boboskips Samba Member
Joined: November 06, 2005 Posts: 74 Location: San Clemente, CA
Posted: Sat Aug 05, 2006 9:09 am Post subject: Oil Cooler Tightening Torque Question |
After putting my tin back on and looking at my oil cooler from above (also reading the article about the oil cooler blow-out) I'm a bit concerned that I did not secure mine well enough.
Should the oil cooler be flush w/ the case? As you can see in the picture, the gaskets are visible through the crack between the case/cooler. Now I followed the Bently (5 ft lbs) spec using my torque wrench, howerver my wrench is pretty inaccurate at low ftlbs (it's really only accurate above 10).
Any suggesestion would be appreciated. Thanks
_________________ Bobo
'73 Transporter
Stock 1700cc engine
"Miles from nowhere
I Guess I'll take my time" |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Sat Aug 05, 2006 9:13 am Post subject: |
They're designed to be a cushion between the case and the cooler.
That's why only 5ft lbs. The seals would crush with any more. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Sat Aug 05, 2006 9:15 am Post subject: |
Awesome... Thanks shark~ _________________ Bobo
'73 Transporter
Stock 1700cc engine
"Miles from nowhere
SlowLane Samba Member
Joined: July 11, 2005 Posts: 1044 Location: Livermore, CA
Posted: Sat Aug 05, 2006 10:39 am Post subject: |
What Shark said, and consider acquiring an inch-pound torque wrench for those low-torque fasteners (such as the sump plate nut: 9 ft-lb max. If over-tightened, will crack the cam bearing web in the crankcase). _________________ Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett |
