Progress : T3 Full Flow plumbing
Max Welton
Max Welton is offline
PostPosted: Tue Apr 10, 2007 10:00 pm    Post subject: Progress : T3 Full Flow plumbing Reply with quote
http://66.225.214.60/squareback68/T3FullFlow.html
Comments on the use of washers between the case and shroud? Seemed like a reasonable thing to do.
Max
1967 Type-3 Fastback
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Wed Apr 11, 2007 2:58 am    Post subject: Reply with quote
as long as you aren't losing any cooling air from gap, shouldn't be a problem...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
localboy
Samba Longboarder
localboy is offline
PostPosted: Wed Apr 11, 2007 10:30 am    Post subject: Reply with quote
When you install the large inner fan just make sure you have no clearance issues against the housing.
One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project
Russ Wolfe
Russ Wolfe is offline
PostPosted: Wed Apr 11, 2007 3:14 pm    Post subject: Reply with quote
It can be done without grinding the case, or spacing it out. Those pictures are of Jim Adney's installation.
Gary: OK. Ima poop.
Max Welton
PostPosted: Wed Apr 11, 2007 4:12 pm    Post subject: Reply with quote
Got it. Although I'm not a big fan of those barbed fittings. Or all those extra angles.
Thanks! Cool
Max
FASTBACKDON
The other insensitive jerk like Neil
FASTBACKDON is offline
PostPosted: Wed Apr 11, 2007 4:13 pm    Post subject: Reply with quote
the secret is the Gene Berg type 3 full flow pump cover
FUCK CANCER FUCK CANCER FUCK CANCER!!
Mom 25 months of standing up to Cancer R.I.P I miss you so much.
Buy my best friends stuff
http://www.thesamba.com/vw/classifieds/search.php?username=56TIMOTEO
(21:10:42) Jennepher: Russell is our proudest achievment. I feel like Samba created him from a little nugget of crap into a full blown adult.
localboy
Samba Longboarder
localboy is offline
PostPosted: Wed Apr 11, 2007 5:16 pm    Post subject: Reply with quote
The Gene Berg kit does a good job but it's still a very tight fit back there. My fan housing still required very minor clearancing.
FASTBACKDON
PostPosted: Wed Apr 11, 2007 5:22 pm    Post subject: Reply with quote
Really? Ok thanks for the warning I need a berg fullflow for my 2 liter. what clearancing is involved send or post pictures.
Thanks Mark
Don
localboy
Samba Longboarder
localboy is offline
PostPosted: Wed Apr 11, 2007 5:32 pm    Post subject: Reply with quote
Thanks Mark
Don
Really minor though, Don. Mainly one of the raised "fins" on the rear molded into the housing for strengthening. I'll see if I can find a pic of it. If not I have to raise it up and crawl under there for some pics for Brian so I'll try to get some as best as possible.
Like I said; it's a tight fit. God forbid it leaks from one of the fittings. Mad I'd have to take apart the entire fan housing etc. just to get to it.
Max Welton
PostPosted: Wed Apr 11, 2007 6:32 pm    Post subject: Reply with quote
Unless I am mistaken, the only difference between the Berg type-1 and type-3 kits are the fittings. I just changed the fittings on mine.
Max
Notched
Notched is offline
PostPosted: Wed Apr 11, 2007 6:57 pm    Post subject: Reply with quote
I really like my engine builders plan. No angles... No adjusting anything...
If you look closely, there is a brass block off between the holes.
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
localboy
Samba Longboarder
localboy is offline
PostPosted: Wed Apr 11, 2007 7:01 pm    Post subject: Reply with quote
Max
Yeah it's got a different brass fitting that's slightly clearanced on one side to clear the fan housing.
Max Welton
PostPosted: Thu Apr 12, 2007 11:17 pm    Post subject: Reply with quote
You guys were right. Very Happy
The fan did touch the shroud with those spacers. And I did have to take some material off one of the ribs to clear the right side of the pump cover.
See updates: http://66.225.214.60/squareback68/T3FullFlow.html
Max
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Thu Apr 12, 2007 11:37 pm    Post subject: Reply with quote
True...but the Berg pressure regulating unit is the better choice. Keeps your oil filter from exploding Wink
P.S. I like Phillip's solution the best!
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
dcdubs
dcdubs is offline
PostPosted: Fri Apr 13, 2007 11:53 am    Post subject: Reply with quote
notched has the right idea...no reason for messing with anything else....then you can stil run the cool 1500 super oil pump cover Wink
dcdubs/glcustoms
AllRightGarageDoorsNW.com
Max Welton
PostPosted: Tue May 01, 2007 9:18 pm    Post subject: Reply with quote
Now we're cookin. Cool
I will make a bracket to place the filter farther forward and a little higher. But there it is.
Max
Critter1
Critter1 is offline
PostPosted: Wed May 02, 2007 6:00 pm    Post subject: Reply with quote
Here are some pics of how mine was done. Had to shave some material off the back of the shroud as well as shave some meat off the brass fitting.
This filter mount worked for me since I have merged headers and no heater boxes.
Justin
Russ Wolfe
PostPosted: Wed May 02, 2007 8:00 pm    Post subject: Reply with quote
Don't know if I like the filter that close to the headers. It will add heat to the oil.
And, it looks like you are not an IRS engine with the cross member.
Gary: OK. Ima poop.
localboy
Samba Longboarder
localboy is offline
PostPosted: Wed May 02, 2007 8:19 pm    Post subject: Reply with quote
Agree, Russ. I fab'd a simple bracket to use the bumper mounting location with just longer bolts. My oil filter sits above the driver's side bumper bracket and the steel braided hoses clear the headers by a few inches. Now if I could only get the breather box hoses to run so cleanly. Evil or Very Mad
redbug74
redbug74 is offline
PostPosted: Wed May 02, 2007 8:23 pm    Post subject: Reply with quote
Killer installation. Gives me ideas when I get ready freshen up the motor in my square.
Different Strokes for Different Volks
74 Standard Type 1
69 Squareback Type 3
55 Oval Type 1
