jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Thu Apr 19, 2007 12:24 pm Post subject: Nose cone |
how can you tell if your nose cone is damaged? i just did my mounts. the front mount was really bad. just got the car so dont know how long they were like that. put all new heavy duty german mounts in but did not inspect the nose cone. _________________ www.cultwagen.com |
sled Samba Member
Posted: Thu Apr 19, 2007 3:12 pm Post subject: |
if the nose cone is broken then it will possibly leak and also under acceleration it will buck and lurch. your shifting may be difficuly and erratic as well. |
Posted: Thu Apr 19, 2007 3:42 pm Post subject: |
So would the motor move back and fourth like it did with the broken front mount? can you tell by looking under the car? _________________ www.cultwagen.com |
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Thu Apr 19, 2007 5:54 pm Post subject: |
I've seen a few broken ones, and its usually the square boss with the mounting holes in it. Snaps right off the nose cone body. Look for a big crack. |
Posted: Thu Apr 19, 2007 10:29 pm Post subject: |
did not see any big cracks and it was pretty dry so i think im good. looks to have a small leak where there is a threaded sensor (reverse light?) _________________ www.cultwagen.com |
Herby Samba Member
Joined: January 24, 2005 Posts: 742 Location: LALA Land
Posted: Thu Apr 19, 2007 10:50 pm Post subject: |
Check to see if the holes where the studs for the tranny mount on the nose cone have ovaled. I recently changed my tranny and this mounting area had oval holes instead of perfect circles, which most likely caused the tranny to teeter and most likely cause my shifting problems since they went away when I added a midmount a couple months ago. _________________ 62 Beetle
73 Super Beetle German Look project
03 TDI Jetta
Airspeed
www.airspeedvwclub.com
"Do not assume that there isn't room for improvement just because VW didn't do it."
Samba #34091 |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Thu Apr 19, 2007 11:35 pm Post subject: |
ouch.
my bug is a 65. it has a sensor in the nose cone. was that for a reverse light? so do i have a later tranny? _________________ www.cultwagen.com |
sled Samba Member
Posted: Fri Apr 20, 2007 12:07 am Post subject: |
yes you do |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
