Yellowbeard Samba Member
Joined: March 07, 2006 Posts: 2288 Location: At large again...
Posted: Wed Aug 30, 2006 6:55 pm Post subject: |
Plenty. VW parts suppliers sell a spring plate removal tool to make the job safe and easy. _________________
Lohe wrote: |
Thanks. Thread went from me not being able to understand what Ipis was saying because English is obviously not his first language to me not being able to understand it because English is my first language |
Fuel pumps galore:
http://www.thesamba.com/vw/classifieds/detail.php?id=845378 |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3116 Location: Keizer, OR
Posted: Wed Aug 30, 2006 6:59 pm Post subject: |
don3751 wrote: |
Plenty. VW parts suppliers sell a spring plate removal tool to make the job safe and easy. |
no need, bus spring plates are not preloaded like bug ones. there is no danger in taking them off the ledges _________________ flossin, tossin, dippin, and trippin |
firzout Samba Member
Posted: Wed Aug 30, 2006 7:00 pm Post subject: |
don... Your saying that the bus is already lowered 3.5 inches by me changing the tire size to 195/50/15s ? If so, I don't see any change? please explain..
thx _________________ Why use a car when you can take a BUS! |
rizzag Now Wut?
Posted: Wed Aug 30, 2006 7:02 pm Post subject: |
firzout wrote: |
thx |
the suspension will not lower with lower profile tires but the bus will be closer to the ground by the difference in sidewall height between the old and new tires. _________________ flossin, tossin, dippin, and trippin |
Posted: Wed Aug 30, 2006 7:03 pm Post subject: |
rizzag... I remove everthing you stated from the wheel end right? not the tranny end..?
will my tires rub the wheelwell ? _________________ Why use a car when you can take a BUS! |
Posted: Wed Aug 30, 2006 7:04 pm Post subject: |
Sorry. My bad-lowered 1.75 inches with 1.75 inches more wheelwell clearance. Which you'll need. My fronts barely clear the wheelwells. _________________
Lohe wrote: |
Fuel pumps galore:
rizzag Now Wut?
Posted: Wed Aug 30, 2006 7:05 pm Post subject: |
firzout wrote: |
will my tires rub the wheelwell ? |
yes, wheel end
they will be real close but "should" not rub _________________ flossin, tossin, dippin, and trippin |
So 195/50/15s lowers thebus closer to the ground by 3.5" ? doesn't seem that much!! I have a 66 dlx sitting next to it in the garage and it doesn't look that much of a difference. _________________ Why use a car when you can take a BUS! |
Posted: Wed Aug 30, 2006 7:08 pm Post subject: |
the front i plan to put a 4" narrowed beam with drop spindles . I should be okay there right ? _________________ Why use a car when you can take a BUS! |
Posted: Wed Aug 30, 2006 7:14 pm Post subject: |
You guys have been of great help!!! thank you soo much!!
HOW fast will I be able to cruise when it's all said n done ?? _________________ Why use a car when you can take a BUS! |
middleburgebus64 Samba Member
Joined: March 29, 2005 Posts: 303 Location: on the earth
firz if you dont want to staight axel you can flip your box's. my bus has fliped box's but one bad thing about them is you will go slower.
_________________ ladyVW:burge is cute |
Posted: Wed Aug 30, 2006 7:27 pm Post subject: |
hey middle... were you at the last winter springs vw show with this bus?? I think I saw it or one like it... the lettering seems familiar.
I don't want it that low, and I don't want to remove anything from the bus yet. Is fliping the boxes ahrd to do ?? do I need any special tool ? I really want to be able to cruise 60-65 if need be. _________________ Why use a car when you can take a BUS! |
Posted: Wed Aug 30, 2006 7:28 pm Post subject: |
pic of front wheelwell clearance
[/img] _________________
Lohe wrote: |
Fuel pumps galore:
Posted: Wed Aug 30, 2006 7:30 pm Post subject: |
Lohe wrote: |
Fuel pumps galore:
DAMM that is close. do you hit when you hit a bump or something? If I go with a narrowed beam it should take care of that problem right?? _________________ Why use a car when you can take a BUS! |
Posted: Wed Aug 30, 2006 7:32 pm Post subject: |
Don .. do you have a picture of the whole bus to see what it looks like complete ? _________________ Why use a car when you can take a BUS! |
Posted: Wed Aug 30, 2006 7:33 pm Post subject: |
Firzout, you don't need to do anything extreme to cruise 60-65. You can do that with a r/p swap in your big nut setup. Stay with the tallest tires you can get away with, as they have a noticeable effect on top end speed. _________________
Lohe wrote: |
Fuel pumps galore:
Posted: Wed Aug 30, 2006 7:34 pm Post subject: |
how costly would it be to change the r/p ? _________________ Why use a car when you can take a BUS! |
RINC Samba Member
Joined: July 22, 2005 Posts: 3877 Location: A Sunny Place For Shady People
Posted: Wed Aug 30, 2006 7:36 pm Post subject: |
middleburgebus64 wrote: |
my bus has fliped box's but one bad thing about them is you will go SLOWER.
Being that low an you dont need to go fast.
Just enjoy the blank stares as the motoring public passes you by on there way to nowhere. |
Posted: Wed Aug 30, 2006 7:41 pm Post subject: |
Lohe wrote: |
Fuel pumps galore:
