larrytrk Samba Member
Joined: July 22, 2007 Posts: 377 Location: Central NJ & MA
Posted: Thu Aug 16, 2007 5:12 am Post subject: Trouble raising my pop top |
Maybe I need Viagra to get it up, because my newly acquired 87 Westy' pop top is a BEAR to erect.
My 83, from a few years ago was not this difficult.
It has a new 3 window canvas and a Thule rack, could that extra weight account for the difficulty?
Are there any accessory struts, like on the "California", available.
Do I need to eat more spinach?
Do I need to take "AARNOLD", with me whenever I go camping?
Should I try to lube the runners in back, could they cause the problem?
The top lowers easily!!
Thanks. _________________ It's all in your mind.
I Hate BAMBI!
87 Westy full camper "Bluie" aka-"busturd"
JUST SOLD HER, WESTYLESS!
Good by cruel world! |
zippyslug31 Samba Member
Joined: July 20, 2007 Posts: 799 Location: Central Oregon
Posted: Thu Aug 16, 2007 9:27 am Post subject: |
Coupla thoughts....
the new canvas might be stiff? I know that the aftermarket material makes the top stiffer.
is your rack loaded? When I have my Yakima pod on the van, even empty it can be damn near dangerous to pop the top (read VERY HEAVY).
rusty spots at any of the pop top's pivot points? Maybe hose them in WD40 and see if it helps. _________________ previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor. |
Dark Alley Dan Samba Member
Joined: November 23, 2005 Posts: 185 Location: The Land of Wind and Ghosts (AKA Edmonton, AB)
Posted: Thu Aug 16, 2007 9:59 am Post subject: |
I've found that German dedication to thorough weatherproofing can be problematic.
If I attempt to raise the top with the doors and windows closed, as well as the tent windows zippered shut, the suction alone makes the lid feel like she's made of granite.
Could this be the issue?
Dan _________________ Dark Alley Dan
______________________
I blame rap music. For everything. |
Posted: Thu Aug 16, 2007 10:54 am Post subject: |
Dark Alley Dan wrote: |
Dan |
Thanks guys.
The racks are empty, awaiting unlock key from Thule to remove.
I hit all piviot points I could see with WD-40.
The sliding door was open to alleviate suction.
I will try to grease upper slides when I attempt to open again.
I guess I just turned into a wimp in my old age!!! _________________ It's all in your mind.
I Hate BAMBI!
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Thu Aug 16, 2007 1:08 pm Post subject: |
AFAIK, there are springs in the lower arms of the pop-top struts that are supposed to act as a counter-balance. I haven't heard too many complaints of this area, but there have been 1 or 2. I don't know if there is a fix even, so in other words - i don't think i've given you any useful information other than a possible explanation.
-Damon _________________ '84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go. |
msinabottle Samba Member
Posted: Fri Aug 17, 2007 12:05 am Post subject: One Suggestion... |
Find all your pivot points, and clean them, I'd suggest shots of brake cleaner if it doesn't get on the paint, or lighter fluid on a toothbrush, or Simple Green, which is probably the safest thing to use and will do a good job for you if you give it some time and a bit of scrubbing.
Then lube 'em with something heavier than WD-40, like 3 in 1, White Lithium, or the like. Gunk can really add to the friction, and the friction can do AMAZING things to the amount of effort any job requires.
amishman Samba Member
Joined: March 09, 2004 Posts: 3219 Location: California
Posted: Fri Aug 17, 2007 7:55 am Post subject: |
The rack is to blame in my opinion. My top was rather easy to lift when I had no rack and basket. I added a rack and basket and now it takes a olympic gold medalist to do a dead lift with red face style approach to get it up. I now push the top up part of the way by pushing the top rather than the bar and once it is up part of the way, I push up with a quick push and alternate my hands to the main bar and push like a mad man to get it up all the way and then locked in place. That works for me and my name is now Boris from russia and the dead lift king.
tj _________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com |
Posted: Fri Aug 17, 2007 8:41 am Post subject: |
amishman wrote: |
I now push the top up part of the way by pushing the top rather than the bar and once it is up part of the way, I push up with a quick push and alternate my hands to the main bar and push like a mad man to get it up all the way and then locked in place. |
Actually, that's a good point. When my pod is on top and fully loaded, about the only way I can get the top popped is by unlocking the top, putting my back/shoulders into the top, press it out with my legs while pushing the bar just to get it started. So, in other words it's fair game to carefully push the fiberglass up a short distance until the bar is easier to push toward the front of the van.
This is a mystery though. Doors not closed, nothing to speak of on top, hinge points seem clean? What the hell else could it be???
If you can relate to the following, then maybe this is your problem -
Could just be time to bulk up! _________________ previous:
'80 westy
current:
Surfalia Samba Member
Joined: December 25, 2006 Posts: 134 Location: Panama
Posted: Fri Aug 17, 2007 9:04 am Post subject: |
I have a yakima rack and it doesn't make it any harder to lift the top. Only when I have a few surfboards on the rack does lifting the top become tough. I have been thinking of trying to rig up a couple of the rear hatch assist shocks on my top but haven't yet. First I gotta get off the side of the road....no spark...no juice to the fuel pump |
tclark Samba Member
Posted: Fri Aug 17, 2007 10:40 am Post subject: Re: One Suggestion... |
msinabottle wrote: |
Best! |
2 words Fluid Film
http://www.eurekafluidfilm.com/ |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Fri Aug 17, 2007 11:48 am Post subject: |
Also you've got to consider where your rack and pod are mounted in relation to the hinge/pivot point of your pop-top. If you have your extra weight (the rack and pod + contents) mounted further away from the pivot point, in essence they are going to seem heavier.
Imagine swinging a baseball bat the normal way (weight out at end of bat). Now switch ends of the bat, so you're holding the barrel end in your hands, and the handle part of the bat is at the other end. Will semm much easier to swing, because you're not swinging the heavy end, it's in your hands!
If your weight is towards the front of your pop-top, you're lifting the heavy part. If your rack is towards the back, closer to the hinge, it should have less of an impact on the effort required to lift the top.
Not sure if that made sense, but I'm too tired to try again!! _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
fyrgrrl Samba Member
Joined: May 21, 2006 Posts: 396 Location: The Evergreen State
Posted: Fri Aug 17, 2007 12:31 pm Post subject: |
Uhhhh....I put a Thule box on top of my camper...and my dad and I can barely get the bad boy "popped".
MY GAWD!!! That was a killer but the real killer was when it was time to get it back down....I was ready to drive with the top up....we did get it down but we weren't feeling too good afterwards.
I have to admit my dad is 83 and I am a mere 130lbs and 5'6"....but I have no problem with the box off the top. So I have to go with, "It's the pod." And my rack is installed forward....about over the sliding door. _________________ 1987 Vanagon Westfalia (manual) - "Van Hildegaard"
1987 Vanagon Westfalia (auto)
1985 Vanagon GL 7-passenger van (auto) - "Blau Frau"
1985 Vanagon GL 7-passenger van (manual) - "Braunkuh"
1998 Subaru Legacy Outback (auto)
2003 Subaru Legacy L wagon (auto) |
