jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Thu Aug 09, 2007 1:00 pm Post subject: end play? |
went to adjust my valves and there is like 1/4 inch or more play in the bottom pulley. the motor has less then 2000 miles on it. what went wrong? _________________ www.cultwagen.com |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Thu Aug 09, 2007 1:23 pm Post subject: |
You mean crank end play? At 1/4" something major is wrong, and you'd best pull the motor ans see if you have something like a looseflyweheel that is readying to let go and do more damage. |
Posted: Thu Aug 09, 2007 1:40 pm Post subject: |
i can rotate the pulley side to side more than 1/4 inch before it catches. _________________ www.cultwagen.com |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Thu Aug 09, 2007 1:43 pm Post subject: |
jroymcd wrote: |
i can rotate the pulley side to side more than 1/4 inch before it catches. |
So you don't mean that you are trying to push and pull the pulley "in and out", but rather that you are turning the pulley in the direction of rotation and it takes a bit of turning before you feel resistance? That is normal. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Thu Aug 09, 2007 1:47 pm Post subject: |
Or possibly the keyway in the crank and or the crank pulley is beat/worn? |
The Noof Samba Member
Posted: Thu Aug 09, 2007 1:51 pm Post subject: Re: end play? |
jroymcd wrote: |
went to adjust my valves and there is like 1/4 inch or more play in the bottom pulley. the motor has less then 2000 miles on it. what went wrong? |
Are you adjusting the valves to resolve anoise issue, and then discovered this?If so, you discovered your noise.Keifernet may be right...pulley came loose, and it did in the keyway.Could be camshaft drive gear loose on the crank as well. |
Posted: Thu Aug 09, 2007 2:02 pm Post subject: Re: end play? |
The Noof wrote: |
Are you adjusting the valves to resolve a noise issue |
YES
Would it be safe to drive it for a few miles. _________________ www.cultwagen.com |
Posted: Thu Aug 09, 2007 2:31 pm Post subject: |
I wouldn't untill I knew for sure what it is, bro. |
Posted: Thu Aug 09, 2007 2:52 pm Post subject: |
dowel pin that holds in the main bearing? _________________ www.cultwagen.com |
SRP1 Samba Member
Posted: Fri Aug 10, 2007 12:32 am Post subject: |
Somthing is wrong with that! While it's very possible it is a loose pulley and wobbled out key way, what you may be seeing is actually an excessive amount of crankshaft endplay. Look carfully when you rock the crankshaft back and forth, the cam gears will normally push the crank front to back with a slight twisting motion in the crank. That will give you the impression that it's only the pulley moving side to side when in fact the crank is walking front to back. Hope this makes sense to you, let us know what you find. |
