tools... tools...
0to60in6min
0to60in6min is offline
PostPosted: Sat Mar 03, 2007 3:25 pm    Post subject: tools... tools... Reply with quote
hi all,
Could anyone please recommend me a good tool set to put in my vanagon... I have a tool box full of mismatched and redundant tools which I want to replace with something that I can bring along on a trip and also use it to do some light repair....
thanks in advance,
dan
riceye
riceye is offline
PostPosted: Sat Mar 03, 2007 6:37 pm    Post subject: Reply with quote
In my van:
In my canvas tool bag:
Multi-meter (cheap, small one from Sears).
Jump wire w/ alligator clips.
Combo wrenches - 6mm - 24mm.
Adjustable wrenches 4" and 10".
Vice grips - 6" curved jaws and 8" nut grabbing jaws.
Trusty Snap-on 6-in-1 screwdriver.
Small screw driver.
3/8" 12 point metric sockets w/ rachet, extensions and flex joint.
Spark plug socket.
Tranny fill bit (15mm?).
Metric hex keys and 3/8" drive metric hex keys.
Folding Torx set - for Thule rack.
Hammer - small ball-peen.
Linesman pliers.
Diagonal cutting pliers.
Needle nose pliers.
Water pump pliers.
Wire stipper/crimper w/ assortment of crimp ends.
Spare parts:
Fuel pump.
Water pump.
Fuel filter.
Belts (old ones left from previous change).
Plugs, cap, rotor (old).
1 set of front wheel bearings and seal.
Spare bulbs.
Handful of relays.
Fuses.
wiper blades (old).
I also have an AFM, ECU and various other parts at home ready to be shipped if I need them.
General auto stuff:
Bentley manual.
Tire plug kit and 12v compressor.
Jumper cables.
12v light and flares.
Qt engine oil.
Gal antifreeze.
Bottle isopropanol for fuel.
Wheel bearing grease.
several pieces of fuel line.
Gloves - leather and several pairs of latex.
Waterless hand cleaner.
Decent lug wrench and sockets.
Funnel.
Rags.
Electrical tape.
Duct tape!
Sleeping bag.
All of this fits under the bench, with ample room for boots, tarps and more.
I'm sure I missed a few things.
Cheers,
Ric
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
I find that things usually go well right up until the moment they don't. - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
Da TOW'D
Da TOW'D is offline
PostPosted: Sat Mar 03, 2007 7:16 pm    Post subject: Reply with quote
AAA card Smile
'56 deluxe microbus w/sunroof Elvis
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS
levi
levi is offline
PostPosted: Sat Mar 03, 2007 7:33 pm    Post subject: Reply with quote
Riceye!
wow, that's a lot of stuff!
what're water pump pliers? Never heard of that. Should I have had that when I put in my new water pump? Is that why it took me part of 3 days? Rolling Eyes
You forgot the self-fusing silicone tape. Good to about 500 degrees, nice to have if a hose should bust, even at the H-pipe.
dr. no
dr. no is offline
PostPosted: Sun Mar 04, 2007 8:14 am    Post subject: Reply with quote
Screwdriver with 4 bits
duck tape
fuses
jumper wires (and cables)
13, 17, 8, 7, 10, 15mm wrenches
2 vise grips
ratchet handle with various bits
breaker bar with 19mm head (for wheels)
2 more 13mm wrenches (they seem to reproduce)
large hemostat
pump handle pliars (also called channel-loks)
Bentley
belts
heater hose
whatever part I think will die next (currently water pump)
Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant--wonderful!
'86 MB 300GD
'97 Z3
'14 Subaru Crosstrek Mommymobile
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox
riceye
riceye is offline
PostPosted: Sun Mar 04, 2007 10:47 am    Post subject: Reply with quote
Water pump pliers = Channellocks. Not useful for waterpump r&r, but good for general grabbing of things, like hot pans on the campfire.
Ditto on the self-fusing tape. It's not on the list, but it is in the van.
Sounds like a lot of stuff, but it all fits under the bench to the passenger side of the heater box, with the exception of the sleeping bag and Bentley. They're under the jump seat.
Cheers!
ShootingFish
ShootingFish is offline
PostPosted: Tue Jun 07, 2011 9:50 pm    Post subject: Reply with quote
I am looking for suggestions on a good set of wire crimpers... I am about to start a total re-work of the house electrical system and am willing to throw down on a decent tool.
SF
SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy Red Vanagon
'90 Syncro 16 Doka Yellow Vanagon
climberjohn
climberjohn is offline
PostPosted: Tue Jun 07, 2011 10:11 pm    Post subject: Reply with quote
SF
Dear SF,
These are not crimpers, but wire strippers. An amazing tool.
Irwin Vise-Grip Self-Adjusting Wire Stripper 8in., Model# 2578300.
About $21 online.
This makes electrical work SO much more enjoyable! You'll get perfectly stripped wires every time.
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
erdonline
erdonline is offline
PostPosted: Tue Jun 07, 2011 10:14 pm    Post subject: Reply with quote
Here's a pretty thorough thread already going:
http://www.thesamba.com/vw/forum/viewtopic.php?t=238180&highlight=toolbox
Ed
'85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle
randywebb
randywebb is offline
PostPosted: Tue Jun 07, 2011 10:23 pm    Post subject: Reply with quote
so, there is no need for 9, 11, 12, 14 mm wrenches on the Vanagon?
1986 2.1L Westy 2wd Auto Trans.
Wildthings
Wildthings is offline
PostPosted: Wed Jun 08, 2011 3:58 am    Post subject: Reply with quote
Here is a list of what I carried on a long trip a few years back. Most of it except for things like jumper cables, spare oil, battery drill, etc actually fits in a fairly small tool box.
http://www.thesamba.com/vw/forum/viewtopic.php?p=2794763&highlight=tool+list#2794763
Wildthings
PostPosted: Wed Jun 08, 2011 4:00 am    Post subject: Reply with quote
The 9 fits some brake bleeders, the 11 some brake fittings, and the 14 the nuts on the valve adjusting screws, while the 12 will be needed for that metric bolt you scrounged off a Toyota in the wrecking yard. Wink
Perales
Perales is offline
PostPosted: Wed Jun 08, 2011 5:10 am    Post subject: Reply with quote
SF
I highly recommend the Klein 1005. I bought it on TK's suggestion and Wow, what a difference a good tool makes. Home Depot had it in stock for about the same price.
http://www.amazon.com/Klein-Tools-Insulated-Non-Insulated-Terminals/dp/B0006M6Y5M/ref=pd_cp_hi_2
-- 1987 Westfalia automatic (Captain Vino)
randywebb
PostPosted: Wed Jun 08, 2011 11:18 am    Post subject: Reply with quote
Wildthings - you include "1/2 drive sockets 15mm-22mm" in your list (other thread)
To put together a reasonable minimal set of tools to carry in the Vanagon, which of those are needed?
17, 19, and ??
Stockurai
Stockurai is offline
PostPosted: Wed Jun 08, 2011 11:20 am    Post subject: Reply with quote
what I have:
bentley manual
adjustable wrench
needlenose pliers
regular pliers
crow bar
duct tape
5000+ zip ties
ratchet straps
and THIS
http://www.sears.com/shc/s/p_10153_12605_00937154000P?prdNo=1&blockNo=1&blockType=G1
(WHICH IS ON SALE GOOD DEAL!)
Razz
1990 Vanagon Transporter 2.1L [the fridge] - Daily Driver for College Commuting
Dogpilot wrote:
Besides, Yuppies cannot run to a dealership and give a credit card and just buy one. You have to breath life into it, kind of like an Egyptian afterlife thing. Once you resurrect it, it becomes your buddy. It is unusual and has character.
