Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80160 Location: Sneaking up behind you
alindeman1989 Samba Member
Joined: April 18, 2005 Posts: 657 Location: Newark, Ca
Posted: Thu Apr 19, 2007 2:58 pm Post subject: |
i have a 2180cc as well and live in sunny cali. i have a external mesa 72 plate cooler with one big fan a a electronic thing that kicks th fan on when it hits 175 degree and never goes past 180. im very happy with it. sit in stop and go all day with it never going past 180 or so.  _________________ 2180 powered 1974 super( sleeping since 2011)
1967 beetle(new project) |
Glenn  Mr. 010
Posted: Thu Apr 19, 2007 3:02 pm Post subject: |
Where do you have it mounted? _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Apr 19, 2007 3:07 pm Post subject: |
above the tranny. nice and out of the way. if you go under the car above the tranny is the luggage area and i monted it on the luggauge area. never had a problem. what are your temps right now? _________________ 2180 powered 1974 super( sleeping since 2011)
Street Bug 29 Samba Member
Posted: Thu Apr 19, 2007 3:33 pm Post subject: |
| the cooler bypass thermostat is nice to, helps at start ups,and wont use the cooler when you dont need it |
Posted: Thu Apr 19, 2007 3:38 pm Post subject: |
i have one of those.  _________________ 2180 powered 1974 super( sleeping since 2011)
HBRag Samba Member
Joined: April 29, 2005 Posts: 735 Location: Huntington Beach, CA
I've run up to a 2110 in a sedan and never needed a fan on the external oil cooler. I've just mounted a cooler on the bottom side of the package tray with some rubber standoffs (like they use on the FI fuel pumps). The oil temp runs consistently between 180 and 200 degree. On very hot days on long runs (400 miles) it climbs to 210 degrees.
The bigger problem I had aws getting the engine to warm up with oil flowing through the cooler. I ended up mounting a four inlet/outlet mount on a Bugpack bump mount bracket.
http://store.summitracing.com/partdetail.asp?autof...toview=sku
I plugged the out let hole on the back side of the mount and used a short brass nipple to screw the following oil flow thermostat on the forward output.
I then connect the two fittings facing forward on the thermostat to the cooler, and the one remaining (top rear) is the return back to the engine.
With this setup the oil doesn't flow through the cooler until it reached 180 degrees. The optional fan will help control the top temperature (which I do on buses). |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15602 Location: Deep in the 405
Posted: Thu Apr 19, 2007 4:17 pm Post subject: |
Another option would be a DTM from Jake _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Thu Apr 19, 2007 4:20 pm Post subject: |
thats the route im goin... ( rabys dtm) but im only building a 1915... _________________ Brian
68 sedan
Dallas Air Coolers
| perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time.  |
| cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
Glenn  Mr. 010
Posted: Thu Apr 19, 2007 4:23 pm Post subject: |
| vwracerdave wrote: |
| Another option would be a DTM from Jake |
I've got my reasons for staying with the OEM shroud. _________________ Glenn
Member #1009
#BlueSquare
jammer729 Samba Member
Posted: Thu Apr 19, 2007 6:00 pm Post subject: |
| Hey Glenn, What kind of compression are you running? I'm building a similar combo to yours and was just wondering? |
Glenn  Mr. 010
Posted: Thu Apr 19, 2007 6:29 pm Post subject: |
9.3:1 _________________ Glenn
Member #1009
#BlueSquare
Mad Manx Samba Member
Joined: September 30, 2004 Posts: 304 Location: Redondo Beach California
Posted: Thu Apr 19, 2007 7:14 pm Post subject: |
I use one of the sandwich thermostat adaptors along with a Setbab
single fan cooler. I mounted the cooler in the area in front of the axle
and to the left of the tranny. I put the thermostat fan switch (180 deg)
on the outlet of the cooler, I figured if the oil is still over 180 when it
come out of the cooler I should have the fan running. Beware that
even the made in the USA sandwich adaptor needs to be cleaned up
because it was very restrictive. My 2332 runs nice and cool and the
fan only comes on once in a while. Here are a couple of pictures of
the sandwich adaptor before and after.
Marty Staggs Samba Member
Posted: Thu Apr 19, 2007 8:23 pm Post subject: |
Yeah those and even the filter adapters need "fine tuning". _________________ Marty |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Thu Apr 19, 2007 8:41 pm Post subject: |
| Mad Manx wrote: |
come out of the cooler I should have the fan running. |
Exactly right MM.
Hey Glenn, the single is all you need. They are VERY efficient oil coolers. A single setrab cools as much as a large mesa. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
John M. Samba Member
Joined: July 22, 2005 Posts: 3833 Location: Boulder, CO
RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Fri Apr 20, 2007 8:13 am Post subject: |
| Mad Manx wrote: |
| I use a Setbab single fan cooler. I mounted the cooler in the area in front of the axle and to the left of the tranny. |
Are you running a swingaxle? Because Glenn has IRS and the limited space of the IRS swing arms may not have the Setrab to fit and will have to have it up higher.
Here is shots of Max Welton's '67 Ghia with the Setrab installed:
I setup my Setrab, mounts, and fanswitch (from Aircooled.net) the same way as Max did on my '64;
One thing I noticed where I mounted mine, I may need to switch to the Joel Mohr mid-mount as the Berg mid-mount rubber pieces won't clear.
The little fins on the bottom are house siding vents and used a screen door mesh to prevent any debris from getting caught between the fins.
_________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Fri Apr 20, 2007 9:42 am Post subject: |
Yea mine is a swing axle and is setup almost exactly the same as the
pictures. ( great pictures by the way ) I forgot about the IRS and the
a-arm being in the way but I am sure Glenn can figure that out.  |
