themansfield Samba Member
Posted: Sat Dec 06, 2003 3:56 pm Post subject: New Engine break-in! |
I'm about to install my new engine in my 71 bus, but I'm unsure of the proper break-in procedure. I got a fairly detailed list from type2.com, nut my main concern is about priming the engine before I turn the key. I know that for some cars you can buy a priming rod that you put on a drill and stick down the distributor to get the oil flowing....is this necessary and /or available? Should I just bolt it in there and turn the key?? _________________ Need British parts? 800-235-6954 ext 3199!! |
aircooledjosh Samba Member
Joined: March 15, 2003 Posts: 83 Location: Mckinleyville, CA
Posted: Sat Dec 06, 2003 4:12 pm Post subject: |
Try posting this in the engine forum. They'll probably jump on it quicker...
That's a great question by the way... _________________ Don't get too close to my fantasy.
Don't be afraid to clutch the hand of your creator.
Stare into the lion's eyes, and if you taste the candy, you'll get to the suprise. |
csa000 Samba Member
Joined: December 06, 2003 Posts: 77 Location: Spanaway, Wa
Posted: Sat Dec 06, 2003 4:14 pm Post subject: |
you won't find a priming rod that will work for a vw. priming rods are for oil pumps that are run off of the distributor. What I do to prime my engines is: pull the coil wire, take the plugs out, make sure the oil sending unit wire is hooked up and then turn it over until you have oil pressure. Another further step that works is to pack vasoline into the aoil pump when you put the engine together. That causes suction and helps pick up oil quicker. Hope this helps. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Sun Dec 07, 2003 9:58 pm Post subject: |
Thanks, you guys are the best! Wish me luck, it looks like Wednesday will be the day.... _________________ Need British parts? 800-235-6954 ext 3199!! |
