pinkiedog64 Samba Member
Joined: June 24, 2007 Posts: 97 Location: Kerrville, TX
Posted: Sun Jul 22, 2007 8:00 pm Post subject: Engine tin diagram |
Does anyone know where there might be a complete engine tin diagram on the internet or on this site that shows all the engine tins and where they go? I'd like to look at one as I think I may be missing a piece or two. It's for a '69 Beetle with a '75 1600 dp. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
harryset Samba Member
Joined: July 14, 2005 Posts: 690 Location: Bemidji, MN
Posted: Mon Jul 23, 2007 10:43 am Post subject: |
I don't believe I've ever seen parts no. 7 or 8 before, for that matter, I've never seen either of those assemblies before. _________________ '72 Standard
Proud owner of a "Hoover Bit"
185 60's up front, Empi disc kit, 2 1/2" drop spindles, 185 65's in back, stock drums.
Sound Deadening by Secondskin |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Mon Jul 23, 2007 11:03 am Post subject: |
These diagrams cover a wide number of years, including much later engines. _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Mon Jul 23, 2007 11:47 am Post subject: |
7 & 8 are the lower cooling tins with flaps for the "stale air" heat exchanger cars up to 1963-1/2 _________________ Midwest Autosavers, Inc. Woodstock, IL |
Posted: Mon Jul 23, 2007 5:23 pm Post subject: |
That's good to know. I thought I was gaining ground on replacing my engine tin, until I saw that particular diagram. My 72 should be ok. _________________ '72 Standard
Posted: Mon Jul 23, 2007 5:25 pm Post subject: |
Does part no 11 have a matching right hand tin? Is this the pice that the top cylinder tins screw to? _________________ '72 Standard
68Bug-lite Samba Member
Joined: July 31, 2005 Posts: 1087 Location: Tustin, CA
Posted: Mon Jul 23, 2007 7:04 pm Post subject: |
harryset wrote: |
Does part no 11 have a matching right hand tin? Is this the pice that the top cylinder tins screw to? |
Yes, and yes...
They vary slightly in appearance, but thats it. The rear breast tin is held by the same screws aswell. |
Posted: Mon Jul 23, 2007 7:31 pm Post subject: |
How important is piece no. 11? I have the piece in the picture above, but not the opposite piece. Will my engine be ok cooling-wise without it?
Thanks,
Stephan |
Glenn Mr. 010
Posted: Mon Jul 23, 2007 7:32 pm Post subject: |
They're all important. If they weren't needed the factory would of left them off. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jul 23, 2007 7:58 pm Post subject: |
I realize that, but is my engine gonna overheat and fry if I don't have that piece? |
Glenn Mr. 010
Posted: Mon Jul 23, 2007 8:00 pm Post subject: |
pinkiedog64 wrote: |
No... most engines have them missing along with the "Hoover Bit", the flaps and the thermostat.
But is will run cooler and last longer with all that stuff. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jul 23, 2007 8:22 pm Post subject: |
Do you know anywhere where I can get this individual piece? |
Posted: Mon Jul 23, 2007 8:56 pm Post subject: |
Mid America has them listed, but not shown, in their engine tin listing. $13.00, 306-104 and 306-105. Wasn't sure where they went until now. Also, try the classifieds here. _________________ '72 Standard
Glenn Mr. 010
Posted: Tue Jul 24, 2007 3:00 am Post subject: |
Swap Meets
Classified
Salvage Yards _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jul 24, 2007 5:42 pm Post subject: |
CURSE YOU!!!
Visited the site and ended up spending $250. _________________ '72 Standard
mikemck Samba Member
Posted: Tue Aug 07, 2007 9:56 pm Post subject: |
Where does piece #5 go?
Thanks. |
Posted: Wed Aug 08, 2007 5:49 am Post subject: |
mikemck wrote: |
Where does piece #5 go? |
Under the cylinders, muey importante!
You can just see it in this pick, up against the cylinders...
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Wed Aug 08, 2007 6:32 am Post subject: |
What about pieces 44, 49, & 51? It looks like they seal up the heat riser. Do parts 49 & 51 fit inside 44? I found 44 for sale @BFY, but not the others. And part 42, does it seal up the pre-heat hose? |
