Espinosa 8 Mile
Posted: Thu Jan 30, 2003 9:54 pm Post subject: CB Drop spindle question |
was just out trying to install my CB drop spindles on my 66 bug and was wondering if they require different wheel bearings.
i was putting on the drums and they wouldn't fit correctly.
i put the micrometer on the race and they are quite a bit larger than the stock spindles.
can anyone give me some input? it would be much appreciated. i had visions of actually being on the road in the next day or so.
thanks
scott |
Espinosa 8 Mile
Posted: Thu Jan 30, 2003 10:03 pm Post subject: CB Drop spindle question |
wanted to add, that i purchased the spindles off flea-bay and the owner said they were for ball joint, drum brakes.
is it possible that they are actually for disk?
what are my options if these are the wrong spindles? |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3116 Location: Keizer, OR
Posted: Thu Jan 30, 2003 10:25 pm Post subject: CB Drop spindle question |
hey scott, you will need late wheel bearings(outers i think) and also you will need late tierod ends. |
Espinosa 8 Mile
Posted: Fri Jan 31, 2003 8:17 am Post subject: CB Drop spindle question |
it is the inner wheel bearings that won't fit, will the late bearing still fit properly into the drums from my 66?
i got the correct tierods with the spindles.
thanks rizzag!! |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri Jan 31, 2003 8:42 am Post subject: CB Drop spindle question |
The BJ spindles they sent you must be later model.
66-68 1/2 (split year change) front spindles had smaller bearings and small shank tie rod ends.
You will need both inner and outer later model bearings and they fit the drums no problems, straight swap
As a side note, you can tell they don't fit, as the drums won't even go on... but when the opposite occurs ( peolple put late model drums/and or bearings on the skinnier early spindles, wierd things happen, like when the wheels are turned to the side and you try and take off it feels like the brake are dragging and or the front end is binding up... this has baffled alot of people! |
Espinosa 8 Mile
Posted: Fri Jan 31, 2003 8:55 am Post subject: CB Drop spindle question |
thanks keith.
suhhh-wheat
i thought i was going to have to buy another set of spindels and have two really funky heavy paper weights. guess i could have used them as boat anchors.
werd
scott |
Espinosa 8 Mile
Posted: Fri Jan 31, 2003 9:40 am Post subject: CB Drop spindle question |
jeff and keith!!!
thanks for the help!!!!
you guys have gone out of your way for me numerous times either with some content for www.lowlifeVW.com or here with tech info.
it is not going un-appreciated.
THANK YOU BOTH!!!
scott
www.lowlifeVW.com |
Posted: Fri Jan 31, 2003 10:05 am Post subject: CB Drop spindle question |
No problem Scott, LOL! I actually enjoy the abuse of trying to help peolple out online! And having your content scrutinzed and spit/shit on! :D
But after I re read your post I am confused as to which spindles you did get so,
I would say just check whatever bearings your gonna use for fit on the spindles by hand, both inner and outer before drifitng in and out the races ect and getting them all greased up and ready to go.
As I recall I helped someone out one time who ordered a "New" set of dropsie's and he got one of each! talk about a pain in the arse to get that sorted out! |
Espinosa 8 Mile
Posted: Fri Jan 31, 2003 10:19 am Post subject: CB Drop spindle question |
with a couple emails from rizzag and what was posted here, i think i am sure what is going on.
i ended up with 68 and later spindles. they take a different inner bearing.
it is all gonna work out and this thing will be on the road this weekend.
NARROWED AND DUMPED!!! mmmmmmmmmm
sorry if this is a crappy thread but it was kinda a learning experience for me and i am stoked that things are finally coming together. my car has been sitting for too long!!
scott |
rizzag Now Wut?
Posted: Fri Jan 31, 2003 10:27 am Post subject: CB Drop spindle question |
no problem, anytime scott. we better see some pics of this ride once its on the ground.
p.s. everybody if you havent yet go check out scott and thayers website www.lowlifeVW.com its really cool, plus they featured my bus for the car of the month and thats pretty darn cool in my book! |
Espinosa 8 Mile
Posted: Fri Jan 31, 2003 10:55 am Post subject: CB Drop spindle question |
even thought it is sitting narrow and low, where it is supposed to be, might i add. the thing is still a buk-it. nothing exciting to look at.
i decided that any pictures i take are going to be with thayers car. that way no one will even notice my roach sitting there.
scott |
Espinosa 8 Mile
