BigDog Samba Member
Joined: April 12, 2006 Posts: 61 Location: On the Peninsula in Western Washington
Posted: Fri Nov 09, 2007 12:54 pm Post subject: No power after coasting |
I have an 85 1.9 with 4 speed. The engine runs great except for two problems which are probably related.
1. This thing has **no umph** starting from a stop. In fact, I often have to press the gas down and hold it for the engine to spin up before letting out the clutch. There are times when I have forgotten to do this, have pulled out into traffic and had to get to the side of the road to avoid being hit.
2. It will do the same thing after coasting down a hill. There is a hill several miles long that I take a couple of times a week. The engine will give no throttle response at all for perhaps 10 to 20 seconds after coming off that hill.
The engine never dies. It just has no power.
Any ideas? |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Fri Nov 09, 2007 1:09 pm Post subject: |
Check the timing. Connect a decent timing light and verify the distributors ability to advance it's timing to it's full advance up to about 3000 RPM. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
Dogpilot Samba Member
I would suspect your Throttle Switches are sticking in the closed position. The engine thinks it is at idle until they release. THe 85 has a low switch and a high switch, your offending one would be the low switch. Put a meter on it (it is on the throttle body) and see if its is gummy and releasing late. It really makes the engine into a gutless wonder when it is closed. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
morymob Samba Member
Posted: Sat Nov 10, 2007 6:40 am Post subject: |
make sure afm flapper not sticking also inspect wiper strip inside |
