how do i know ?
buster
buster is offline
PostPosted: Mon Jan 13, 2003 7:39 pm    Post subject: how do i know ? Reply with quote
how do i know if i have a mechanical or vacuum distributor? the distributor is not attached to an engine. so i dont know if that makes a differance. is there a number to look at or what? please help
static
static is offline
PostPosted: Mon Jan 13, 2003 8:13 pm    Post subject: how do i know ? Reply with quote
If it looks like this: http://store1.yimg.com/I/jimscustomvw_1710_31830 then it is a mechancial distributor.
Here is what you need to know:
http://www.aircooled.net/gnrlsite/resource/articles/distributor.htm
Jeff H
Jeff H is offline
PostPosted: Mon Jan 13, 2003 8:39 pm    Post subject: how do i know ? Reply with quote
Hey Buster;
I think the easiest way to tell is this... If it has a diaphragm (on the outside of the distributor), and a little tube running to the carburator, it's a vacuum distributor. The diaphragm is probably 2-3 inches in diameter and not quite an inch thick. It will have a little air tube coming out of it.
Hope that helps a little.
JSH
Aussiebug
Aussiebug is offline
PostPosted: Mon Jan 13, 2003 8:59 pm    Post subject: how do i know ? Reply with quote
As Jeff says the vacuum distributors have a canister mounted on the side of the body.
Mechanical advance distributors like the 009 have a circular body with no canister stuck on the side.
A 009 has a 9 digit Bosch part number ending in 009 (amazing!)
Most of the vacuum distributors have a 9 digit VW number ending in 205 and usually followed by one or two letters, (which tells you which vacuum model it is).
Regards
Rob
buster
buster is offline
PostPosted: Mon Jan 13, 2003 10:09 pm    Post subject: how do i know ? Reply with quote
thanks for the help. im not the most engine inclined kind of person. what is better a vacuum or mechanical?
oregonian52
oregonian52 is offline
PostPosted: Wed Jan 15, 2003 8:11 am    Post subject: how do i know ? Reply with quote
For a stock engine the vacuum is the only way to go. Better driveability.
static
static is offline
PostPosted: Wed Jan 15, 2003 9:20 am    Post subject: how do i know ? Reply with quote
It took me about 20 years to learn that.
I am finally back to a stock distributor and my bus drives better than it ever has.
The pain lingers on though, on account of the big 'dope slap' that I gave myself.
j.pickens
j.pickens is offline
PostPosted: Wed Jan 15, 2003 2:27 pm    Post subject: how do i know ? Reply with quote
The BEST thing I ever did to my bus was to dump the 009 mechanical distributor for a stock vacuum unit. The bus idles like a kitten's purr, has much better gas mileage, doesn't surge or backfire, and doesn't diesel (keep running) when you shut the ignition off. Oh, and my skin cleared up, too.
buster
buster is offline
PostPosted: Wed Jan 15, 2003 9:27 pm    Post subject: how do i know ? Reply with quote
so is this a big deal to switch from a mechanical to a vacuum? what all is involved? do you need to do anything inside the case?
