ogarcia_02 Samba Member
Posted: Thu Apr 05, 2007 11:27 am Post subject: Looking for home made awning |
A while ago there was a post of someone making their own awning out of pvc tubes, I think? They had pictures of the process and where and how they attached it. I've looked but cant seem to find it. Maybe lost along other files a while ago. Anyways if someone could find it or if they saved it I would appreciate if they could post the pics. |
Tomswesty Samba Member
Joined: July 06, 2005 Posts: 194 Location: Moscow, ID
jmfoust Samba Member
Joined: February 01, 2005 Posts: 130 Location: Des Moines, Iowa
Posted: Thu Apr 05, 2007 11:59 am Post subject: |
I found this one in the archieves but its not the one I saw before. The one I'm thinking about had the pvc pipes attached to the body under the sliding door. Well thanks anyways. Waaa |
Posted: Tue Apr 10, 2007 11:32 am Post subject: |
Yeah this is the one I was looking for but hadn't checked the samba over the weekend and I must've posted right after you. Thanks |
kevinbassplayer Samba Member
stumpy Samba Member
Joined: April 04, 2007 Posts: 181 Location: york, pa.
Posted: Tue Apr 10, 2007 3:32 pm Post subject: awning |
I am in the finishing stages of completing work on the, " Awning for the Frugal Westy Owner". I need about another month to finish it. Its simply a 8' piece of PVC pipe into which I routed a 1/4" slot ( For sliding the awning thru) I had 4 hangers fabricated which hold the pipe, and the hanger will be mounted in the gutter. The awning can be as simple as a $4.00 tarp or someyhing more expensive. ( I will start with the cheapo ) Then all you need are a pair of poles and some tiedown ropes. Stumpy |
singlewc Samba Member
Posted: Tue Apr 10, 2007 4:45 pm Post subject: Re: awning |
stumpy wrote: |
Would you give us a peek at the future, and explain how you connect it to the rain gutter? I have tried several things, and as you say, any old tarp will do, and tent poles with stringers and stakes will get it done, but I haven't found a decent 'frugal' method to connect to the van.
I did come across someone who attaches a larger tarp, to the driver's side of the van and pulls it across. That seems a better idea, but for the added size and weight.......
Thanks,
John |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3039 Location: Vancouver Island, B.C.
Posted: Tue Apr 10, 2007 7:13 pm Post subject: |
I'm all over the bus depot awning, never seen it before! |
basil Samba Member
Posted: Wed Apr 11, 2007 6:23 am Post subject: bus depot awning |
The EZ Awning from Bus Depot is fabulous. I have one of the first ones ever sold in the US and have loved it from day one. It takes 5 minutes to set up and packs really small when not in use. It attaches to the gutter with three srew clamps. I made brackets that go beneath the tires, but you can now buy the same thing. It has held up fine in some pretty heavy wind and rain. While it looks like it would be a big sail in the wind, the design actually created downforce that helps keep it in place.
Basil _________________ Cashtration: The act of buying a Beetle and then emptying your bank accounts. |
1621 Samba Member
Posted: Wed Apr 11, 2007 6:41 am Post subject: Re: bus depot awning |
basil wrote: |
Basil |
How does it attach to your van? Can it be permanently mounted?
Lundy _________________ '85 Westy |
basil Samba Member
Posted: Wed Apr 11, 2007 10:38 am Post subject: |
It attaches to the rain gutter with screw clamps. It's not designed for permanant mounting. Instead, it's portable. I have actually used it on the non door side of the van on a couple of occasions due to wind factors for tailgating. _________________ Cashtration: The act of buying a Beetle and then emptying your bank accounts. |
stumpy Samba Member
Posted: Wed Apr 11, 2007 6:33 pm Post subject: awning |
I used a 3/4" angle iron, unto which I welded a 3/16"X 3" piece of steel which is shaped to the conture of the PVC pipe. The hanger is mounted to the gutter with 2 small screws. I used 4 hangers for the 8' piece of pipe. If I ever learn to post pics, I will get them on the forum. The whole works cost me about $40.00. I sewed a 5/8" nylon rope onto the tarp, and I slide the rope thru the slot in the PVC. Stumpy |
Thin Metal Samba Member
Posted: Sun Apr 15, 2007 10:25 am Post subject: Home Made awning |
Wasn't there an optional factory side tent type awning made for the Vanagons at some certain years? |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5066 Location: denver
Posted: Mon Apr 16, 2007 10:29 am Post subject: |
kevinbassplayer wrote: |
I also have the EZ Awning. For the price, it can't be beat. It's a bit clumsy to set up until you get the hang of it. There are lots of poles and stuff, so it's best set up, in my opinion, if you're going to stay where you are for a day or two.
It's sturdy and stands up to the wind very well.
I'd rather have a Shady Boy, but for the price, the EZ Awning is great. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
DAVEURO Samba Member
Posted: Mon Apr 16, 2007 6:09 pm Post subject: |
One of the thing I like about the Bus Depot awning is that the top is pointed lessening the chance of rain collecting and collapsing. Shade is good but rain can suck. |
Posted: Wed Apr 18, 2007 7:59 am Post subject: |
DAVEURO wrote: |
That's true--also, mine has been through a couple of ugly (albeit short) hailstorms up in the mountains, and I had no rips, tears, sags, nothing. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
craig wright Samba Member
Joined: June 06, 2006 Posts: 2 Location: Hull - Yorkshire - UK/Dubai - UAE
Posted: Wed Jun 27, 2007 3:21 am Post subject: |
Here's another alternative. Good if you're in the U.K. and don't want to import.
http://www.the-bus-shelter.com/
