TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Fri Jun 30, 2006 3:48 pm Post subject: westy interior from a bay window? |
hi guys, i was wondering what years of bay window westy interior fit a 67 kombi. i was looking for some bay seats to throw in while i was wondering the boneyards. i found the cleanest and most virgin westfalia camper kit imaginable in a junk bus. it was a 76 poptop walk thru. here's the best i could describe it. foldout rear seat with bed cushion, storage unit attatched to roof, closet that sits on driver side, short ice box with two containers, sink with plastic tank and shelves that sit behind driver seat. nothing in this kit sits behind the passenger seat. the rear seat is covered in plaid cloth material and appears to be 3/4 size. there is a westfalia tag attached to rear seat. i'm going to go pull the whole thing as a set tomorrow if you guys say it will work. i don't mind modifying anything since i was going to make my own camper interior anyway.
thanks |
60freak Samba Member
Joined: October 08, 2002 Posts: 861 Location: Indiana
Posted: Fri Jun 30, 2006 4:40 pm Post subject: |
It will all fit, except the passenger side cabinet needs to be notched up at the top. When you set-up the cabinet, you'll see where the notch needs to be. Good luck. |
Posted: Fri Jun 30, 2006 4:48 pm Post subject: |
thanks 60freak. i have seen a smooth vinyl westy kit from a 70 in a 67 before, with pass side cabinet and the notch cut that you are referring to. this one is driver side though. it looks the same as earlier westys, but has black trim instead of white and cloth instead of vinyl. this closet sits above where the spare tire sits in my 67 walk thru kombi. |
Posted: Fri Jun 30, 2006 5:09 pm Post subject: |
i forgot, i just remembered that the westy id tag says " campmobile 70 |
