Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Thu Nov 29, 2007 4:00 pm Post subject: Gray running board material? |
Does Wolfsburg West or any other company make gray running board material? _________________ Justin |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Thu Nov 29, 2007 10:38 pm Post subject: |
I've only seen gray on e-bay once for an NOS set and I missed the ending. I need gray for my '65.
As a test I prepped a set of Brazilaian (cheap) running boards that have the harder rubber or vinyl mat (the $20.00 boards) and lightly primed / painted them with a flex ajent in the paint and put them on a parts chaser of mine two years ago and they've held up well including through a Chicago winter. I'd assume you could simply use a Gray spray on interior / vinyl top dye with a lot less hassle. I did the sunroof cover of my '63 seven years ago and it too has held up fine. _________________ Midwest Autosavers, Inc. Woodstock, IL |
Posted: Thu Nov 29, 2007 11:50 pm Post subject: |
I figure thats what I'll end up doing... _________________ Justin |
max-five Samba Member
Joined: October 18, 2006 Posts: 525 Location: Kenner, Louisiana
Posted: Thu Nov 29, 2007 11:54 pm Post subject: |
Critter, if you want to go the dye route, check out the SEM product line.
http://www.sem.ws/ _________________ '66 Beetle Convertible "Wilson"
'05 New Beetle Convertible "Ladybug"
'69 Deluxe Bus "Sunshine"
Want to buy your original German black '66 bug front seat upholstery...all or part |
