VW Computer Analysis System
ksbugger
ksbugger is offline
PostPosted: Sun Sep 30, 2007 8:20 pm    Post subject: VW Computer Analysis System Reply with quote
What information did the "VW Computer Analysis System" show? What type of equipment did VW dealers have to plug into the "test network socket" in the engine compartment. Are any of these still in existance?
Has anybody explored interfacing the "test network socket" with a modern computer....might be a fun project?
1979 Bug Convertible
Bookwus
Bookwus is offline
PostPosted: Sun Sep 30, 2007 11:40 pm    Post subject: Reply with quote
Hiya ksb,
The VW Diagnostic Computer System would spill out results in about 70 individual tests. The exact number would vary with the model of vehicle being tested. About half of these tests were actually visual inspections done by the technician and entered into the computer system.
The Computer System itself was actually a number of components housed in a frame. There were a couple of other units (wheel alignment and headlight adjust), but, in truth, when one thinks of the VW Diagnostic Computer System (Oh boy, let's plug it in and get a readout!) its the "framed" components one is thinking of.
I have most of that Computer System, although it is, by no means, complete. Check this....................
This is the heart of the system, the CPU. The blue panel in the front is the card reader. The tech would insert a plastic card (software) which would program the computer through the tests of a given model. Immediate test results would be read out in the digital display on the right. Most test results were of the go - no go variety.
Another Sambaite, Tron is considering playing around with the idea of hooking up a laptop to the diagnostic plug. You might want to contact him for details.
Mike
1970 AS Bug
1970 Bus - The Ruptured Duck
Have an AutoStick? Check out www.auto-stick.com
treeman
treeman is offline
PostPosted: Mon Oct 01, 2007 2:09 am    Post subject: Reply with quote
I've been around VWs for over 25 years now, and that is the first time I have ever seen a VW Diagnostic "Computer". Thanks, Bookwus.
Bradford
Peace, love, incense, light shows, all you groovy freaks-Dig It, Right On, and Power to the People!
In loving memory of Rory Miggins, local blues musician and tree planter. May he continue to plant acorns in heaven.
Rowroy
Rowroy is offline
PostPosted: Mon Oct 01, 2007 5:00 am    Post subject: Reply with quote
Bookwus wrote:
Hiya ksb,
This is a real piece of VW history. Where did you get that thing?
Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher
Scott H
Samba Luddite
Scott H is offline
PostPosted: Mon Oct 01, 2007 6:07 am    Post subject: Reply with quote
I have a few of the printouts where the diagnostics were done on my '72.
Here's one of them:
Scott
oc92 wrote:
I like the soul of an old car to be visible...
webwalker Premium Member
webwalker is offline
PostPosted: Mon Oct 01, 2007 6:27 am    Post subject: Reply with quote
I actually used the diagnostic plug this weekend.
I set up two switches, so I wouldn't have to keep going back up to the key: one is a momentary, the other is an on off toggle.
I hooked + to one side of each switch. The other side of the momentary goes to pin 30, the other side of the toggle goes to 13.
So when I need to start and run the car from in back, I switch on 13 (power to ignition) and then press the momentarily switch to power the starter.Zoom. And I'm sitting at the back by the engine the whole time.
M
"Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image
Bookwus
Bookwus is offline
PostPosted: Mon Oct 01, 2007 7:49 am    Post subject: Reply with quote
Hiya row,
I landed the computer shown and a bunch of ancillary parts from an e-Bay auction quite some time ago. My intention was to restore the system but, in truth, it has been languishing out in the shop for the past few years now.
Scott: Neat! Although I have the blank form, this is the first one I have seen that was actually printed out. Very cool!
Web: That is outta sight! As I understand it, remote starting was a function used in the original set-up. Too bad more folks didn't take the time to play around with their diagnostic plug before ripping it out. A built-in (so to speak) remote starter.
Mike
1970 AS Bug
BrockGrimes
BrockGrimes is offline
PostPosted: Mon Oct 01, 2007 8:03 am    Post subject: Reply with quote
A friend on mine used the remote start to start up his bug and had no key or setup in the car itself.
Like a security feature. Hop in it to steal it and there's no place to stick a key, LOL.
Update:
I hit my buddy up on yahoo, he said he has made a plug that he puts in the port. Then when he gets in he flips some switches and pushes a button to start it. Great anti-theft device!
Selling the SB:
http://www.thesamba.com/vw/classifieds/detail.php?id=557335
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Oct 01, 2007 10:03 am    Post subject: Reply with quote
Wow, that engine's oil temperature was running at 948 degrees Centigrade Shocked Wink That must be 94.8 degrees, which would be about 203°F
Thanks for posting the computer report, I've never seen one before either, and have always wanted to see what it looked like.
-Andy
DeathTrap
DeathTrap is offline
PostPosted: Mon Oct 01, 2007 12:25 pm    Post subject: Reply with quote
I'm not really trying to take it off topic
The readout, it says
ADJUST the BRAKES
it doesn't say retrofit discs, or bleed the brakes, it says adjust them.
GatorJZ
GatorJZ is offline
PostPosted: Mon Oct 01, 2007 12:59 pm    Post subject: Reply with quote
M
Very clever.
The Pirate
The Pirate is offline
PostPosted: Mon Oct 01, 2007 2:48 pm    Post subject: Reply with quote
What some one may want to do is try and build an emulation software that mimics the original Diag computer. The cool part would be that it could have different settings for different models , t4, t3, bus, ecet.
The biggest hurdle is that a modern computer or laptop would not be able to handle the currents generated by the Diag plug. One would need to construct an adapter that steps the voltages down and then translates the signal into lets say a USB plug. This could then be plugged into the computer running the emulator and it could then give a virtual print out.
74 super beetle AKA The Pirate.
We are currently offering a rebuild service for Beetle rack and pinion steering units. PM for details.
Service with a Yahhrrr.
Auto Van Buster
Auto Van Buster is offline
PostPosted: Wed Oct 26, 2016 11:24 pm    Post subject: Re: VW Computer Analysis System Reply with quote
Such a cool thread! Love the info on here. Did anyone ever make an attempt to write a software program?
