Jerry Samba Member
Posted: Wed Dec 26, 2007 6:46 pm Post subject: horn pics? |
I get the gist of the wiring routing (I think), for a '70 model horn. I was just wondering if any of you have any pics for the tab on the steering coupler. I think the negative side of the horn runs to a tab on the column itself, plastic-protected from the frame. The po of my westy evidently just got pissed off & jerked everything out, including the wire that runs through the center of the steering tube itself, & I can't see the tab on the coupler or the one on the inside of the tube. Also, I've now got 100 miles on my new engine, do I have to replace valve cover gaskets each & every time I adjust my valves? Thank you so much for your help. |
Jerry Samba Member
Posted: Thu Dec 27, 2007 5:32 pm Post subject: horn pics? |
Can anyone please tell me if there should be 12 volts of electricity on my steering column if wired properly? Seems that if the power goes through the horn, & attaches to the tab, there should be... right? Please reply, I know this subject is drivin into the ground, but my steering coulumn is apart & I feel like a dumbass. |
DubKru Samba Member
Posted: Thu Dec 27, 2007 5:36 pm Post subject: |
Valve covers are cheap. Don't be cheap.
As far as I know, the steering column is ground for the horn. There's a wiring diagram available online that shows all the wires. _________________ 2L, Raby cam, HAM Heads, Mallory, Dual Dell 40's, Porsche discs, Fuchs (Colored matched not to my bus),tunin' the crap out of it, slammed on Wagenswest suspension.
Polish Rifle wrote: |
I like to take care of my engine and find a nice speed to cruise in on my bus, but sometimes.....you just get in the mood to run the piece of crap into the ground. |
Rocknrod Samba Member
Joined: November 02, 2004 Posts: 2157 Location: North Carolina
Posted: Thu Dec 27, 2007 6:18 pm Post subject: |
No you don't have to replace your valve cover gaskets every time you pull them.
I use Permetex #2 gasketmaker on the valve cover side to stick them on, and wheel bearing grease on the head side.
After about the third time though, the cork is cooked/hard and you get to swap them out. I really, really wish that Felpro's reusable gaskets were worth something, but they stretch out and compress in weird ways on my small block chevy. Cork is cheap... and a perfectly clean install with good quality valve covers doesn't leak for a long time. Haven't tried them on the bus, maybe the rubber ones with steel core are better than rubber only. _________________ 1971 Westfalia with a high top.
http://71vwbus.blogspot.com/ - Pictures and words... Oh My! |
