bunnytrucker Samba Member
Joined: March 29, 2006 Posts: 70 Location: Ferndale WA
Posted: Tue Dec 12, 2006 4:22 pm Post subject: HID headlights |
Hello again everyone. I am converting the headlights on my panel to HID. I am wondering if any of you have done this. I am at a loss as to where to mount the ballasts. They need to be behind the interior panel in the nose somewhere but they get pretty hot so they cant be real close to anything that can burn. They also have to be within about a foot of the headlight housing. Now that I'm getting into this project I'm realizing how little room there is in the nose.... Anyway if any of you have done this or have any bright ideas please share. _________________ 61 BEETLE.
65 PANEL.
92 CORRADO VR6 |
60freak Samba Member
Joined: October 08, 2002 Posts: 861 Location: Indiana
Posted: Wed Dec 13, 2006 6:07 pm Post subject: |
I've slowly been installing the HID's in my bus and ran into the same issue, but found a solution that will work only if you have a Deluxe--I have deluxe trim on my Sundial, so I put in long machine screws to go thru the nose trim and into the inside, and then mounted "custom made" brackets to those via some nylock nuts and a couple shims/spacers to mount the ballast and keep it away from anything that could melt (wires, etc). When I get a chance I will post some pics of it in my gallery to help out with some ideas, but give me a day or two. Good Luck! |
Posted: Wed Dec 13, 2006 6:56 pm Post subject: |
That's a really good idea. I don't have deluxe trim though. I just got finished putting them in about 15 minutes ago. I ended up welding the ballast brackets to the inside of the nose and after I put the fire out they seemed to work out good. (The outside of the bus is in primer.) I'm hoping the place where I mounted them will be ok. Hard to change it now I guess. I will be posting some pics as soon as I get my digi cam back from repair. Post some pics when you get yours going. _________________ 61 BEETLE.
65 PANEL.
92 CORRADO VR6 |
gator Samba Member
Joined: August 12, 2004 Posts: 475 Location: Tookiedoo, South Carolina
Posted: Thu Dec 14, 2006 7:27 am Post subject: |
what kind of HID assemblies are you guys using? custom retrofit i assume? i would love to see the end results. _________________ "And then before the sentence was over, you threw a `fuckin' in there to emphasize your irritatedness." ~ Shanna
"And most of all, fuck you!" ~ Capt. Spaulding |
Posted: Fri Dec 15, 2006 12:45 am Post subject: |
Basically you have to convert to an H-4 bulb type housing. And then you have to get an HID conversion kit for H-4. I got mine off of Ebay. If you decide to do it yourself be sure to get the hi lo kit and not the HID/halogen hybrid. I will try to post pics of the install and final result. _________________ 61 BEETLE.
65 PANEL.
92 CORRADO VR6 |
Posted: Sun Jan 07, 2007 8:23 pm Post subject: |
So after much research and investigating I have changed the way I am doing my conversion. Basically the conversion I had planned on doing was just one of those kits that replaces the halogen bulbs with HID bulbs. Well that is a very flawed system. Halogen and HID bulbs discharge light very differently. So accordingly they need to be reflected and dispersed differently. In my ignorance I did not realize this originally. The most important part of the HID sytem (optics, ballasts, HID bulbs) is the optics. The optics magnify the light X3 and project it. They also put a very sharp cut off line on the light at about hood level so you don't blind on coming traffic. So that is the basics of HID. There is alot of info out there on retofitting HID into your ride on the net. The reason I am explaining this is for people thinking about buying a kit. Don't. You are wasting your money. Buy a OEM system from a car that came with it and make it that way.
So I will show step buy step how I am converting my 65 panel the right way. Before all you anti custom fellas out there hunt me down and make me a set of cement sneakers. I am all about keeping busses OE. This bus is a bus that came out of a junk yard and would not have never been saved. Rust around the entire lower 8" and roof. And the top half of the long side has to be replaced. So if I am going to go to all the trouble to fix this thing. It is going to be a custom.
This is the HID I am using. The e46 bmw bixenon. Bosch unit. And then hella ballasts with phillips 4300K bulbs.
And here are the stock headlights that I am using. I know that you all know what they look like. But just in case some of you dont know how they work.
Now I am starting the mock up process. The cardboard will be replaced with silver carbon fiber. I would like to do an angel eye type light around the 7" ring that held the original sealed beam. The inside of the headlight housing will be painted a flaky gun metal gray. The projector will also be surrounded by a bezel of some sort to finish it off.
I will post more pics when progress is made. _________________ 61 BEETLE.
65 PANEL.
92 CORRADO VR6 |
flatfourfan Samba Member
Joined: September 14, 2004 Posts: 187 Location: Pretoria, South Africa
Posted: Wed Jan 10, 2007 4:11 pm Post subject: |
I'm currently waiting for my carbon fiber to cure so I can cut it out with a water jet machine. So stay tuned!
65 PANEL.
92 CORRADO VR6 |
derv Samba Member
Joined: October 12, 2005 Posts: 2600 Location: Oak Park (Chicago), IL
Posted: Wed Jan 10, 2007 4:20 pm Post subject: |
I am too lazy to read the post when the text scrolls all the way to the right. _________________ Jack
Quote: |
Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth. |
DTA Samba Member
Posted: Thu Jan 11, 2007 1:20 am Post subject: |
im very interested in this as well. |
superpilot Samba Member
Joined: February 10, 2005 Posts: 117 Location: Gloucestershire
Posted: Tue Jan 23, 2007 9:54 pm Post subject: |
Made some progress today. I Painted the headlight housings and adjustment ring. The color is a semi gloss black with lots of flake in it.
I also found some Mercedes S class projector bezels that happen to fit. They will finish off the project nicely I think. I painted the outside section of them to match the housing.
And then I made an angel eye ring or halo. Looks better than I thought it would now that I have it together. I will post a tutorial on how to make them if anyone is interested.
That's all for now. I have not got around to cutting out my carbon fiber yet. But I hope to get it done this week. Stay tuned! _________________ 61 BEETLE.
65 PANEL.
92 CORRADO VR6
Last edited by bunnytrucker on Tue Jan 23, 2007 11:30 pm; edited 1 time in total |
Posted: Tue Mar 06, 2007 11:41 pm Post subject: |
Sorry for the delays as far as updates on this project. I am having problems with suppliers of some of the parts I need. I will have progress as soon as this problem is worked out. Thanks! _________________ 61 BEETLE.
65 PANEL.
92 CORRADO VR6 |
quintmann Samba Member
Posted: Thu Mar 22, 2007 6:42 pm Post subject: |
thats awesome looking!! what kinda ballasts are those? and do the controls for the bi-xenon come from the ballasts or what? |
Posted: Thu Apr 12, 2007 8:26 pm Post subject: |
The ballasts are Hella 3rd generation. As for the other question. The lights will be ran on a custom wiring harness that will relay from the original harness. I 'll post a diagram. _________________ 61 BEETLE.
65 PANEL.
92 CORRADO VR6 |
Posted: Thu Apr 12, 2007 8:36 pm Post subject: |
65 PANEL.
92 CORRADO VR6 |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Apr 12, 2007 10:40 pm Post subject: |
I have no idea what any of this means. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Thu Apr 12, 2007 11:02 pm Post subject: |
Made a little progress on the headlights. So many projects so little time.
This is pretty much the finished product. I still need to work out the details And post the rest of the project but this is what they will look like.
Cut out the carbon.
And installed....
65 PANEL.
92 CORRADO VR6 |
Posted: Thu Apr 12, 2007 11:29 pm Post subject: |
hmmm, I dunno anymore. I don't think that the carbon surround is up to par....just my 0.02c..... _________________ 1957 KCC Porsche Speedster
www.vwsport.co.za
www.aircooledvwsa.co.za/forum |
