tsombrero1 Samba Member
Joined: June 13, 2006 Posts: 288 Location: Seattle, WA
Posted: Sun Dec 23, 2007 9:14 pm Post subject: Odyssey down, Optima in |
My Odyssey PC1200 is less than a year old and it won't take a charge. I ran it down a few times and I guess it was too much for the pup. I replaced with with an Optima Yellowtop, the much-hyped deep-cycle batt.
If you search the forums for Optima advice you'll find everything from "Yeah it fits in no problem!" to "I ain't cutting into my mf'in van for no mf'in battery" and "dude, I ruined it". So I gave it a whirl. Here's an actual pic that shows the notches you have to cut in the metal under the seat. Mind you this is freakin gute Deutsche Steel and it took me 30 minutes with a Dremel and a jigsaw.
If you have swivel seats you definitely have to install it on its side. I did not wanting to risk cutting off the posts and wrecking a $200 battery. I don't see any other way around cutting those two fugly notches. I painted over them to stave off rust.
There is room to use the side terminals but just barely. I had to insulate it from the batt compartment lid, and fabricate a hold-down.
Meanwhile the Odyssey is powering a small fan in the greenhouse
_________________ Tennessee Sombrero
1988 Westy, Syncro-nated
2003 Aprilia Caponord (now with Jif)
Atari 2600
1970 Earthbound Humanoid |
Rodknock Samba Member
Joined: April 06, 2006 Posts: 516 Location: Boulder CO
Posted: Mon Dec 24, 2007 6:30 am Post subject: |
It seems that running these type of batteries down is an expensive DOH!. Having just installed my Odyssy, I think a low battery alarm is the way to go. Just have to find one. |
Dogpilot Samba Member
Posted: Mon Dec 24, 2007 9:01 am Post subject: |
Actually, a a relay that would trigger at below 11.5 volts and cut off power. Problem is, something to handle the amps would eat power on its own. I was depressed when I realized I had killed my optima. Now I have voltage gauges everywhere. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
tencentlife Samba Member
