Water Tank Key And Oil Filter
kevinlyndsy
kevinlyndsy is offline
PostPosted: Wed Oct 24, 2007 2:21 pm    Post subject: Water Tank Key And Oil Filter Reply with quote
Anyone know where to get a new water tank key I could not find it on the lots o links, also where do you get those replacement oil filters I have allways just used fram but here you guys talking about some other brand filter with a check valve in it.
Thanks
85 westy
meinvw
meinvw is offline
PostPosted: Wed Oct 24, 2007 2:22 pm    Post subject: Reply with quote
If you fnd a key let me know where as well!
I order my filters from bus depot, Mahle's.
The memories of a man in his old age, are the deeds of a man in his prime.
Quando Omni Flunkus Moritati !
73 High roof, 91 Carat, 87 Weekender, Mr magoo buggy, 88 LT 28, 98 R32,81 Diesel double door, 73 tin top, 72 HR.
kevinlyndsy
PostPosted: Wed Oct 24, 2007 2:27 pm    Post subject: thanks man Reply with quote
I think I will try a locksmith for the key thing I hate to bust it. I will check out bus depot for filters thansk again
PDXWesty
PDXWesty is offline
PostPosted: Wed Oct 24, 2007 2:56 pm    Post subject: Reply with quote
You should be able to get filters at a good german garage or parts house. I know they have them in Sac. Call around and ask for Mann or Mahle filters.
r39o
Samba Polizei
r39o is offline
PostPosted: Wed Oct 24, 2007 3:11 pm    Post subject: Reply with quote
RE: Water tank key
Oh heavy sigh. "Use the search, Luke." This sure has been discussed before. Please look at the Best Threads sticky. I know there is a thread about it.
Ditto the oil filters.....
[Preach mode = ON]
It conserves time, effort, bandwidth, etc to search before asking......
[Preach mode = OFF]
hiram6
hiram6 is offline
PostPosted: Wed Oct 24, 2007 3:29 pm    Post subject: Reply with quote
1) Go up to the sticky that is titled links to the best threads.
2) Scroll down until you find the one titled: Water Tank Key
3) There ya' go.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
Rhinoculips
Rhinoculips is offline
PostPosted: Wed Oct 24, 2007 5:21 pm    Post subject: Reply with quote
When did the fresh water tank key go from an actual cylinder lock and metal key to a plastic setup? 1986?
As I believe that all the plastic keyed tank locks are the same, I have two extra keys if anyone is hard up for one. Just PM me.
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
bucko
bucko is offline
PostPosted: Wed Oct 24, 2007 5:33 pm    Post subject: Reply with quote
The key became plastic when a previous owner replaced it with a water lock setup from GoWesty! This is the setup that is now available. Original was a lock and metal key setup.
I went to a locksmith as the sticky pointed out, but my local locksmith could not match it. I got lucky and bought one off of the classifieds here with it's key.
Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
Rhinoculips
PostPosted: Wed Oct 24, 2007 5:50 pm    Post subject: Reply with quote
Hmmmm....
Strange, very strange indeed. I'm pretty sure that this was never changed from stock, unless is was a dealer option of some sort and added before we purchased it. The vehicle has been in my family since new and I've owned it for most of its life.
Though, I have been wrong before.
Click to view image
Perales
Perales is offline
PostPosted: Wed Oct 24, 2007 6:07 pm    Post subject: Reply with quote
I think I'll bet you a doughnut on this one Bucko. My 87 had the plastic key setup and I am pretty sure it had nothing to do with GW. I don't know when they switched, or maybe it's a Canadian thing but at some point the plastic key setup became stock.
-- 1987 Westfalia automatic (Captain Vino)
msinabottle
msinabottle is offline
PostPosted: Wed Oct 24, 2007 6:15 pm    Post subject: Locksmith's... Reply with quote
Mine's metal and has the tumblers--and my local locksmith wasn't SURE he could duplicate the key, but he tried, and... it worked! So it's not a completely unfathomable lock.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
PDXWesty
PDXWesty is offline
PostPosted: Thu Oct 25, 2007 9:26 am    Post subject: Reply with quote
Rhinoculips - Can you post a close up picture of the key? I've never had one but would like to see if I could make one somehow.
My 89 is still stock and is a plastic set up. So was my 88.
Thanks!
bucko
bucko is offline
PostPosted: Thu Oct 25, 2007 10:08 am    Post subject: Reply with quote
I stand corrected. I had ordered a water fill hookup from GoWesty, and recieved the plastic key setup. The original I had was of the metal key and tumbler lock setup. I assumed that the GoWesty replacement was just that; a replacement for the original metal key/tumbler setup. I then found a water fill hookup with metal key and lock tumbler here on the Samba classifieds and bought it. It looks to be a better made setup then the plastic one.
Sorry about that call. Looks like VW went with the plastic setup sometime after 85-86.....
The mystery continues.
Rhinoculips
PostPosted: Thu Oct 25, 2007 11:15 am    Post subject: Reply with quote
Thanks!
Here you go. The dimensions(not including the large flat part on the left) - the round section is just shy of 3/8" long X 3/16" diameter. The flat part that turns the release is a 3/16" long X heavy 1/16" high X 1/16" thick
I have a total of 4 keys. Theres no need for me to have 3 backups. So I am more than happy to give 2 away F.O.C. One per person. It would be nice if these would go to people that have lost all water tank keys and not just someone looking for a back up. If you would like one, PM your address to me.
Click to view image
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Thu Oct 25, 2007 11:23 am    Post subject: Reply with quote
Thanks!
i'll get in line for one, i just broke mine, however i do have a spare so i would step aside if someone needs it more. hate using my spare cuz i'll end up breaking it at the wrong time Crying or Very sad
generous offer rhinoculips Wink
bucko
bucko is offline
PostPosted: Thu Oct 25, 2007 11:51 am    Post subject: Reply with quote
I have a couple of them as well that I'm not using. I'll be away for a couple of weeks, returning the 10th of November if you can wait that long for me to send out. If the other 2 get taken and there is a need for my 2, pmail me as well, and I'll dig them out.
Perales
Perales is offline
PostPosted: Thu Oct 25, 2007 1:41 pm    Post subject: Reply with quote
Thanks!
I did make one in brass as a gift for a Westy owner who had lost his (Banjojay67) and it workes fine. The lock is a bit of a tight fit so trial and error is necessary but it certainly can be done. Small files and a dremel tool are in order but certainly not brain surgery (or valve grinding).
21-window
21-window is offline
PostPosted: Tue Jan 25, 2011 1:47 pm    Post subject: Reply with quote
I need to wake this thread up I think. Anyone know where to get a key like this. My westy came without and I open it with a pick thingy now.
Thanks
Thanks!
Team WorldTour
Team WorldTour is offline
PostPosted: Tue Jan 25, 2011 3:06 pm    Post subject: Reply with quote
What is this 'watertank key' you all mention? My watertank has a brand new cap I bought here in Germany. Came with a metal key, too. And its a real lock and key, not this luggage key in the pic. I got it from this guy
http://server5.gs-shop.de/200/cgi-bin/shop.dll?SES...terID=4357
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Timwhy
Timwhy is offline
PostPosted: Tue Jan 25, 2011 4:41 pm    Post subject: Reply with quote
This one worked for me.
American lock company.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
