kayakwesty Samba Member
Joined: February 15, 2007 Posts: 687 Location: East Tennessee
Posted: Tue Jan 08, 2008 8:06 am Post subject: GoWesty vs Van-Cafe springs |
I'm looking at getting new springs for my 84 Westy
What is the difference other than price ?
GoWesty p/n# Part #2WD-SPRINGLIFT
Van-Cafe p/n#Part #: 2WDLiftSpring
I just installed Bilstein's HD stocks all the way around
This is a big commitment for me so any advice is appreicated Samba land _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
B.5.5 Passat Wagen with 30v V6-67000 Miles
DAS AUTO
CHANGE YOUR FUEL LINES!
A post without pictures is useless
http://www.kayakwesty.com
http://www.waldensridgewhitewater.com/ |
iceracer Samba Member
Joined: February 28, 2006 Posts: 949 Location: Milwaukee, Wisconsin
Posted: Tue Jan 08, 2008 8:25 am Post subject: |
Customer service at Vancafe is wonderful and no comment on Gowesty. _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
sharky805 Samba Member
Joined: December 12, 2007 Posts: 36 Location: ventura ca
Posted: Tue Jan 08, 2008 8:25 am Post subject: hello |
im about to put on some blistens as well,was it very hard ?did it make it better?should i put springs in also?i haVE 120,000 on my westy.i got the hd from go-westy |
Posted: Tue Jan 08, 2008 10:54 am Post subject: |
Before I begin, I want you guys to know that my opinion of this is NOT a reflection of my opinion about Van-Cafe or GoWesty, just the springs themselves.
The big difference in the two springs is quality. H&R makes a VERY good spring and has for many, many years.
H&R springs (what GoWesty sells) are cold wound, VanCafe's springs are hot wound. The difference is that hot winding is a cheaper method that results in inconsistant coil windings. Cold winding ensures that every coil is consistant in it's dimensions and coil spacing. Without this consistancy, the spring rates of the springs (how much load the spring can carry at any given weight) can vary widely from spring to spring as can the installed load height. Cold winding is much more expensive due to the machinery involved.
H&R springs are then tempered to increase it's "toughness" and making it more ductile while keeping it's strength. Not to say that VanCafe's springs do not got through this process, but they don't mention it. I know that some of the lower cost spring makers fall short in this area.
H&R springs are made from chrome-silicon (54SiCr6) spring steel which is about as good as you can get for coil spring construction. VanCafe only mentions "high quality steel". Using chrome-silicone spring steel allows the spring to be more consistant and allows the actual wire to be slightly thinner with the same strength.
Now here is the biggest difference between a quality spring and a cheaper spring. H&R uses what they call the “SuperBlok™” system which cycles the springs through a series of motions and calculated compressive measures to ansure that the spring will not loose any load height after being installed. In other words, the spring will not "sag". Cheaper springs do not invlove this process and therefore you WILL have some settling of the spring after they are installed.
When you combine the inconsistancy of a hot wound spring, questionable materials and heat treatments with the lack of pre-cycling, you have a recipe for a poor quality spring. Not to say that they can't be used with some success, but they are inferior to a quality spring, period.
_________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6244 Location: Portland OR
Posted: Tue Jan 08, 2008 11:07 am Post subject: |
Here's another recent post.
http://www.thesamba.com/vw/forum/viewtopic.php?t=272234
Syncro.org also sells 2wd lift springs.
http://syncro.org/springs.shtml
The ride height as reported by a Samba user for the GoWesty springs is 18.5". This may settle a bit. Syncro.org says their springs will give a final ride height of 17". You can read about their springs too. Genuine H&R springs seem like the best quality in my opinion but the ride height may be more than I'm looking for. |
allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Tue Jan 08, 2008 12:24 pm Post subject: |
If you go to go westy's site they have a side by side comparison of H&R springs VS the the cheaper ones. I would say the H&R would be the way to go after reading that article. They just seem like they will last longer and you will get a true lift with them. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
captainpartytime Samba Member
Joined: December 04, 2005 Posts: 715 Location: Mission Viejo, CA
Posted: Tue Jan 08, 2008 5:13 pm Post subject: |
Loogy, thank you for the very informative explanation. As a teacher and budding mechanic, I am always trying to read and learn as much as I possibly can about the engineering of an automobile (especially Vanagons). You explanations are very clear, lucid, and to the point. I just wanted to let you know that your input is very well recieved and appreciated. _________________ -Kerry
1982 turbo diesel Westfalia |
vwjedi Samba Member
Joined: November 29, 2005 Posts: 1463 Location: G-ville, FL - hopefully on a trail.
Posted: Tue Jan 08, 2008 5:41 pm Post subject: |
I put a H&R cupkit on my 96 Jetta and was lucky enough to have purchased my 2004 Passat with H&R lowering springs.
bottom line: THE BEST THERE IS!
you get what you pay for and they will be the last spring you purchase unless you keep your van another 20 years. _________________ 1987 Wolfsburg T25 still riding out. A bunch of other VW's passed on... |
Pascaa Samba Member
Joined: September 27, 2007 Posts: 72 Location: Quebec, Canada
Posted: Tue Jan 08, 2008 6:18 pm Post subject: |
iceracer wrote: |
Customer service at Vancafe is wonderful and no comment on Gowesty. |
This is not my experience (even if it seems i am part of the minority). I called Gowesty and the rep took all the time explaining and answering all my questions. Vancafe's rep seem to have something else to do that was more important. First time i called and i was not impressed.
Then, 2 days after putting my order at gowesty, i get a gowesty 10% off newsletter/coupon. I email explaining my luck and was given a equivalent credit on my next purchase. that to me is customer service.
Quote: |
you get what you pay for and they will be the last spring you purchase unless you keep your van another 20 years. |
Darn, i am going to buy those again? |
Pascaa Samba Member
Posted: Tue Jan 08, 2008 6:20 pm Post subject: |
oh i did buy gowesty HR spring with bilsteins... cant wait for them to get here... |
pete000 Samba Member
Posted: Tue Jan 08, 2008 8:00 pm Post subject: |
H & R springs are the best springs made. Eibach is also good, but they don't do Vanagon. _________________ 1990 Vanagon RS 2.1
1967 Deluxe 21 window
Koni Shocks
H & R Red Springs
Addco Sway Bars Front-Rear
18 X 7.5 and 18 X 8 OEM Porsche Wheels
Recaro Power-Heated seats |
Dogberry Samba Member
Joined: January 03, 2008 Posts: 210 Location: Northern Thailand and Central Oregon
Posted: Tue Jun 10, 2008 10:33 am Post subject: P-R-O-G-R-E-S-S-I-V-E |
I had the GW 2WD springs installed two weeks ago by local alignment shop. Remember vehicle WILL need re-alignment after install. And the shop can and did do the installation a lot more efficiently than I could.
My '91 Westy has over 200K. As well as we could determine my springs were the originals (great docs from 1st and only PO). They were TIRED.
The GoWesty springs are simply fabulous. I've been out trying to beat them in. I’ve put on only a few hundred miles so far, but no measurable "relaxing" as yet. The ride is great. Great. They’re firm and soft all at the same time. Read progressive. Alignment shop recommended a 1000 mile break-in then bring it back to tweak alignment. Don’t know what GW recommends but this seems reasonable to me.
I had done some pretty thorough measuring to make sure Westy would fit in my garage. GW states 1.5 lift over OEM but also includes caveat about original spring’s condition. Point is, with my original springs sag (especially drivers side lean) to new springs, the vehicle is around 3 inches higher. MY SKYLIGHT BRUSHES THE RUBBER WEATHER SEAL OF GARAGE DOOR! But it FITS. Ya-whoo! (I have GW’s 16” rims and newer Bilsteins as well so I’m sitting pretty, getting used to falling out of the driver’s seat to the ground WAY down there). _________________ 91 Westy |
TSR53 Samba Member
Posted: Tue Jun 10, 2008 3:54 pm Post subject: |
well I finally got my GoWesty springs installed and holy $%^&&* they are nice, soft when I need, and stiff enough to carry a load , the powder coat on them is tough as nails..I'm really happy with them
here is how they look
DAS AUTO
Posted: Tue Jun 10, 2008 4:06 pm Post subject: |
Kayakwesty,
What's the ride height? Center of wheel to edge of fender? What size tires are you running?
Thanks! |
Posted: Wed Jun 11, 2008 6:58 am Post subject: |
Man you ask some hard hitting questions
I have no idea on the center tire question, but Loggy’s ultimate tire thread might answer that
My ride height lifted the back up, but the front stayed about the same I had the high springs due to my 84 having the factory high springs.
As for the tire size, here is a webpage I made on it
http://www.kayakwesty.com/tireupgrade.html _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
DAS AUTO
Posted: Wed Jun 11, 2008 8:45 am Post subject: |
For ride height all you need to do is take a tape measure and measure it. Measure from the edge of the fender down to the center of the wheel. It should be somewhere around 18". Real simple!
Like this:
http://www.syncro.org/springs.shtml#2WDsprings |
Ryan Alfonso Samba Member
Joined: March 23, 2007 Posts: 101 Location: Half Moon Bay, CA
Posted: Wed Jun 11, 2008 1:47 pm Post subject: |
Experiment in progress: I have an older set of syncro.org springs that have left me underwhelmed. Lots of sag over the last 4/5 yrs. Front is basically down to stock levels and feels really soft..., leaving the ass end really proud. Moreover, it took a LOT of shimming on the left rear to account for the westy lean.
So, I just ordered a set of gowesty springs.
Once installed etc, it should give me a great comparison, having had both! |
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Thu Jun 12, 2008 5:59 am Post subject: |
I had GW 2WD springs installed (Fred's Garage in Redwood City did the install) on my 89 Westy and am very happy. If you keep your Westy loaded and ready to go - you may want to consider adding an additional spacer to the left rear spring to help alleviate the Westy Lean that comes from all of the kitchen equipment, closets + gear. _________________ 89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden |
Posted: Thu Jun 12, 2008 5:34 pm Post subject: |
Thanks for the tip. I'll take mine to Fred's too.
I just got the box in the mail. Kinda cool that they springs have their date of mfr on them, along with "front" or "rear", "2wd", and of course "gowesty".
My office mates are now certain I've lost my noodle. "buy a new car already!". They don't understand, but I actually have! One piece at a time, year by year... It's like George Washington's axe... |
