M_atthewanderson Samba Member
Joined: January 25, 2005 Posts: 288 Location: Seattle
Posted: Sat Dec 30, 2006 10:58 pm Post subject: |
here you are erhoads, you need to type [/img] after your link not after your full comments
_________________ 1980 2.0 Sunroof Vanagon |
mordeaux Samba Member
Posted: Sun Dec 31, 2006 8:32 am Post subject: |
I think it's because you put the [/img] at the end of all of your text rather than at the end of the image location. |
airkooledchris Samba Member
Posted: Tue Jan 02, 2007 3:07 pm Post subject: |
mordeaux wrote: |
Hey now. Does anyone have these wheels on their Vanagon? I'd love for some clever dickey to create a small java app that would let us see various wheels "installed" on our vans. That would be cool.
I like these wheels also, but have yet to see them installed on a baywindow or vanagon. |
Posted: Tue Jan 02, 2007 5:27 pm Post subject: |
Man, if I ran those wheels, I would have to modify them.
Strength be damned! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Jan 02, 2007 5:44 pm Post subject: |
Looog, do you mean to say that the lugs look too minimal now or after you modified them they would be weak? I was thinking that the lugs look a little dinky compared to the mass of the spokes themselves. They do look cool though. |
Posted: Tue Jan 02, 2007 6:09 pm Post subject: |
I meant that they might be weakened by modifying them to extent depicted in my Photoshop version. I just did them to where I thought that they looked good. If you were make the area around the lugs just slightly more beefy than in my version, I don't think that strength would be an issue. The shrunken lug area makes the wheels look bigger and the spokes look longer. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Jan 02, 2007 7:23 pm Post subject: |
Snap! I didn't even notice that you had changed it. I got fixed on your version. I like them both ways. |
erhoads Samba Member
Joined: November 02, 2006 Posts: 13 Location: Creswell, Oregon
Posted: Mon Jan 08, 2007 5:15 pm Post subject: new tires on my 15 inch wheels |
I just came from the tire shop with new michelin hydro's 205/65/15 on my benz wheels and i can say that this van has never come close to handling like this and i've always run reinforced 6 ply tires on my old 14 inch rims. the difference is night and day, I still havent been able to get my photo to load....image size to large for the site, not sure what to do there. Anyway, I dont feel any flex in these non reinforced tires, they're what gowesty recommends and i agree withem. e _________________ 87 westfalia
2000 triumph speed triple |
r39o Samba Polizei
Posted: Mon Jan 08, 2007 6:15 pm Post subject: |
You need to use a tool to resize your picture. Your edit or upload software should be able to do it. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Crankey Samba Member
Posted: Tue Jan 09, 2007 9:50 pm Post subject: |
hey Loogy, still out there ?
how do you like rollin on those 18's ? is the ride a bit tough ? I'm here in Seattle and working in the industrial district, potholes and train tracks galore ! near 100% 0f my driving is off I-5 around Seattle so I'm just worried the road is too harsh.
I'm thinking 17's but I can imagine my cd player skipping constantly. I also have the harder H&R springs but they're not installed yet.
the other day I wimped out on a set of Ronal R9's on ebay @ 16x8 with an unknown ET... just don't want to get stuck with something that won't fit or look right.
I've seen a guy with Prosche rims and adapters here...any worries with adapters ?
anyone else have a report about the road feel of their van/truck with lower profile tyres ?
thanks |
Posted: Tue Jan 09, 2007 10:39 pm Post subject: |
Yep, I'm always "out there".
I really don't mind the ride with the 40 series tires 95% of the time. There are those few moments when it bothers me but they are fairly few and far between. My CD player never skips even when I'm in Fremont or down in Georgetown. I think that if I were you, I might be inclined to run a 17" wheel with a 45 series tire. The difference in ride between the two is fairly noticable. One thing that I might also recommend is to purchase a good quality wheel and keep your tire pressures up just a bit. This will prevent bent wheels.
Contrary to popular belief, H&R's can be made to ride almost like stock. You have to trim the bump stops and run really good quality shocks. Uncut bumpstops and poor quality shock are usually the main causes of the poor ride quality with the H&R springs. Worn out suspension bits can amplify a poor ride too.
I have no problem with good quality steel or 6061 T6 aluminum adapters.
Make sure you post pictures of whatever wheel you choose. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Jan 10, 2007 1:02 pm Post subject: |
=edit=
I'm pulling all these pics cause they're ebay pics and will go away soon anyway...
went ahead and got the BBS RF's
Posted: Wed Jan 10, 2007 5:12 pm Post subject: |
Well, I have always thought that a T3 would look good with a set of 16" Porsche Fuchs on it but the offset would be all screwed up. The thinnest adapters that I have ever seen are 20mm thick. This would put the offset of your front wheels at 16mm. Although the tire probably wouldn't stick out of the fenderwell, the 16mm offset would play havoc with the handling.
The AMG Monoblock wheels look great on Vanagons due to their beefy, blocky looks. Those real ones with a supposed 5" backspace seem kind of odd to me. If the sellers measurment is correct and they truly do have a 5" backspace, that would mean that they have a 12-13mm offset wich doesn't sound right to me but who knows.
If you can at all help it, buy an OE wheel. it will be much stronger and resist lip bending much better than any of the replica's. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Jan 10, 2007 6:52 pm Post subject: |
thanks for your thoughts Loog. on the OE vs copies...I suspected that too.
any idea about the BBS RF's as far as machining for the hub or lugs ? the center cap on those match up with the spider spokes so...I spose I could make a cap that would work...here's a pic w/o the cap...real 3 piece units.
16x8, no ET listed and *gulp* 800 bones ! they'd be bad ass though. I'd be down $1500 by the time I was rolling again |
Posted: Wed Jan 10, 2007 7:39 pm Post subject: |
I think those Rf's would look sweet on there. It would be best if you could get ahold of one of the wheels to take some measurments. The lug holes will have to be large enough to fit the 14mm lugs. If they are not large enough, a 9/16" drill bit will do the deed nicely. The center bore should be at least 66mm in order to clear the lip on the grease caps. Many BBS's use hubcentric rings so that a particular wheel can fit a couple of different vehicles. Mine were that way. I did not have to open the center bore up at all. If you can see the wheels in person, the offset should be on molded or stamped on the wheel somwhere. Sometimes the ET is on the rear of one of the wheel spokes, sometimes it's near one of the lug holes, on my BBS's, it's stamped near the outer lip on the face side of the wheel. Knowing the ET would be really helpful in determining the proper fitment. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Jan 10, 2007 7:51 pm Post subject: |
the BBS's are in cali, but the guy with them has an audi hot rodding shop so if I call and grill him a little more maybe I can get some better info. ($800 should be worth a little phone time) on the ET, since the rims are actually separate parts...that may not be cast into the center as it usually is.
more than I want to spend but still, I'm drawn to them tough and mechanical looking, works well w/ my truck.
HEY !, just found a post of some 17" RF's and the bore is 66.5
2-8" rims w/ ET 32... 2-8.5 rims w/ ET 20... how's that sound ?
may strike up a deal here. what's your take on these ? |
Posted: Sat Jan 13, 2007 10:19 am Post subject: mercedes 15 inch wheels. |
ok her is my final attempt at posting an image. my westy as previously described. thanks for the tips. e[/img] _________________ 87 westfalia
Posted: Sat Jan 13, 2007 10:20 am Post subject: |
and that came out ridiculously small. e _________________ 87 westfalia
Posted: Sat Jan 13, 2007 11:10 am Post subject: |
Here you go erhoads. Your van looks really nice. Do you have any specs on your wheels like what model they are off of, offset, any spacer involved, etc.?
chris32 Samba Member
Posted: Sat Jan 13, 2007 3:41 pm Post subject: |
im suprised nobody has pics of vans with audi wheels |
