Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Sun Oct 28, 2007 8:37 pm Post subject: |
In context:
Ron Domeck wrote: |
At the rear is 2 2 stage external air cleaners. The engine lid is made up of Thing lid cut and flattin then the ribs from a late bus engine cover, front bus grill all welded and finished. Total of 9 pieces for the lid. |
Ron Domeck wrote: |
The dash has been cut out from the pinch weld down and has a one piece dash with Porsche 914 guages. |
Ron Domeck wrote: |
Forgot, the hood was made using a spare tire area from a Dodge Omni. |
Beautiful! Is that a T3 or T4 engine? I see many more things than you mentioned Turn brakes, odd hi-beam switch, odd turn signal switch... Is that a spare fuel tank switch under the dash?
Wow! _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
npconnor Samba Member
Joined: February 13, 2007 Posts: 194 Location: Central Texas
Posted: Sun Oct 28, 2007 10:06 pm Post subject: |
Now, I'm not familiar with turbo-charged engines... all my cars are naturally aspirated.. but is that a turbo in that thing? (2nd picture) _________________ '73 Thing
Austin Air-coolers Gang |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Oct 28, 2007 10:49 pm Post subject: |
Ian Epperson wrote: |
Wow! |
He said it's a 2.0L 914 engine. Thought you'd recognize those by now. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Video Bob Samba Member
Joined: November 03, 2005 Posts: 261 Location: Bishop, GA
Posted: Mon Oct 29, 2007 5:12 am Post subject: |
Nice job on the conversion. I believe Ferdinand would approve. :lol: _________________ Ya can't have too many Vdubs!
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22 |
Posted: Mon Oct 29, 2007 6:50 am Post subject: |
npconnor wrote: |
Now, I'm not familiar with turbo-charged engines... all my cars are naturally aspirated.. but is that a turbo in that thing? (2nd picture) |
Nope, that's naturally aspirated. The carbs are on the left and right - he's got an external air cleaner per carb, each sucking its own air from behind the car through the black tubes.
I think the blower in the engine compartment is for moving air over heat exchangers for providing cabin heat.
Towel Rail wrote: |
He said it's a 2.0L 914 engine. Thought you'd recognize those by now. |
My T4 looks significantly different. That pancake tin requires a lot of cutting to get it to fit in the compartment, but it certainly looks clean. I've not played with T3's at all - I suppose that oil filler and dip stick configuration gives it away as not being a T3. _________________ VW-181 shirts and stickers.
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Oct 29, 2007 9:39 am Post subject: |
The level under the dash is for the reserve valve from an old beetle, blower on the engine is for the heater from a bus, then the heat in sent up front thru the 2 in. square tubing that was used to lift the body. Steering column is from a early ghia so dimmer switch had to be used from early beetle. |
