rterfert Samba Member
Joined: October 08, 2003 Posts: 1419 Location: Yuma Arizona
Posted: Sun Mar 25, 2007 6:27 pm Post subject: IRS conversion Jig what are they really worth? Dollar wise |
Looking for some input
The one I made for both right and left sides works Great...If I make up a batch from my Jig realistically what would they bring?
Yes I saw the one in the classified.
What is a good price that the average Joe would pay for a conversion Jig?
Thanks for your input. |
sandhopper Samba Member
Joined: December 13, 2004 Posts: 453 Location: Norwalk Ca
Posted: Sun Mar 25, 2007 6:39 pm Post subject: irs jig |
I'd pay $25-$35 for a good jig , I would like to have template for the cut out more . The jig I can make off an other car . A simple paper doll type cut out so you don't cut to much of the horn for better fit |
mrreddog Samba Member
Posted: Sun Mar 25, 2007 7:07 pm Post subject: |
i have been thinking the same thing... |
Durf Samba Member
Joined: October 19, 2006 Posts: 245 Location: San Diego
Posted: Sun Mar 25, 2007 7:55 pm Post subject: |
I like the jig. If I needed one I'd be willing to pay $80 or so for a good one. How much toe-in do you have on that car? Looks like alot but maybe it is an illusion. |
Posted: Sun Mar 25, 2007 8:32 pm Post subject: Re: irs jig |
sandhopper wrote: |
Yes Jason ran into the same problem with the first side (I have a little patch work to do there)
Lesson learned and the second side was much better.
As far as a template.....I just held up the pivot on the second side at 10 degrees,scribed a mark on the frame horn and Jason cut about 1/8" inside the line...Worked great for the initial fitting.
He then bolted the hanger in the Jig and kept clearancing till the 4 side bolts lined up.
The hole was Much improved from the first blind cutting. |
Posted: Sun Mar 25, 2007 8:39 pm Post subject: |
Durf wrote: |
We checked the caster/camber and with the spring plate on the bottom stop we had 1 degree in at the top
The picture of the left wheel at full compression was just a quickie picture and the parts are not fully bolted tight....
Every check so far looks like the suspension will be just about straight up and I dont think these are the expensive arms. |
kcnaz Samba Member
Joined: November 10, 2006 Posts: 312 Location: Sahuarita, AZ
Posted: Sun Mar 25, 2007 9:25 pm Post subject: |
Might just throw the pan up in the truck and drive down to see ya all when the trailing arms come in, The jigs look great. GOOD JOB.......... _________________ When I nod my head ......hit it!!
"rare as rocking horse poo" |
el loco kingo Samba Member
Joined: October 02, 2005 Posts: 607 Location: temecula, california
Posted: Mon Mar 26, 2007 7:17 am Post subject: |
kcnaz wrote: |
Might just throw the pan up in the truck and drive down to see ya all when the trailing arms come in, The jigs look great. GOOD JOB.......... |
Here is the second side after Jason had some practice with the first.....He did all his cutting with a 4" angle grinder.
Posted: Mon Mar 26, 2007 4:47 pm Post subject: irs conversion |
Thats what I was talking about and why I think a template is needed . I have a plasma cutter so I think if I have a guide to do this it will be easy.
I don't like to weld with that much to fill or patch . You said you just traced around the clip and cut 1/8 inside ? What did you use to fill in with 1/8 X1 in strap ? got any pictures of finished side ?
I have 2 cars I want to do , 1 is a sandrail the other is a Fiberglass buggy but both have stock swing axle torsions . |
72BajaBen Samba Member
Joined: July 30, 2006 Posts: 888 Location: Tampa Florida
Posted: Mon Mar 26, 2007 4:55 pm Post subject: |
unless you are converting alot of cars you will only use it once, which sucks. so i wouldnt pay very much. |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Mon Mar 26, 2007 4:59 pm Post subject: |
72BajaBen wrote: |
i borrowed one that was homemade _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Tim10 Samba Member
Joined: April 06, 2004 Posts: 1433 Location: Minneapolis
Posted: Mon Mar 26, 2007 6:09 pm Post subject: |
$50 if you wanted to make money $35 if you wanted volume _________________ Dub Infested- PART WI$H LI$T-CLICK |
seabeebuggy Samba Member
Joined: October 03, 2005 Posts: 2395 Location: NM, CA, UT and now NV
Posted: Mon Mar 26, 2007 6:29 pm Post subject: |
I would pay 75$ for a set. cheeper to buy and resell than pay a shop. I will use a shop because it is cheeper for me . |
wayneweir Samba Member
Joined: September 23, 2006 Posts: 174 Location: Surprise, AZ
Posted: Mon Mar 26, 2007 8:42 pm Post subject: |
I got quoted $200-$300 for the conversion at carcraft in riverside a few days ago. I think im gonna go that route and not have to second guess my own work _________________ Buggy in progress....well not really, i'm too damn lazy |
Posted: Tue Mar 27, 2007 7:48 am Post subject: Re: irs conversion |
sandhopper wrote: |
I have some flat patch panels from other projects that are just under 1/8"
here is one Jason made....Don’t mind the puddle d up weld where I was just filling a few gaping holes he didn’t wish to make panels for. The structural integrity of the hanger is there the pretty under the car he was not concerned with.
SSChicken Samba Member
Posted: Tue Mar 27, 2007 10:39 am Post subject: |
I'm looking to buy or rent a jig very quickly if you are willing to sell one in the next week or so or lend one if you are near. It'd be better for me to rent one for 20 bucks than buy one for 80. |
kcnaz Samba Member
Posted: Tue Mar 27, 2007 8:09 pm Post subject: |
Rick did you build that jig? _________________ When I nod my head ......hit it!!
Posted: Tue Mar 27, 2007 8:49 pm Post subject: |
kcnaz wrote: |
Rick did you build that jig? |
What kind of question is that...What no faith?
check the date in the picture.
Your answer is Yes I made it off of this car.
For this IRS project/conversion
kcnaz Samba Member
Posted: Wed Mar 28, 2007 4:52 am Post subject: |
Not doubting your skills, just a question. Great job. _________________ When I nod my head ......hit it!!
