Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3455 Location: Talos IV, Piedmont Arizona
Posted: Tue Oct 16, 2007 3:05 pm Post subject: Disassembled / Reassembled the power rack |
I'm doing the rebuild of the westy rack. Here is stage 1
lotsa rubber rings and 3 seals. I am going to try to source the parts locally. $90 for a kit kinda takes the smarts out of doing it your self when a rebuilt is only $150 more.
More to come............. _________________ LEARN TO SELF RESCUE
....Bad Sneakers....
deprivation Samba Member
Joined: September 14, 2006 Posts: 1220 Location: Austin, Texas
Posted: Tue Oct 16, 2007 4:42 pm Post subject: |
Bill: At some point I'm going to have to do this as well. I've already got a torn boot.
Loosk good. Please post lotsa pictures because I have no idea what I'm doing!  _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
www.kittenfart.com |
Posted: Tue Oct 16, 2007 5:14 pm Post subject: |
this is my 3rd time over 10 years on this. Perhaps it will make the Stickeys. _________________ LEARN TO SELF RESCUE
....Bad Sneakers.... |
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Sun Oct 21, 2007 9:29 pm Post subject: |
Bill,
How's this project coming along? Who do you get the kit from? Kida lazy here, is there a good break down procedure in the Bentley, or do you just figure it out? Any special tools needed, or just the usuall extensive home VW set? how are the other one you rebuilt holding up?
Sorry for all the questions, but $90 is still cheaper than $250......and I've got two leaky racks. _________________ Imagine that, theres not an "h" in either Westfalia or Syncro? |
Posted: Mon Oct 22, 2007 4:23 am Post subject: |
sourced the parts locally, thanks Willy at ECI, $75 and last one left. Bentley doesn't cover it, I just took apart.
You need to make a tool to take it apart. Reassembly is easy, I took photos but the focus was off. I'll write it up when I get the time. Reassembly takes about 1.5 hours. _________________ LEARN TO SELF RESCUE
Posted: Thu Oct 25, 2007 3:50 pm Post subject: |
Here we go:
loosen the internal nuts to remove the seal housings.
Clean every thing and lay out the parts in order of removal.
If the center shaft is rusted, pitted or scored STOP, it's toast buy a new one.
this is the center point: C clip,spacer,spacer with bushing and rubber ring inserted inside,spacer then C clip.
The sleeve:
Bushing chamfer faces inside the sleeve then the seal, spring side facing you.
Sleeve to the shaft
install the plastic bushing then the rubber ring. leave the 4 point shim on when cleaning, no need to remove it.
Sleeve and shaft to the driver housing
Passenger side housing
Seal, spring side facing you, plastic bushing, metal spacer with chamfer facing you , plastic bushing.
Replace the 2 rubber rings on the outer housing, slide the outer housing onto the shaft assembly. Install the other 4 point shim, slide the pass side seal assembly onto the shaft and tighten the internal nuts
Done, attach the arms,boots and rods. plug and play.
That was fun  _________________ LEARN TO SELF RESCUE
Posted: Thu Oct 25, 2007 4:58 pm Post subject: |
Holy sh*t, bill - this is amazing. Fantastic! Thanks!!!!! _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Thu Oct 25, 2007 5:03 pm Post subject: |
For the love of the Samba gods, please make this a sticky!
One question Bill, can you post a pic of the "tool" you have/made to remove the "internal nuts"? _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10162 Location: Abiquiu, NM, USA
Posted: Thu Oct 25, 2007 6:46 pm Post subject: |
Stickilicious. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Please don't PM here, I will not reply. |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Wed Feb 18, 2009 7:16 pm Post subject: |
| Mighty Art how about a sticky for this one? |
dbo550 Samba Member
Joined: August 28, 2008 Posts: 365 Location: Kentucky
Posted: Thu Feb 19, 2009 8:21 pm Post subject: Re: Disassembled / Reassembled the power rack |
| Bill W wrote: |
More to come............. |
Where could I find a rebuilt for $150? Or something close to that. _________________ 1985 Westy
2001 Audi Allroad
1999 Volvo v70 xc
1995 Volvo T5-R, Yellow
1998 Jetta GLX |
dbo550 Samba Member
Posted: Thu Feb 19, 2009 10:31 pm Post subject: |
I will keep bumpin' til I get an answer. Don't make me get all poo on ya'. Surely somebody has replaced their rack on one of these things. _________________ 1985 Westy
2001 Audi Allroad
1999 Volvo v70 xc
1998 Jetta GLX |
eeebee Samba Member
Posted: Thu Aug 27, 2009 5:22 pm Post subject: |
| bump |
Posted: Thu Aug 27, 2009 5:55 pm Post subject: |
No $150 rack exists.Unless you build it. Stop bumping. _________________ LEARN TO SELF RESCUE
shorepig Samba Member
Joined: November 30, 2005 Posts: 516 Location: Vancouver, B.C.
Posted: Thu Aug 27, 2009 9:04 pm Post subject: |
| So, did u feel any difference in your steering after the rebuild? I'm trying to determine whether I need to rebuild mine. |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10133 Location: Where?
Posted: Thu Aug 27, 2009 11:04 pm Post subject: Re: Disassembled / Reassembled the power rack |
| dbo550 wrote: |
| Bill W wrote: |
| $90 for a kit kinda takes the smarts out of doing it your self when a rebuilt is only $150 more. |
Where could I find a rebuilt for $150? Or something close to that. |
What Bill says is the parts are $90 but you can get a rebuilt unit for $150 MORE for a total of $240. RockAuto has a wholesale closeout for $211. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
mrlimbo Samba Member
Joined: April 28, 2004 Posts: 289 Location: Adams, MA
Posted: Mon Jun 28, 2010 10:51 am Post subject: |
90 Dollars for a seal kit? Do you have a part number or a source for these? Mine's leaking.
I have a manual rack I'm thinking of installing, but I have to find the intermediate shaft for a manual rack. _________________ -Jim DiGennaro, Samba lurker, Disc Jockey and LiMBO freak www.LiMBObus.org
'67 Kombi- April, its not original and I don't care.
'87 Vanagon GL (daily driver)
'01 Jetta Honey's car
Looking for a Vanagon weekender or Escorial green camper. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7300 Location: Honolulu,Hawaii and France
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 769 Location: Lancaster PA
Posted: Tue Jun 19, 2012 5:35 pm Post subject: |
| Anyone have experience with the $30 Gates seal kit? GATES Part #348522 |
rogertj Samba Member
Joined: October 07, 2008 Posts: 522 Location: Tijuana, Baja California. Mexico
Posted: Mon Apr 08, 2013 8:24 am Post subject: |
Hello Bill!
Hey Thanks for the rack and pinion post. I need your help I encountered a problem with the aluminum housing pasenger side, when I tighten the internal nut slaming the thing with a small shisell (Well actually hiting it gently... ) and a hamer it does not tighten enough... the aluminum housing it is in its place but even when I have tighten it it keeps turning...
edit: Oh and by the way the internal nut is all the way inserted in to the aluminum housing !!!
thanks in advance for your speedy reply. _________________ Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
