Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Mon Aug 07, 2006 3:28 pm Post subject: Wiper switch |
My wiper switch only moves to one position: slow. Shouldn't there be two speeds? I will need to remove the switch and clean/repair it. Any recommendations before I start? |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Mon Aug 07, 2006 5:55 pm Post subject: |
Yes, two speeds. Remove the wiper moter too, and clean all it's contacts. Years of old grease build up with dirt, and make for poor connections, as well as dragging on the moving parts.
Talk with Kubalman on this; he's involved in some repairing of wiper motors and such. |
kubelmann Samba Member
Posted: Tue Aug 08, 2006 6:30 am Post subject: |
The two speed function is most often faulty as a result of problems with the brushes or their connections. Most of the time the switch either works or is worn out. If you only have one speed chances are you need parts to repair the trouble. Does your motor park? |
Posted: Tue Aug 08, 2006 7:41 am Post subject: |
The motor parks just fine. The switch itself only moves to one position (currently on or off). This makes me think the switch is faulty. |
74 Thing Samba Member
Posted: Tue Aug 08, 2006 9:15 am Post subject: |
Excuse my ignorance, what exactly are the "contacts" in the wiper motor-the male spade part that the wires attach to? |
bucko Samba Member
Posted: Tue Aug 08, 2006 1:21 pm Post subject: |
First things first....
If the switch on your steering column moves to one positon (on) and a second postion (off) Something is wrong.... A stock (good) wiper switch has off, low and high (three postions) It also pulls to the rear to open the air valve that allows wiper fluid to spray on the windshield.
I suspect you are correct in your diagnosis of a questionable switch.
Second things second....
The contacts are part of the auto-park system. They cause the motor to stop (in conjunction wiht a number of other parts, so that when the switch is turned off the wiper blade assembly continues to travel until the wiper blades reach the bottom of the windshield. |
Posted: Tue Aug 08, 2006 8:30 pm Post subject: |
It turned out that mud dobbers had made a home inside the switch some time ago. After picking out the dirt and re-lubing the moving parts, it works just fine.
Unfortunately, something broke inside the turn signal switch and blows a fuse everytime I turn right or turn on the hazard lights. I couldn't see where to open the switch up to investigate the problem, so I ordered a new one from the Thing Shop. I needed a new one anyway since the canceling mechanism was broken. |
Posted: Wed Aug 09, 2006 10:38 am Post subject: |
I am glad you found the wiper switch to be repairable. I also had a faulty turn signal switch that caused all kinds of electrical troubles and blown fuses. I hope you paid fair price from the Thing shop as this is a part that is also common to other T-1 VWs and is not a Thing only part... the Thing shop sells them for $60 and I can get them for $36 for a German made part... |
Posted: Wed Aug 09, 2006 1:10 pm Post subject: |
Not that it matters, since I already ordered the switch from the Thing Shop, but what vendors would you suggest for Bug parts?
Also, it there a listing anywhere of interchangable parts? I'd like to stop paying more then I need to...
Thanks |
Posted: Wed Aug 09, 2006 9:00 pm Post subject: |
The RoMTOC Thing Data CD includes the Thing part crossover guide. I thought you owned this one.. If not $12.50 to paypal via [email protected]
gets you the CD shipped asap....
My favorite T1 and T2 parts resource ~~ OE German
Currently: OE VeeDub has a huge sale going on.
www.oeveedub.com
This company sell the highest quality German OE VW parts for
T-1 and T-2 (No T-3 or T-4) |
