Barndoor heater tubes
Gerson
Gerson is offline
PostPosted: Wed Oct 24, 2007 8:30 am    Post subject: Barndoor heater tubes Reply with quote
this might sound like a dumb question but here it goes......does anyone know if there is a difference between early(BD), and later heater tubes front side diameter????...how about the forward and the rear chassis crossbrace hole diameter where the heater tube passes thru??????I have some clients that are telling me that the tube is too large, too small...etc...I have an NOS chassis crossbrace, and the diameter is 7cm........any help would be greatly appreciated.......
that's not patina, that's fucking rust man!!!!
we (klassicfab) make the funky green panels...........
52panelvan
52panelvan is offline
PostPosted: Wed Oct 24, 2007 10:59 am    Post subject: Reply with quote
Hi,
Rear is 3" (7.7mm)hole in cross member and front is 2.75" (7cm)in crossmember. These are taken from panels made by someone else that i believe to be correct. When i fitted these exact panels to the 52 and they seemed to tally with the original heater tube i refitted(undamaged and for the most part not rusty) which was tapered from one end to the other too.
I dont know if later Bd had the non tapered version as in post 55 vans.
I will take try and take some measurements from the original heater tube if it helps.
I would be interested in the year question too as it may be me who has the wrong panels.
Thanks for the panels
Cheers
Mark
euroduncan
euroduncan is offline
PostPosted: Thu Oct 25, 2007 4:18 am    Post subject: Reply with quote
The heater tube is tapered needing the dimensions you say. This is correct for 53,54. As I don't have an earlier bus I can't tell you about other years.
RockStock
RockStock is online now
PostPosted: Thu Oct 25, 2007 5:08 am    Post subject: Reply with quote
the feet on later heater tubes are angled, aren't they
feet on earlier buses go straight down?
-StockRocks-
52panelvan
PostPosted: Thu Oct 25, 2007 6:50 am    Post subject: Reply with quote
Not sure which parts you mean by "feet", Do you mean the 2 welded on clips that hold the front flexy pipe on?
When i assembled my van i could not figure how they would have assembled originally as with the two clips on the tube it will not go through the front centre chassis hole and the chassis section cant be slid on from the other end as the tube is too fat, so may be clips added after?
So 52-54 is tapered (possibly 8cm to 7cm across its length), im not sure my 51 has any left to check, some one will know im sure. I assume it was a slight attempt to increase the air speed in the cab as it comes out the vents?
Gerson
Gerson is offline
PostPosted: Thu Oct 25, 2007 6:56 am    Post subject: Reply with quote
so where do we stand with the measurements????the heater tube hole in my NOS rear chassis crossbrace is 7cm, I assume this is the same for all years...the front would then be 6.5cm for 1950, 51, 52...and different for 53, 54, 55 ?????? does this sound right????? Confused Confused Confused Confused Confused
Gerson
Gerson is offline
PostPosted: Thu Oct 25, 2007 7:11 am    Post subject: Reply with quote
here is a picture/measurement of the hole for the heater tube on my NOS rear chassis cross brace...does anyone have a picture of the front????different year fronts????
Gerson
Gerson is offline
PostPosted: Thu Oct 25, 2007 7:13 am    Post subject: Reply with quote
forgot the god damned link Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed
http://www.thesamba.com/vw/forum/album_page.php?pic_id=390447
52panelvan
PostPosted: Thu Oct 25, 2007 7:17 am    Post subject: Reply with quote
Not sure exactly where we are with the measurements if you have an Nos rear at 7cm, but is it possible the Nos one could be a later one?? I really dont know.
Im saying that rear is 77mm and front is 70mm hole and between Duncan and myself we have heater tubes in a 52, 53 and 54 that reflect this size.
My 80mm mention in my last post was just an assumption based on the fact the tube sticks out past the chassis cross centre.
A few more people need to measure up to be sure i guess with Og heater tubes.
The front hole and heater tube diameter is 70mm just to confirm.
Cheers
mark
RockStock
PostPosted: Thu Oct 25, 2007 8:23 am    Post subject: Reply with quote
sorry, i was missing the point - i was on about the the heater logs in the cargo area.
-StockRocks-
52panelvan
PostPosted: Sat Oct 27, 2007 5:00 am    Post subject: Reply with quote
Hi Gerson,
After looking at a picture of an nos bd rear cross member i have here, i think- and i could be wrong as i often can be but i think that rear cross member in your picture is not a Bd one. The hole size, cut out and a missing cut out point to it being possibly a later one.
On the picture i have the hole is defiantly around 1/2 cm either side nearer the edges.
Cheers
Mark
Gerson
Gerson is offline
PostPosted: Sat Oct 27, 2007 7:25 am    Post subject: Reply with quote
52panelvan, can you post a picture of it??thanks
Anchovy
Anchovy is offline
PostPosted: Sat Oct 27, 2007 12:15 pm    Post subject: Reply with quote
helping hand on the photo
Gerson
Gerson is offline
PostPosted: Sat Oct 27, 2007 1:11 pm    Post subject: Reply with quote
thanks a bunch Very Happy Very Happy Very Happy Very Happy
52panelvan
PostPosted: Sat Oct 27, 2007 2:45 pm    Post subject: Reply with quote
Hi Gerson, i have sent you a pm
Mark
Gerson
Gerson is offline
PostPosted: Sat Nov 17, 2007 12:40 pm    Post subject: Reply with quote
Mark, you guys are right on the heater tube/chassis crossbrace issue....I just went through my pile of cut up BD parts, and I found a rear and a front crossbrace with pieces of the og heater tube still attached, the rear is 7.7cm, and the front is 7.0cm Very Happy Very Happy Very Happy Very Happy , you are correct, the NOS rear chassis crossbrace that I have is a post BD piece....I am glad this issue is solved, the correct parts will be included in Chris's next shipment.....now, on to the next BD parts mistery Very Happy Very Happy Very Happy Very Happy ....I tell you, this never ends, learn soemthing new every day.....
52panelvan
PostPosted: Sat Nov 17, 2007 2:47 pm    Post subject: Reply with quote
Glad to of helped. The amount of changes 50-53, small differences in the frame and panels is amazing. May be there should be a thread just for these.
Cheers
Gerson
Gerson is offline
PostPosted: Sat Nov 17, 2007 3:04 pm    Post subject: Reply with quote
I agree Very Happy Very Happy Very Happy Very Happy
musclebus
musclebus is offline
PostPosted: Sat Nov 17, 2007 7:27 pm    Post subject: Reply with quote
Gerson wrote:
the correct parts will be included in Chris's next shipment.....learn something new every day.....
cool news Cool .....and correct Very Happy
if only we had access to one of the original vw factory workers (Marks getting there though Twisted Evil Cool )
www.musclebus.co.uk
Check out our last remaining Klassicfab panels in stock
barndoormambo
barndoormambo is offline
PostPosted: Fri Apr 01, 2011 6:56 am    Post subject: Reply with quote
..does anyone have a pic of the OG 70mm flexi hose?
- & , besides modern substitutes, does anyone know whre i can find one? Confused
....just cause you don't see it, doesn't mean it isn't there!....
