Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Mon Jul 03, 2006 8:38 am Post subject: Thermostat ? |
What are the differences between the thermostats for the different type of motors? I'm talking about the thermostats themselves, not the mounts and such. The reason I ask is that I have a thermostat that doesn't appear to be bad (it expands and contracts), but it is too big to fit into the mounting bracket.
Thanks. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
Vayabroder Samba Member
Joined: April 04, 2006 Posts: 989 Location: Hollywood, FL
Posted: Mon Jul 03, 2006 8:56 am Post subject: Thermos |
They vary in design according to the model and type of engine. Just make sure you're getting the right one for your motor and it'll fit perfectly on the bracket. |
FASTERFRED Samba Member
Joined: January 01, 2005 Posts: 294 Location: PARACHUTE, COLORADO TERRITORY
Posted: Tue Jul 04, 2006 10:15 am Post subject: |
STEVE22....When you say too big do you mean diameter or length?...If too big around/diameter then I don't know what's up....If you mean length, then it has been heated up/expanded outside/not mounted in a bracket....This will expand it to the point that it will not return to the orginal compressed state...If your going to test one in hot water/heat, AWAYS mount it in the bracket before heating....The sections of a good stat should lay together touching each other, minus any grit that might be between the folded sections....Even if it still expands/contracts in the over expanded state, it is still shot, as have never found a way to get it back to the orhinal compressed condition.... ....The Best....The Lizard.... _________________ 64 Sedan, 67 Sedan, 68 Hot Rod Bug, 71 Ghia Coupe, 1600 Roller Crank, 1776 110 Cam, 2161 Work in Progress, 9 roller parts Bugs, and a Ton of Parts!.... Got a Lizard?....I have 9 Insectivors!.... |
Posted: Wed Jul 05, 2006 5:26 am Post subject: |
This tstat is too tall to fit into the bracket and still have room to expand. I'll try to post a pic this weekend. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
