dragonfire709 Samba Member
Joined: July 13, 2005 Posts: 154 Location: Hampshire, UK
Posted: Mon Dec 31, 2007 11:42 am Post subject: PS Hose (Updated) |
I have a tiny hole in the rubber ps hose that runs from the end of one of the metal pipes up to the top of the PS pump.
No problem, i think. Simply remove the hose and take it to the nearest hydraulics workshop. Only one problem. I cant get the damned thing un done at the connection to the metal pipe! I have soaked it in WD40 and 3 in 1 for days bu cannot get the damned thing to budge!!
Has anyone got any suggestions/hints/tips/morale boosters? I dont want to drive it with the leak as i dont want PS fluid spraying onto the engine.
Oh, and happy new year everyone! _________________ My name is Roy
Last edited by dragonfire709 on Tue Jan 01, 2008 10:23 am; edited 1 time in total |
kevinbassplayer Samba Member
Posted: Mon Dec 31, 2007 11:47 am Post subject: |
Hey Roy - You might have to hit it for several days with PB blaster, Wd-40, something along those lines. I've had this same problem with other "problem" fasteners, had to soak them over a few days |
ChesterKV Samba Member
Joined: February 07, 2005 Posts: 1725 Location: El Cerrito, CA
Posted: Mon Dec 31, 2007 11:48 am Post subject: |
Put a set of vice-grips or heavy-duty pliers on it where it connects over the metal nipple, and TWIST sideways.....it should move. If it does twist you can go ahead and pull while twisting a bit. It should work.
Photo ?
Good luck,
Chester _________________ 1984 Wolfsburg 7-passenger stock sunroof
1992 Subaru Legacy EJ22 boxer motor installed.... van is now sold.... currently playing with a 1987 Toyota MR2 with 1.6 liter twin-cam motor. Better than the Subaru boxers....... I'm impressed. Well, okay, in an "apples and oranges" kind of way. |
Terry Kay Banned
Posted: Mon Dec 31, 2007 11:58 am Post subject: |
IF you absolutly can't get the hose off--drive it to the hydraulic hose shop.
How?
Simple.
Slit a piece of heater hose, slip it over the hole, and clamp it down onto the PS hose where the pin hole is.
2-3 aircraft clamps will be good.
It'll slow the leak down enough to get you where your going, without making a mess of your engine compartment. _________________ T.K. |
Posted: Tue Jan 01, 2008 5:38 am Post subject: |
Hi Kevin-hope you are well. Ive been blasting it with WD40 for 10 days now. Thought it would have budged by now!
Heres a photo of the connector in question, Chester;
My new thought is that maybe its not supposed to undo?
Thats a good suggestion TK. I've already put another pipe loosely over the top of the leak(to stop it spraying directly onto the engine). If I clamp thet in place it should hold a bit of the fluid in.
Thanks for your help, guys. _________________ My name is Roy |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Tue Jan 01, 2008 9:00 am Post subject: |
Are you using flare-nut wrenches?
_________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
Posted: Tue Jan 01, 2008 10:23 am Post subject: PS Hose (Updated) |
Thanks for all your replies. I Have managed to get the damned thing undone now and hope to get to the hydraulics place tommorow.
I guess you were right, Kevin! _________________ My name is Roy |
Posted: Tue Jan 01, 2008 1:32 pm Post subject: Re: PS Hose (Updated) |
dragonfire709 wrote: |
I guess you were right, Kevin! |
Good news....and I was thinking of the low pressure return line.
- Chester _________________ 1984 Wolfsburg 7-passenger stock sunroof
