VOODOOKING Samba Salami Slapper
Posted: Sun Aug 12, 2007 6:44 pm Post subject: |
FRONT
current set up...
6 inch narrowed beam
2.5 CB drops
135 Diamondback whitewalls ($650 Nankangs with a white wall cut into them )
flipped tie rods
Chrome Rader repops ( still hasnt grown on me with the WW's,.. so stocks are going back on)
REAR
current set up...
KCW 2 inch tranny raise
2 outers
145 Diamondback white walls
Chrome Rader repops
notched spring plates
currently look like this:
Stockers going back on soon,.. possibly some other color than red
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Sun Aug 12, 2007 7:02 pm Post subject: |
Front:
7" Narrowed beam, no shocks
Stock Smoothies
135's with Port-a-Walls
Rear:
3 Notches
Notched Springplates
No Shocks (might try to find some that will work)
Stock Smoothies
165's with Port-A-Walls
aeromech wrote: |
in my opinion you don't know shit |
Jason C Samba Member
Joined: June 14, 2005 Posts: 1028 Location: Portland Oregon
Posted: Sun Aug 12, 2007 8:47 pm Post subject: |
It would be nice to have one of these (Pictures of tire, wheel, and suspension thread for FAQ's) in the offroad forum too. _________________ Throw me a bone here. All I wanted were
sharks with friggen laser beams attached to their heads.
64 Bug |
EverettB Administrator
Joined: April 11, 2000 Posts: 69801 Location: Phoenix Metro
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Sun Aug 12, 2007 10:26 pm Post subject: |
Up front
7 1/2" beam no shocks SAW adjusters built by me.
CB drop spindles built by me.
Flipped tie rods.
3 1/2" spindle mount wheel with a goodyear 125 temp.
In the back
67 axles
3 and a half clicks
5" Randar with a 165
The shocks that came with the car
I tried to go 4 clicks in the back. The shocks wouldn't fit and the tires hit the body. |
ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Mon Aug 13, 2007 2:53 am Post subject: |
My 58:
Front-
4" beam, no shocks. Built by me
CB spindles
Hammered headlight buckets
175/60R14 on Bus wheels
Didn't rub too bad except on the top of the tires
Same tires on the 6"? wide 14" Pacers
Tires rub BAD both on top, inside (a little) and outer fender lip
Bottom SAW adjuster broke off, car continually lowers itself.
Rear-
3 notches down
165R15 on smoothies rubbed on inside fenderwell at the top after a couple months of driving
No shocks
195/65R15 on the Pacers don't rub, but are REAL close on the inside (too tall for me)
Bottomed out stock shocks
Notched springplates with extensions made by me, modified Hobbes design.
Short axles _________________ (O\U|U/O) Top Vw (o\UU/o) |
Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Mon Aug 13, 2007 7:34 am Post subject: |
Front:
4" Hamburger Brad Signature Series Narrowed Beam
No shocks
CB dropped spindles
Stock 63 drum brakes
Nothing done to tie rods or headlight buckets
5.5 American Eagle 5-spokes
175/55/15 Continentals
Rear:
Springplates set at 4 deg (2 notches?)
No shocks (bounces all over but I'm deciding what kind to get)
Short axles
Springplates are not notched (It's on my to-do list)
195/60/15 Cheapos
_________________ www.DenverWildlifeControl.com
lowrange2 Samba Member
Posted: Mon Aug 13, 2007 11:14 am Post subject: |
Front:
CB Drop Soindles
2" narrowed Beam
2" Wider fiberglass fenders
Caster shims
245 45 17 on 17x8 Rims with some huge backspacing...
Air Cylinders on instead of shocks (Formerly Airkewlds air shocks)
Rear:
2500 LB Bag
No torsions
Crazy Notched Spring Plates
Airkewlds original bag bracket setup.
Short ass shocks...
If i put some tiny wheels on it like all you guys have it would sit flat on the ground... Sorry about these horrible pictures... The pic of just the pan is the best i had to show for the clearance I have.
Scrubs the fender a lil at full drop while turning. but other than that with a lil steering bump stop it scrubs nothing.
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Tue Aug 14, 2007 4:14 pm Post subject: |
Front:
4.5" Porsche Fuchs
145 Firestones
CB Drop Soindles
2" narrowed Beam
Caster shims
KYB Shocks
Tie rod flip kit
Rear:
Deep 6" Fuchs
205-65-15 Warrior
Adjustable Springplates
KYB Shocks |
Frankenbeetle Samba Member
Joined: August 08, 2003 Posts: 825 Location: The Great NW, Home of PBR and roses
Posted: Mon Aug 20, 2007 7:31 am Post subject: |
Edit; Placeholder for pics of my suspension
(sorry glandnut)
Edit #2; Caster shims. I've dropped my front about 5 inches, and only have one set up front. Should I be using 2 sets of shims and lowered ball joints and lowered shocks? _________________ Samba Whipping Boy of '07
Tram wrote: |
That explains it. Jihad supplies ain't cheap!
Last edited by Frankenbeetle on Mon Aug 20, 2007 7:59 am; edited 2 times in total |
attack chicken Samba Member
Posted: Mon Aug 20, 2007 10:55 am Post subject: |
Here is mine. I have a 6.5 in. beam, 2.5in. spindles, no shocks in front, 145's in front on factory wheels and 205/60's out back. All around drums. The beam is adjusted almost all the way up. Some rubbing on the inside top when turning but none on the fenders. Need some caster shims and I will be happy. It rides pretty smooth otherwise.
erok81 Samba Member
Posted: Thu Aug 23, 2007 7:06 pm Post subject: |
Here is mine.
Front
~6 inch narrowed front by me with stock bushings. SAW adjusters, only the top one is in, no shocks. Also no drop spindles...yet.
145/65R15 Continentals in the front with smashed buckets. They still rub.
Rear
2 splines down with stock shocks. It bottoms out all over the place, the tires rub the fenders on big bumps and have about 1/4 of room before they hit the suspension items. Also notched spring plates. 165R15 tires.
Needs drop spindles so I can get the front a bit lower. |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Fri Aug 24, 2007 12:32 am Post subject: |
Doesn't sound like your current set-up is working out so great. Maybe you could get some 175/55's up front instead because with future drop spindles and your current tires, you'll rub even worse. I hate to hear people pounding the backs of the headlight buckets, I just don't think it's really necessary most of time. Spindles will help center the front tires back in the wheel well and lessen or eliminate the headlight scrubs with 175's. _________________ Looking for aluminum single port Kadron manifolds. |
Slowlow Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Fri Aug 24, 2007 8:03 am Post subject: |
glandnut wrote: |
Doesn't sound like your current set-up is working out so great. Maybe you could get some 175/55's up front instead because with future drop spindles and your current tires, you'll rub even worse. I hate to hear people pounding the backs of the headlight buckets, I just don't think it's really necessary most of time. Spindles will help center the front tires back in the wheel well and lessen or eliminate the headlight scrubs with 175's. |
He isnt talking about 145/80 Nankang.. he has the NEW 145/65
which is smaller than a 135
The drop spindles will move his front wheels BACK in the fenderwell and reduce the amount of rubbage.
A car without spindles that is low, gets that volksrod look as the wheels go to the VERY front of the fenderwell.
a 175 55 WILL work, but its so wide that it will rub the inner fender like HELL with a 6" beam when turning _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
sled Samba Member
Posted: Fri Aug 24, 2007 8:37 am Post subject: |
sam is correct. (slowlow) _________________ drive your split. |
Posted: Fri Aug 24, 2007 2:36 pm Post subject: |
Update... Changed to stock wheels, so actually narrowed the front track by a HAIR
62 Beetle
Front -
4" narrowed adjustable beam, home built
NO shocks
CB drop spindles
135's on stock smoothies
Stock drum brakes
Rear -
Two outer splines
stock shocks
165's on Stock smoothies
Stock drum brakes
66vw2nv Samba Member
Joined: October 03, 2006 Posts: 74 Location: WICHITA,KS
Posted: Wed Sep 12, 2007 11:09 pm Post subject: |
front has air shocks with 125 temps and stock width beam
rear is solid on stock plate that need notched 3 outer spilnes i think may be 4?? 165 tires all on polishe 5 spokes...rear air to be continued Sorry shitty camera
_________________ PURE ENVY CAR CLUB MEMBER
TCB GARAGE WORKER
FLAT-WHITE 1966 VW BUG |
sled Samba Member
Posted: Thu Sep 13, 2007 5:32 pm Post subject: |
125 temps on a 5.5 is a terrible idea.
go with a 175/55/15 PLEASE before you hurt yourself or someone else. _________________ drive your split. |
Mine126 Samba Member
Posted: Tue Sep 18, 2007 8:47 pm Post subject: |
Awsome thread
Would love to see some life back in it! Working on my dream at the moment, but would love to see other pics of peeps playing in the dirt!
More names of places to get 4" narrowed beams be cool, but I think i have mine picked out.
Hope to have my ride up here soon. |
Posted: Fri Sep 21, 2007 11:58 pm Post subject: |
Ok sled was right 125 temps are very bad!!!! went back to 4.5 steelys and 135's on them. The 125 was short and worked when i only drove it 5 miles to and from work but on a 70 plus mile trip they melted and in a town of like 30 people i was up shi# creek with no spare tires in town. _________________ PURE ENVY CAR CLUB MEMBER
TCB GARAGE WORKER
