mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Fri Mar 09, 2007 8:20 am Post subject: 091 Aircooled Transmission Identification |
OK Transmission gurus (Where's Gears at?)
What is the designation "DJ" mean after the part number on a 091 aircooled transmission?
This is the part number: 091 300 043 JX DJ
The only thing I could find was a DJ Tranny was geared more for the mountains, but I can't verify this. |
tencentlife Samba Member
Posted: Fri Mar 09, 2007 9:30 am Post subject: |
There's a DU. Are you sure the J isn't a U?
What year? Date of production is stamped on the gearcase underside right(see Bentley p.3). Code; day; month; last digit of year.
Gear specs are all over the book. Pp. 34.1a-1b; 34.9 (DU's here); 34.19; 35.32-33; 35.60. They're probably some other places I missed. |
Waldemar Sikorski Samba Member
Posted: Fri Mar 09, 2007 9:55 am Post subject: |
There was a tranny made only for Switzerland, I wonder if that's it? |
Posted: Fri Mar 09, 2007 10:04 am Post subject: |
I can't flip it over right now, it's still in the create
here's the sticker:
It's a VW factory rebuild. |
Posted: Fri Mar 09, 2007 12:32 pm Post subject: |
The VW Etka shows it as non existent. Probably it's European. I've stumbled upon a DJ before. Don't have time now to dig in. |
vanmike Samba Member
Joined: January 18, 2006 Posts: 89 Location: Wisconsin
Posted: Fri Mar 09, 2007 4:26 pm Post subject: |
I checked in the german ETKA
the partnumber listed is the replacement
for a bunch of trannys that are not available any longer.
it seems that 1st - 3rd and reverse is the same on all the
gearboxes. 4th for DJ is the same as DH,DN and DO.
DO is the same as DJ exept it has locking differential.
ring an pinion ratio 41/7
hope this helps. |
