Oil filler neck socket.
FreakCitySF
FreakCitySF is offline
PostPosted: Tue Jun 19, 2007 4:42 pm    Post subject: Oil filler neck socket. Reply with quote
I need this tool
Anyone have an extra laying around? or not gunna use it anymore?
uberautowerks
uberautowerks is offline
PostPosted: Tue Jun 19, 2007 9:19 pm    Post subject: Reply with quote
They suck, they slip, they make you cuss!
Use this...
Internal pipe wrench, Ace (and others hardware stores) have them.
--- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black)
74 Thing
74 Thing is offline
PostPosted: Wed Jun 20, 2007 10:46 am    Post subject: Reply with quote
How does that internal pipe wrench work-does the cam just expand outward grabbing the nut from the inside?
I agree that adapter socket sucks-it will slip and you will strip the nut. I saw a hand made one once where a piece of short pipe was cut and on one end a rod was drilled through to create a tee handle and on the other end a amall rod was drilled through and welded on to instert into the nut.
uberautowerks
PostPosted: Wed Jun 20, 2007 8:48 pm    Post subject: Reply with quote
-Yeah the cam just grips the inside and tries to rotate, well it can't so it "Jams" and out comes the filler nut thingie!
-You have to position it carefully so the cam is in the nut, if you get it too far in you miss the nut and are trying to twist off the top of the neck!
-That piece in the leading picture seams to be designed to suck. Look how the ends of the "tang" are angled off right where in grabs the slot!
- Douglas Adams -
'74 Thing (White)
PostPosted: Wed Jun 20, 2007 9:10 pm    Post subject: Reply with quote
I agree the internal pipe wrench is so much easier to use.
I even have the real dealer tool as seen in the first post (higher quality) and I still use the pipe wrench.
GPthing
GPthing is offline
PostPosted: Wed Jun 20, 2007 10:20 pm    Post subject: Reply with quote
Great tool... have three different sizes. The tool for every thing. Laughing
brian
74 Thing
74 Thing is offline
PostPosted: Thu Jun 21, 2007 9:36 pm    Post subject: Reply with quote
What size is needed for the oil filler nut-I saw a 1/2" and a 3/4" wrench in the pipe section at the hardware store.
Petermac
Petermac is offline
PostPosted: Thu Feb 23, 2017 9:23 pm    Post subject: Re: Oil filler neck socket. Reply with quote
Did you ever figure out the size internal wrench you needed
Hobug Premium Member
Hobug is offline
PostPosted: Fri Feb 24, 2017 6:38 am    Post subject: Re: Oil filler neck socket. Reply with quote
I bought a 1 inch and it does the job.
73 Thing (Typ481)
76 Westy
69 Squareback auto
72 Super
63 Bug
Wildthings
Wildthings is offline
PostPosted: Mon Feb 27, 2017 9:44 pm    Post subject: Re: Oil filler neck socket. Reply with quote
I took an old strap style gate hinge, did a bit of grinding so that is fits the slot and it work perfectly.
