Spanish Flea Samba Member
Joined: November 20, 2006 Posts: 1244 Location: So. Flo.
Posted: Mon Aug 13, 2007 10:28 am Post subject: Wicked Shake |
Ok, i went to Daytona this past weekend. 600+ miles round trip.
On the way back, about 140 miles from home, the tread pealed from the tire and the flap punched the battery try about 5 inches higher.
I got a new tire installed, wallymart was nearby, but they couldn't balance the tire.
I got the bus rolling and all was good, untill i got home. Once i got off the freeway, i felt the shake. Starting off the line, the bus would shake violently. This will remain till i get to around 45mph then it calms down.
Now i know the first responce will be that the tire is not balanced.
But rolling at 1 to 5 mph, the tires unbalance would not be a factor here.
What should i check? What could be wrong?
Thanks,
Spanish Flea _________________ Miami Vdubs
Alte Schule
Rare Vintage Air
"Mr. Ford, i don't think what we are being offered here is worth a damn!" - Ernest Breech (On buying VW, March 1948) |
incynr8 Samba Member
Joined: September 23, 2003 Posts: 822 Location: Soylent Green is PEOPLE!
Posted: Mon Aug 13, 2007 11:01 am Post subject: |
check rim for damage
all the lugnuts torque
rear axle nuts torque
springplate bolts torque
check axle tube for being broken (rare but it happened to me)
check spring plate retainer cap bolts torque (another rare)
check for broken springs in all corners
you can balance the rear tire by putting it on the front. Jack up the front then and spin the tire, the heavy spot always settles low (use chalk on tire) then use small weights to balance tire until you can get the heavy spot stopping randomly instead of setting to the bottom.
FRONT: check wheel bearings and lugnuts, torques. _________________ ..........
Do it right, or don't bother. |
Posted: Tue Aug 14, 2007 10:19 am Post subject: |
Well last night i took a look at everything. Removed the tire and looked. All looked well. No skuf marks on the spring plate or shocks, all the bolts are tight.
It was to late for a drive, so if it's not raining when i get home i'll go for another short drive to see if the shake is still there.
Looked at the body damage, and it's not as bad as i thought.
Alte Schule
Rare Vintage Air
tkelley Samba Member
Joined: January 10, 2006 Posts: 1597 Location: Where Pterodactyls crash and burn...
Posted: Tue Aug 14, 2007 10:39 am Post subject: |
Time for new tires dude. Wide Whites
Put new tires on (you need them anyway) and get them all balanced out.
Whoever balances them can tell if your wheel is out of round.
PM me if you need anything else.
Good luck,
Tom _________________ When the sun doesn't rise, we'll replace it
with an H-bomb explosion or a painted jail cell... |
Posted: Tue Aug 14, 2007 10:41 am Post subject: |
Yeah, and try not to go muddin' this week.
r_sunada Samba Member
Joined: July 26, 2005 Posts: 233 Location: aiea, hawaii
Posted: Tue Aug 14, 2007 12:52 pm Post subject: |
Try checking the other tires if any of them have a "separation", like a bubble on the thread. that would cause a low speed vibration. Try rubbing with your hand on the thread of the tire see if you can feel any lumps. |
Stocknazi Samba Member
Posted: Tue Aug 14, 2007 4:55 pm Post subject: |
i agree, time for new tires if the other 3 are in the same condition as the one that detreaded. i have had that happen to me on 2 occasions. feels like the wheel is about to fall off. from now on i install new tires on any bus i plan to drive, for more than a few miles anyway. i would also suggest checking your other 3 tires for seperation. after one of mine seperated, 2 of the others showed signs of getting ready to do the same thing. be safe. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Wed Aug 15, 2007 10:49 am Post subject: |
I have new tires on the way as i write this. Thanks.
The funny thing is the Driver Rear tire had a nail in it before the trip. I didn't have time to fix it. Honesty i thought it was that tire that let loose. lol.
But yeah, this morning i ordered new tires. Cant wait to get them.
I went and had the new tire balanced. Now i can get to troubleshooting the shake. It was raining all evening yesterday, bummer.
Got Towers, and FF GTG this weekend
Alte Schule
Rare Vintage Air
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
LittleThunder Samba Member
Posted: Wed Aug 15, 2007 4:04 pm Post subject: shakes |
I had the same shakes on my POS chrysler and the tires looked fine to me, lots of tread but a tire guy pointed the bubbles out to me with the car up on the lift. They were barely noticeable but definitely there. No more than 1/8' bump. New tires cured it. |
Posted: Fri Aug 17, 2007 6:34 am Post subject: |
The other night, tom and i started to troubleshoot what was going on. We started by checking the other tires, and sure enough the driver rear tire had a huge bulge in it. Yesterday i got a used tire put on in it's place and that has taken care of the shake.
I took pix of the tire and will post them when i can.
Thanks everyone for helping out.
Alte Schule
Rare Vintage Air
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri Aug 17, 2007 8:13 am Post subject: |
Most steel belted tires can't be switched side to side. In otherwords, if they have been run on the passenger side and are rotating clockwise in the normal forward direction then are placed on the driver's side they rotate in a counter clockwise direction. The belts separate and bulge out air between the layers. Some newer radials are ok some are not. |
Clara Samba Member
Posted: Fri Aug 17, 2007 8:41 am Post subject: |
I thought I had a serious problem with my '65 westy. Turned out that when I got new tires that solved it. One of the old ones had a tumor towards the inside of the bus where I couldn't see it. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
