wolfej1 Samba Member
Joined: August 15, 2005 Posts: 679 Location: North Royalton, Ohio
Posted: Tue Oct 03, 2006 6:25 pm Post subject: Black plastic pipe question |
Now I am getting pretty anal I think....
The black plastic pipes in the rear of the engine that send air to the heat exchangers are hot when I checked them after a drive.
Is this OK? I would think they would be relatively cool due to moving cool air into the system.
Thanks |
Posted: Thu Oct 05, 2006 8:13 am Post subject: |
Wondering if this has anything to do with my heat not working well? |
Randy in Maine Samba Member
Posted: Thu Oct 05, 2006 8:46 am Post subject: |
See if you can remove those hoses and shove an air compressor blow gun in the front of the bus and blow out some of the crap that gets in there. |
Posted: Thu Oct 05, 2006 8:53 am Post subject: |
should those plastic pipes be getting hot though? |
Posted: Thu Oct 05, 2006 1:23 pm Post subject: |
Yes as the hot air is trying to move forward in the bus. |
Posted: Thu Oct 05, 2006 2:52 pm Post subject: |
Are you talking about the two flexible hoses that run from the electric fan down and through the tin to the heater boxes? The fan should run when you have the heat on full and the hoses should not be particuarly hot. If the fan is not running you should not have much back flow through the hoses, but I am sure there is a little so the temperature might creep up. If the electric fan is missing, the hoses are loose, or the outlet check valves on the fan don't work you will get a high rate of back flow through the hoses and little heat to the front. |
Posted: Thu Oct 05, 2006 7:02 pm Post subject: |
I am talking about the black rigid plastic tubes that are in the rear of the engine compartment and go thru the tin to the heat exchangers.
I am not clear as to what is being referred to as the electric fan
The reason I am asking is that my heat is not working. Getting cool air from the heater vents. I need to check the flapper valves and the flexible tube that moves the supposedly hot air to the front of the bus.
I got a little bit of heat while the engine was idling, but thats all.
just figured those black plastic tubes should be cool not hot....
thanks |
Posted: Thu Oct 05, 2006 7:32 pm Post subject: |
I can not picture the rigid hoses you are talking about. What year is your bus? Is it a Type 1 or Type 4 engine?
The only rigid plastic I can think of are where the hoses from the electric fan attach. If the fan is missing you will not be getting much of any heat up front as you will be pumping all your air into the engine compartment. |
scottcollins72 Samba Member
Joined: February 16, 2006 Posts: 134 Location: Coquitlam B.C. Canada
Posted: Thu Oct 05, 2006 9:55 pm Post subject: |
He is talking about the ducts that run from the alternator to the heat exchangers I believe. Those aren't what are causing your lack of heat. Underneath the van where the engine attaches to the transmission, there should be two heater valves. Most of the time they are rusted to submission and won't do anything. Can't remember who posted a diagram of how it all works but somebody did. Replace the valves and check all the hoses and duct work in the area. The fan that Wildthings is talking about is underneath the black metal cover under the rear seat. After that it's all about the gas heater under your butt controlled by the green knob that says temp +-. If you require additional help I'll post some pics tomorrow.
Cheers
Scott. |
Posted: Fri Oct 06, 2006 4:43 am Post subject: |
Quote: |
He is talking about the ducts that run from the alternator to the heat exchangers I believe |
Yes - Those are what I am referring to. I understand how the heat works with regards to the heat exchangers and the flapper valves directly connected to them. I was just wondering if there was some correlation between the fact that my heat is not currently working and the fact that those tubes are hot.
I gotta get under there and check the cables and flapper operation.
Quote: |
The fan that Wildthings is talking about is underneath the black metal cover under the rear seat. |
I was not aware of any fan under the seat. I do not have the gas heater.
Thanks! |
Posted: Fri Oct 06, 2006 9:15 am Post subject: |
Oops, I was thinking of the heating system in a bay window van instead of the one in a Vanagon, sorry for the confusion. The only air cooled Vanagon I have around doesn't run so I do not know how hot the black pipes should be, but I would guess at about the same temperature as the fan shroud. |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Fri Oct 06, 2006 9:37 am Post subject: |
"He is talking about the ducts that run from the alternator to the heat exchangers I believe"
Now I'm confused. What ducts are there that connect to the alternator? |
Posted: Fri Oct 06, 2006 9:43 am Post subject: |
If you have an aircooled you can't miss them. They are in the back of the engine compartment directly behind the fan shroud and abouve the fan and dipstick. About 2 inches in diameter or so. They feed air into the heat exchangers thru holes in the cooling tin. |
