fretless Samba Member
Joined: October 07, 2002 Posts: 72 Location: Vista, Ca.
Posted: Wed Dec 10, 2003 8:41 pm Post subject: installing engine? |
I am having trouble installing my newly rebuilt engine in my 74 thing. It wouldn't go all the way in. first I had to take the vacuume advance thing off the dizzy and remove the pully belt . I got the bottom studs in the trany holes but I could only get the engine to go in about a inch. I tried turning the bottom pully to get the splines matched. still no go. after about a hour and a bad back I gave up. whats the secret to doing this?. I have installed my 68 and 65 bus engines many times, only a 15 minute job. but This sucks. |
rgrsapper65 Samba Member
Posted: Wed Dec 10, 2003 11:35 pm Post subject: |
When you installed the clutch, did you use the centering tool with splines to ensure the clutch is centered on the crank? Are you sure the tranny is the one that belongs on the Thing? That is my two cents |
Posted: Thu Dec 11, 2003 10:25 am Post subject: |
I have centering tool but it doesn't have splines. this is the same tool I have been using for my other engines.. it's the same engine that was in there before. I just had it rebuilt. and it is the correct trany.. |
rfoutch Samba Member
Joined: November 04, 2003 Posts: 102 Location: Las Vegas, NV
Posted: Thu Dec 11, 2003 10:43 am Post subject: Me too |
I to am going to vote for the clutch. It just sounds like that. I would insert the clutch alignment tool again to see if it slides in free. If it does, then that is not the issue.
If it does not, then loosen the bolts on the Pressure Plate, and re-align the disc.
RF |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Thu Dec 11, 2003 10:43 am Post subject: |
just throwing out ideas here- have you got the right pressure plate and throw out bearing installed? is the starter hung up, and interfering with the flywheel? is the engine lined up and straight? _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Thu Dec 11, 2003 7:41 pm Post subject: |
I would loosen the pressure plate and recenter the clutch. |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Fri Dec 12, 2003 12:16 am Post subject: |
I have had problems with some engines before also. Even though you have turned the crank, was the car in gear? Maybe the input shaft was turning also if there was pressure on it. Might try putting the car in gear and set the emergency brake then turn the crank before you pull it back out and reset the clutch. |
Posted: Fri Dec 12, 2003 11:25 pm Post subject: |
I haven't had much time to work on it, but I did check to see if the clutch was centered. it was. everything looks fine.. I will give it a nother go this weekend. |
Posted: Sat Dec 13, 2003 8:45 pm Post subject: |
Go it in ,,it went in like butter I used a combo of what emersonbiggins said and John Muir's book.
Thanks to all and happy holidays. |
