is a special "stamped" gearbox?
Best regards
Tarek |
VW1948 Samba Member
Posted: Sun May 07, 2006 10:27 am Post subject: |
Thank you to all for your help.
Does all gearboxes have the same ratio? Which gearbox number had the earlist 12volt gearboxes?
Tarek |
Posted: Sun May 07, 2006 10:29 am Post subject: |
VW1948 wrote: |
The gearbox broke in the 70's and the car was sitting in a garage until late 90's. When the car was left in the garden it was not to rusty... I will check how much rust there are now . As you can see from the picture it needs urgently to washed... |
That should fix it. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sun May 07, 2006 10:36 am Post subject: |
VW1948 wrote: |
hoss wrote: |
Best regards
Tarek |
The "stamped" gear boxes had stamped metal shock attachments on the axle tubes, and very short plates where the backing plates were welded on. As in this picture.
The later ones had the whole outer end as one forged piece. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sun May 07, 2006 10:42 am Post subject: |
VW1948 wrote: |
Tarek |
T-3 and T-1's have different ratios. So stay away from T-1 gear boxes, if you can.
T-1's had a 4.375 final ratio and T-3's had a 4.13. This means that if you put a T-1 differential into your T-3, you will be turning a couple hundred RPM's more to get the same ground speed. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
VW1948 Samba Member
Posted: Sun May 07, 2006 11:38 am Post subject: |
EverettB wrote: |
This appears to be a 64 or later model.
Type 3 VIN #s |
Which pieces are incorrect if the vin is saying 62?
I know that the car is registred as a 1962-01-01 in the dmv, I will get the VIN tomorow and we will find out. |
Posted: Sun May 07, 2006 11:58 am Post subject: |
Yeah, but it has a 1500 emblem on it. With the VIN that Russ gave makes it a 63. _________________ Frank
SBS #17 |
Posted: Sun May 07, 2006 12:00 pm Post subject: |
Sorry Russ. I wanted the VIN for the square we are talking about. I got the one for the 34. _________________ Frank
SBS #17 |
Posted: Sun May 07, 2006 12:01 pm Post subject: |
I also just noticed that there are no holes or bumper bolts visible which makes it earlier. Maybe someone in the 70s liked the chrome look and tried to hop it up!! _________________ Frank
SBS #17 |
