oilspot Samba Member
Joined: July 11, 2002 Posts: 909 Location: Southern NM
Posted: Tue Nov 27, 2007 2:36 pm Post subject: |
young5o wrote: |
Question for anyone who has used the Wagenwest horseshoes. Did you have a difficult time getting the wheel back on after installation? I have reset my springplate to 20* (factory spec per Bentley), installed the "shoes" and I have to fight to get the wheel to clear the wheel well. I had to take the air out of the tire so I could pound it in. I have stock 14" wheels with 195/75 tires. I really don't want to cut the wheel well, but will if I have to.
What are other options? Lower profle? Larger diameter wheel? Or?
If this has been covered before, I'm sorry. Could you please direct me to the correct thread. I looked throughout this one and did not see it addressed (although I may have missed it).
Thanks |
I've got a lowered split and have had to deal with this problem. You need to figure out a good way to jack the wheel down...
take a factory bug jack, do some creative welding/ fabrication and make a jack you can use between the springplate and frame or something of the sorts. I've heard of people using bottle jacks but I'd want whatever to be somewhat secure, I'd be kinda scared the I may catch a flying bottle jack in the chest or head. |
71weekender Samba Member
Joined: August 07, 2005 Posts: 187 Location: olympia wa
Posted: Tue Dec 11, 2007 9:08 pm Post subject: |
here's mine
here's mine
young5o Samba Member
Joined: July 03, 2006 Posts: 153 Location: Wine Country, Oregon
Posted: Thu Dec 13, 2007 9:46 am Post subject: |
71weekender wrote: |
here's mine |
Double post, but I didn't mind looking at it twice. Any difficulty stuffing the rear tires in? |
DLX-Fe Samba Member
Joined: October 27, 2005 Posts: 90 Location: West Linn OR
Posted: Thu Dec 13, 2007 1:00 pm Post subject: |
Your bus is nice 71 weekender! _________________ Doug
DLX-Fe |
Posted: Thu Dec 13, 2007 2:35 pm Post subject: |
young5o wrote: |
here's mine |
sorry about the double post didn't notice that until u said somthing......um do you mean when the tire is off is it hard to get it back in..if so yes it gets alittle tricky.... |
Posted: Thu Dec 13, 2007 3:57 pm Post subject: |
young5o wrote: |
here's mine |
do you have a hard time getting the back wheels to clear the fender lip when you go to put them on the bus? From the sounds of it, looks like I'm just going to have to live with the difficulty of getting the back wheels and tires on and get a 12v tire pump.... |
Posted: Thu Dec 13, 2007 4:04 pm Post subject: |
yep, I guess it just come with the game of lowridn. 8) 8) |
Posted: Thu Dec 13, 2007 6:37 pm Post subject: |
yep, I guess it just come with the game of lowridn. |
I hear you there!!! |
dgizzle2 Samba Member
Joined: February 03, 2005 Posts: 129 Location: kingsport,tennessee
Posted: Sun Dec 23, 2007 10:36 am Post subject: |
heres my cheap redneck lowering job
P.Stratton Samba Member
Joined: August 31, 2003 Posts: 115 Location: Street, MD
Posted: Sun Dec 23, 2007 4:09 pm Post subject: |
hey weekender........ What size and rating are those tires? Are far off of the ground are you? I am going with the 165/50's front and 185/50's out back this winter. I have already installed my 4" narrowed beam w/ drop spindels. Just working out the breaks,wheels and tires right know!
And for those of you qiuck on the key board ...... Yes it will ride like shit and yes I will have clearance issues and yes I will have under rated tires on it! It is a toy for me not a camper or daily driver.[img][/img] _________________ Always looking for a good opportunity !!!
'73 Bus
'67 Beetle |
shawn63deluxe Samba Member
Posted: Wed Dec 26, 2007 7:45 am Post subject: |
Hi, have read this thread with interest.
I have a splitbus with Creative engineering rear irs. It has their adjustable springplates with the rest being bay parts. I find the rear end has way too much negative camber with (equal) wear on the inside of both tyres. I have read all 17 pages and would like opinions on boomerang plates V horseshoes (I like the fact that they both do not add to wheeltrack as I have precious little room in there!) I also read on the first page or so that the top two bolt holes between the springplate and trailing arm can be spaced with washers/machined spacers. This latter method is obviously dirt cheap but wouldn't it be a bad idea as if you are pushing the top face away by fitting spacers then in theory wouldn't the bottom face not be sitting exactly flush (if you get my idea...)
Is it a simple case of you get what you pay for??!!!!
Cheers for any help,
Shawn. _________________ '63 RHD 13 window deluxe
2276 FI Turbocharged.
http://www.ssvc.org.uk/phpbb/viewtopic.php?t=6907 |
Posted: Sat Jan 05, 2008 8:15 pm Post subject: |
P.Stratton wrote: |
And for those of you qiuck on the key board ...... Yes it will ride like shit and yes I will have clearance issues and yes I will have under rated tires on it! It is a toy for me not a camper or daily driver.[img][/img] |
195/75/14 all the way around.. i don't know what rating they are but they are Mud and Snow. the bottom of my front bumper is 10inches of the ground. and the step is 5inches. I would like to change the front to a 185/75/14 |
NOK Banned
Posted: Sun Jan 06, 2008 10:20 am Post subject: |
I've read all of the threads on lowering Bays and flipped ball joints. Here's a picture of what I'm after. I wanna know if any one has tried to find a ball joint that press in through the back side. This set up doesn't look safe because the ball joint could pottenially pop out under pressure. But if you could find a ball joint with the retaining lip on the other end, we might be onto something.
I want drop spindles, but I don't want welded spindles. Just some thoughts. _________________ www.vwrepublic.com
Volkswagen Republic!
CogsWheel Hood Emblems
http://vwrepublic.com/forums/index.php?action=store;sa=view;id=11 |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Tue Jan 15, 2008 6:05 pm Post subject: |
lots of info in here, and i can only wade through so much. I am looking for information on beam adjusters for my bus. anyways, i was hoping to see if there was an option besides the toothed adjusters as i dont feel they are strong enough for me as i still use my bus as a work truck. I have seen the screw type for beetles, maybe they exist for bays as well? any suppliers or links would be much appreciated. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3076 Location: The Bull City
Posted: Tue Jan 15, 2008 8:58 pm Post subject: |
fusername wrote: |
lots of info in here, and i can only wade through so much. I am looking for information on beam adjusters for my bus. anyways, i was hoping to see if there was an option besides the toothed adjusters as i dont feel they are strong enough for me as i still use my bus as a work truck. I have seen the screw type for beetles, maybe they exist for bays as well? any suppliers or links would be much appreciated. |
http://cbperformance.com/catalog.asp?ProductID=1576 _________________
aeromech wrote: |
in my opinion you don't know shit |
Posted: Tue Jan 15, 2008 9:54 pm Post subject: |
cool to see. unfortantly that is similar to the beetle style which i have heard of having strip out under hard use. my bus wieghs a lot more up front than a beetle, but i wont push it THAT hard, but still its goign to see its fair share. what I really want is a set of these for a bay:
anyone sell them? _________________ [email protected]
NOK Banned
Posted: Wed Jan 16, 2008 2:40 pm Post subject: |
fusername wrote: |
anyone sell them? |
There are no bus adjusters in this style because of the Pitman arm box on the front of the bus beam. The single best adjusters to get are the ones mentioned earlier from CB Performance. They have larger teeth than any other adjuster I've seen and I doubt you would ever have a problem with them stripping out. Here's a picture.
Posted: Wed Jan 16, 2008 9:49 pm Post subject: |
looking closer, yeah those do look meatier, but 35 a pop? maybe ill just go for the ol cut and turn. quality beetle adjusters are like 30 a set! _________________ [email protected]
Posted: Wed Jan 16, 2008 10:54 pm Post subject: |
it's only thirtyfive little bucks....... |
