67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Sun Sep 24, 2006 6:49 pm Post subject: |
ive never used that product or any other additive/cleaning product. i think most if not all of these type of products are snake oil. _________________ 67 bug x3
67 ghia
64 bug |
Posted: Sun Sep 24, 2006 7:00 pm Post subject: |
67jason wrote: |
ive never used that product or any other additive/cleaning product. i think most if not all of these type of products are snake oil. |
That's why I'm asking, because I'm sketchy, too. Supposedly it has a fuel stabilizer in it, too. I used a fuel stabilizer (but not Sea Foam) in my Lotus white '67 when it went to St. Pete for the summer. I have heard of Marvel Mystery Oil and Sea Foam and have heard they actually do clean fuel line and cylinder internals. Of course, I wanted confirmation, or to debunk the myth. _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
Posted: Sun Sep 24, 2006 7:06 pm Post subject: |
67 Florida Deluxe wrote: |
67jason wrote: |
That's why I'm asking, because I'm sketchy, too. Supposedly it has a fuel stabilizer in it, too. I used a fuel stabilizer (but not Sea Foam) in my Lotus white '67 when it went to St. Pete for the summer. I have heard of Marvel Mystery Oil and Sea Foam and have heard they actually do clean fuel line and cylinder internals. Of course, I wanted confirmation, or to debunk the myth. |
nothing wrong with that...im curiose as to others experiences too. _________________ 67 bug x3
67 ghia
64 bug |
thevanillaninja Samba Member
Joined: October 10, 2004 Posts: 704 Location: Scott, IL
Posted: Sun Sep 24, 2006 7:26 pm Post subject: |
I've used Lucas Fuel Injector Cleaner with amazing results in a few different cars.
_________________ 1967 Zenith Blue Type 1 "Elaine"
Bought in 2004
Stored for 4 1/2 years and soon to be resurrected..
'67 beetle |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Sun Sep 24, 2006 8:00 pm Post subject: |
love seafoam...works great....mainly use it in my motorcycle since it sits alot...helped with the carbs when i bought it, they were a bit gummed up....it is not a miracle liquid, but does what it should.... |
Amigo-2k Samba Member
Posted: Sun Sep 24, 2006 8:16 pm Post subject: |
I use it in my daily driver (2000 Isuzu Amigo 3.2L). I dump in half a can into the oil, take it for a 20 min drive and then drain the oil. I use to have an issue with PING but since I have started this, I have not had any PING issues.
http://members.nuvox.net/~on.roz/cars/z28/seafoam.html _________________ 1958 Rag Top
http://ryanendres.com
Operations manager with a results-driven passion for process improvement |
cal63look Samba Member
Joined: January 14, 2006 Posts: 1027 Location: Colorado
Posted: Sun Sep 24, 2006 8:47 pm Post subject: |
Ok first off what type of seafoam are you talking about?? I have used seafoam several times, in my vw's, my acura integra and a honda civic.
The only type of seafoam i've seen is for pouring down the carb or putting it through a vaccum line in your intake manifold. What you do is pour it in with the engine running, you'll have to blip the pedal to keep the car from dying. Then shut the car off and let it sit for about 5 mins, then start it up and WATCH out for all the smoke, seriously its crazy how much smoke will come out!!! Its burning out the product and carbon build up in your manifolds, cylinder heads ect. Then the smoke will go away.
Ive never seen a seafoam for engine oil or as a gas additive.
Great stuff!! |
Posted: Sun Sep 24, 2006 9:06 pm Post subject: |
This is it. You can put it in the crankcase, gas tank, or in the carb (vacuum lines or directly in the barrel). If you put it in the gas tank, does it cause the exhaust to smoke a little bit, too, or just if you put it in the carb?
Posted: Sun Sep 24, 2006 9:28 pm Post subject: |
I've never ran it in the tank. But from how it is when ran direct (smoke), i would assume it would also smoke a little while driving. Plus it makes more sense to have a concentration of the product at once. |
kdfjeff Samba Member
Joined: September 06, 2006 Posts: 37 Location: Los Alamitos, CA
Posted: Sun Sep 24, 2006 9:29 pm Post subject: |
I have used both Lucas and Chevron cleaner. Seemed to "feel peppy" but our cars run better the more we drive them. Our fuel injected cars liked Chevron cleaner and new fuel filters. |
uglydog56 Samba Member
Posted: Sun Sep 24, 2006 9:57 pm Post subject: |
A lot of motorcycle people use it in the winter. I know of no detractors on the mailing list I'm on for my bike. It was discussed recently. |
Erik G Samba Member
Posted: Sun Sep 24, 2006 11:07 pm Post subject: |
it's the real deal, ask anybody that has used as the directions read. I have never heard of another product that you suck into your intake manifold. I really diddn't expect it to work so well. I read the thread on the vortex with about 200 people saying how well it worked, and figured for $7 I'll give it a try. I was also nervous about sucking it into my GTI's intake, but the results are night and day. I wish I would have known about this stuff the last 10 years. I do not know if it would work in an air cooled motor, but I imagine it would be fine since it also is for 2 and 4 stroke motors.
side note: I'd bet cheesy mechanics charge big $ and just use this stuff the night and day difference would simulate a badely needed tune up _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sun Sep 24, 2006 11:11 pm Post subject: |
What stores can you find it in? _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Erik G Samba Member
Posted: Sun Sep 24, 2006 11:29 pm Post subject: |
My car sits in the garage alot while I'm deployed so I might try it out. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
mehmann Samba Member
Joined: January 31, 2006 Posts: 61 Location: Magnolia, Texas
Posted: Mon Sep 25, 2006 5:31 am Post subject: |
When I first bought my 60 I used the Seafoam directly down the carb as I had no clue as to the condition of the carb or fuel. Did what it was supposed to due and helped a bit. At the first oil change though I used a new product that Carquest sells in there Preventative Maintenence Line. It is a two step Engine Decarbonizer product, part number PMC 85. It is meant for fuel injected engines and to be installed professionally, but you can slowly pour it down the carb. Car smoked like crazy while I did it, which was expected, but the results were night and day. On my drive home, car ran better then it ever had. Before I had problems getting over 55mph and afterwards 70 was no problem. Changed the oil and adjusted the valves the next morning and now its like a whole new car. _________________ Mike Ehmann
1960 Beetle
WGAS |
sloans265 Samba Member
Posted: Mon Sep 25, 2006 6:19 am Post subject: |
This is the stuff you want to use for cleaning.
Jectron made by Lubro Moly. Most German car owners swear by it. This stuff makes all the other products seem like water. That seafoam stuff works good but you usually see it used in marine and industrial applications. Jectron is much stronger than a lot of the others on the market and it is suggested that it be used before a scheduled oil change. That way the chemical residues don't get into the oil system and start to break it down. This should be done with any injection cleaner but most people don't realize that. Lubro MOly also carries an excellent line of deisel maintnance products. _________________ 1970 Lotus White Panel
In search of any Pensacola Fla dealership items |
