Trash in my Tranny
ziasync
ziasync is offline
PostPosted: Wed Jul 18, 2007 6:34 pm    Post subject: Trash in my Tranny Reply with quote
Finally broke the drain plug loose on the tranny today so I purchased some Redline MT90 and proceeded to change the oil. Well I pull the plug and it was full of metal shavings and 4 ball berrings. I also fished out a thin piece of metal that turned out to be a bearing sleeve with the drain magnet. The sleeve says RollAx 091301120 on it. I looked up the # but all I could find about it is Ball Sleeve. Does anyone know what bearing this is or any info about it? I haven't been having very good luck with my new van but its a long story Sad
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jul 18, 2007 6:37 pm    Post subject: Reply with quote
I see a new tranny in your future.
Loose ball bearings are bad.
Glenn
Member #1009
#BlueSquare
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Jul 18, 2007 6:42 pm    Post subject: Reply with quote
Being able to read part numbers is worse.
Mr. 010
Glenn is offline
PostPosted: Wed Jul 18, 2007 6:43 pm    Post subject: Reply with quote
Very true.
Glenn
Member #1009
#BlueSquare
mightyart
mightyart is offline
Shavings on the magnetic drain plug are normal, any chunks, teeth, or hunks of metal are bad(if you can read the part numbers, ouch), sorry but Glenn is right.
ziasync
ziasync is offline
PostPosted: Wed Jul 18, 2007 6:44 pm    Post subject: Reply with quote
Makes me want to cry Evil or Very Mad
Mr. 010
Glenn is offline
PostPosted: Wed Jul 18, 2007 6:46 pm    Post subject: Reply with quote
Start looking for a good used tranny and pick a weekend. Afterwards you'll feel the pride in doing the job yourself.
You'll also feel exhausted.
Glenn
Member #1009
#BlueSquare
camo westy
camo westy is offline
PostPosted: Wed Jul 18, 2007 6:52 pm    Post subject: Reply with quote
Maybe someone hid those things in your tranny....
Maybe not.
Sorry.
ziasync
ziasync is offline
PostPosted: Wed Jul 18, 2007 7:07 pm    Post subject: Reply with quote
Let me cry on your shoulder a bit. Sad
I bought the Wolfberg Syncro in March From JDM Imports in Co. They said it recently had a full major service and that the tranny had been rebuilt. Well so far the ingnition switch burned up on the way home the day i purchased it, the throttle spring broke, the small hose from the oil cooler busted leaving us stranded 100 miles from home, the header broke compleatly at the flange in the middle of a 200 mile trip, it was experiencing Vanagon Syndrome witch turned out to improper belt tension, and now this. I'm growing tired. Fortunately the Syncro came with a warranty that covers the tranny so we'll see. I'm sceptical. Unfortunately we had a week long camping trip planned in less than two weeks.
ziasync
ziasync is offline
PostPosted: Wed Jul 18, 2007 7:09 pm    Post subject: Reply with quote
I could think of a lot of better things they could have hid in the tranny.
mightyart
PostPosted: Wed Jul 18, 2007 7:25 pm    Post subject: Reply with quote
A wise old hillbilly once told me:
"When you're buying a used car you're just buying someone elses problems".
I would go over it all carefully before you embark on any long trips , and I hope they honor the warrenty, syncro tranny isn't cheap.
Mr. 010
Glenn is offline
PostPosted: Wed Jul 18, 2007 7:28 pm    Post subject: Reply with quote
Not always true. Sometimes people just wnat a new car. My current car was 5 year old and had 60k on it. It's now 7 years old and had 145k. Other than regular oil changes, brakes, tires and a 90k service it's needed nothing.
You need to assume nothing. And a warranty is worthless unless you can actually get it honored.
Glenn
Member #1009
#BlueSquare
mightyart
PostPosted: Wed Jul 18, 2007 7:38 pm    Post subject: Reply with quote
Of course it's not always true, I said a "wise hillbilly" told me that.
A wise hillbilly is kind of like military intelligence or jumbo shrimp. Laughing
DAVEURO
DAVEURO is offline
PostPosted: Wed Jul 18, 2007 8:16 pm    Post subject: Reply with quote
In agreement
captainpartytime
captainpartytime is offline
PostPosted: Wed Jul 18, 2007 8:31 pm    Post subject: Reply with quote
WHAT!!!! 85K miles in two years!!! What are you smuggling and from where?
-Kerry
1982 turbo diesel Westfalia
ziasync
ziasync is offline
PostPosted: Wed Jul 18, 2007 8:56 pm    Post subject: Reply with quote
Found it! RollAX 091301120 is a shift rod bushing. Page 35.76 in the Bently.
Alan Brase
Alan Brase is offline
PostPosted: Wed Jul 18, 2007 11:55 pm    Post subject: Reply with quote
I THINK that's one of the ball sleeves that the shift rods glide on. It could ONLY come out because the tranny was incorrectly assembled. These support the shafts in holes in the case. I'd think that without one, the shifting on that fork would be pretty sloppy. IT MIGHT be stable enough for some continued driving. ( I'm not sure what subsequent damage could result, but it seems like not much. Perhaps wear on the fork. And it's probably already occurred.)
List member "Gears " would have a pretty good perspective on this.
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
ziasync
ziasync is offline
PostPosted: Thu Jul 19, 2007 5:02 am    Post subject: Reply with quote
Thanks Al. I may try to PM "gears" this evening. The shifting has been sloppy from day one. I thought it was just normal as this is my first vanagon. I'm going to change the gear oil and try it out. I may go on my camping trip anyway and just have it fixed afterwards.
24inchstance
24inchstance is offline
PostPosted: Thu Jul 19, 2007 10:15 am    Post subject: Reply with quote
I just replaced my tranny about 2 months ago. My ring and pinion were going and it sounded like I was driving a 747. This is what my drain plug looked like the last two times I replaced my fluid. Pretty sweet.
1990 Westy MV
2.2L WBX w/ LSD
1986 Darth Moped
81 Centurion
tikibus
tikibus is offline
PostPosted: Thu Jul 19, 2007 1:25 pm    Post subject: Reply with quote
I hope some type of "trail magic" puts you on the Golden Road.
Your lucky the ball bear didn't get "Plink-O"-ed around and messed up things bad Mad
Tranny is in your future...
If it is still operational, you may get the core charge back, depending on who you go to and IF the tranny is still deemed good.
My .02's is to go into the reciepts and find out who did the tranny work and with much poise and guile, state your case to those who did the work. Syncro trannies are a different beast than the norm, so if any type of warranty is there...
Finding a used Syncro tranny is tricky. Best to take the un-lubed bend over and get rebuilt.
I feel your pain. My good friend and I did a swap on his Syncro tranny and the "new" tranny crunches when downshifting into 3rd. He is not happy with the deal Mad
24"- did you pick that for all of us?? Such a beautiful Metal flower... Vanagistis Fuckeditisus I think is the speices.
Happy Trails!
Mark
______________
Founding member of the Empire State VW Camping Club.
http://www.empirevwcamping.org/
1984 Westy - Tiki
1997 Honda Civic -The Green Hornet
1971 Volvo P-1800E- needs TLC
