hlwimmer Samba Member
Joined: May 29, 2002 Posts: 533 Location: concord, calif.
Posted: Sat Feb 02, 2008 3:20 pm Post subject: |
:: stock suspension front and back.
:: ubiquitous nankang 165s all around.
:: inexpensive stock-ish slotted 4.5in mangel rims with the hubcap clips machined off and powdercoated "porsche silver"
:: porsche-B drums.
pix prior to porsche brake install
if i were to do it again, i'd get 5.5in rims of the same design so i could run a wider tire. the front also needs to be lowered a bit, but that's a later project. |
paulsvwbug Samba Member
Posted: Sat Feb 02, 2008 3:33 pm Post subject: brm's |
NeedAName wrote: |
Front: 4 inch narrowed adjustable with towers 2.5 inch dropped spindles 145's
Rear: One outer notch 165 15
I was thinking of painting my 61 ragtop the same color as yours, already have the brm's. I'm running 145's up front and 165's in back but my only problem is I got the AC Industries disc brake kit up front and the center caps to the brm's won't sit flush and so they fall off, mainly on drivers side due to the speedo cable. Any ideas? |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Wed Feb 06, 2008 10:14 am Post subject: |
Front:
3.5 narrowed beam
2.5 CB spindles
Avis style adjusters
Stock brakes
Stock wheels with stainless trim rings
135/80-15 Space saver tires (just to get it rolling, i'm NOT driving on these!)
Rear:
1 outer click
Stock brakes
205/65-15 tires
No engine or trans so its not the final ride heigth.
Can go down 2 more "clicks" on the adjusters.
Switching to CB 5x130 disc on front, Gas Burners, and 145-15 front - 205/70-15 rear, i'll post pics along the way. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
bugdozer Samba Member
Posted: Wed Feb 06, 2008 8:20 pm Post subject: |
thanks for stickying it. |
Rude-e Samba Member
Posted: Fri Feb 08, 2008 1:08 pm Post subject: |
1966
Front:
2" CB Ball Joint Beam .... no other mods
Stock wheels w/ 165's
Rear:
Stock height
Stock wheels w/165's
I have very little space left, maybe an 1/8 of an inch between
the inner fender and the shocktower.
I don't understand how people are installing up to a 4" beam without
modifications. |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
rezidu Samba Member
Joined: November 08, 2004 Posts: 197 Location: Fayetteville NC
Posted: Wed Feb 13, 2008 9:20 am Post subject: |
great sticky...
Front:
-5 KCW beam
no shocks
2.5 CB drop spindles
135s on 5.5 5 spokes
Rear:
Down 2 outer splines
notched spring plates
165s
radmonster Samba Member
Posted: Fri Feb 15, 2008 6:48 pm Post subject: |
front 4" narrowed beam avis adjusters drop spindles no shocks 135s
rear 2 clicks 145s
estofer Samba Member
Joined: November 25, 2004 Posts: 867 Location: Lawrence, Kansas
Posted: Fri Feb 15, 2008 8:00 pm Post subject: |
Here is my 66 with 4.5" BRMS 145's in the front and 5.5 BRMS and 205's in the rear!
_________________ 1964 Type 1 Vert "Ruby"
2019 Tiguan
2020 Tiguan |
dubaroo Samba Member
Posted: Mon Feb 18, 2008 5:45 am Post subject: |
145/65 up front with an adjustable beam
205/70 out back lowered 2 splines or there abouts.
next on the list is narowed beam and dropped spindles |
migsrag Samba Member
Joined: September 05, 2006 Posts: 13 Location: Hercules Ca
Posted: Wed Mar 05, 2008 12:04 am Post subject: |
Front, 4 in Narrowed adjustable with CB drop spindles wide 5 disc brks
Flat 4 Sprints with 195-55-15 Falkens
Rear, Lowered one outer spline, rear wide 5 disc brks
205-60-15
_________________ Mike
1963 Sunroof, Pearl White |
sloans265 Samba Member
Posted: Wed Mar 05, 2008 4:11 pm Post subject: |
FRONT
4" beam with Airkeld dropped spindles
145's on stock smoothie
REAR
6 inner splines down and 5 outer splines back up to get it where I wanted. The typical 2 outer would have been just a bit too low for me.
165's on stock _________________ 1970 Lotus White Panel
In search of any Pensacola Fla dealership items |
Kuncle I am Kyle Deese
Joined: June 08, 2005 Posts: 1284 Location: Greer...South Carolina...
Posted: Fri Mar 07, 2008 10:29 am Post subject: |
If your low and you dont like your Nankang 135s. GO Continental 145/65s I thought it would be ok.. But they are awesome tires that are cheaper, lower, and a better brand than nankang.. Thumbs up _________________ Ost Kuste. |
phatdawg Samba Member
Joined: November 16, 2004 Posts: 189 Location: Eureka CA
Posted: Fri Mar 07, 2008 12:05 pm Post subject: |
KingNut wrote: |
If your low and you dont like your Nankang 135s. GO Continental 145/65s I thought it would be ok.. But they are awesome tires that are cheaper, lower, and a better brand than nankang.. Thumbs up |
Let us decide. Where are your pics? _________________ -1966 T1 2-tone W/1915 cc
-1965 T1 Project car. Have had for 25 years.
-2000 Jetta VR6. Black and Quick! (GONE)
-2010 Jetta TDI. White and sips fuel.
The older I get the beter I was!!
http://www.thebugshop.org/gotech.htm
http://www.wolfsburgwest.com/ |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1184 Location: Dallas, GA
Posted: Fri Mar 07, 2008 3:39 pm Post subject: |
KingNut wrote: |
Be warned that the diameter of the 145/65 tires is 2 inches shorter than your standard 135 or 145 tires!!!!
This is good if you have a really hammered VW... but I ran into a problem with the 145/65s being too short for me.. I personally need that extra inch between my beam and the ground. Made the difference between my slamming my adjuster in to the ground or pushing rocks down the street... Plus I like the way the standard 145s fill the wheel well... I do rub my headlight bucket a little though which the 145/65s didn't do
Anyone want to buy a set of slightly used brand new 145/65s that only had one trip around the block? |
Posted: Fri Mar 07, 2008 4:24 pm Post subject: |
Vee Dub Nut wrote: |
KingNut wrote: |
Well keep your personal opinion to yourself because 145/65s are only 1 inch shorter which means .5 ride height difference and if your worried about dragging an adjuster of why lower it?
Ill post pictures up asap - Kyle _________________ Ost Kuste. |
Posted: Fri Mar 07, 2008 9:03 pm Post subject: |
KingNut wrote: |
KingNut wrote: |
Personal opinion huh... How about looking up the specs on the tires:
Conti 145/65... overall diameter: 22.4"
http://www.tirerack.com/tires/Spec.jsp?make=Contin...3D465TR5EC
Nankang 145's... overall diameter: 24.3"
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6650
Ok.. so its 1.9" difference, and yes I've confirmed the specs by measuring the two tires side by side
I'm not saying anything bad about the tires, so don't get your feelings all hurt..Nor am I trying to discount your previous post. All I'm trying to do is just put info out there so someone may not buy a set of tires they don't really need or can't use... I never said they were bad tires. They are great for cars in the right circumstances...
It's not one tire fits all...
FWIW... the 145/65s are quite a bit cheaper.. just didn't work out for me
KingNut wrote: |
and if your worried about dragging an adjuster of why lower it? |
So its not lowered unless your beating the front suspension in the ground?
I couldn't get the car in the garage without hitting the adjuster on the driveway, and its not even steep.. I just want more than 1/2" of clearance so I can drive over the 3/4" bump to get into my garage...
CASON Samba Member
Joined: April 13, 2007 Posts: 293 Location: jacksonville fl
Posted: Sat Mar 08, 2008 10:54 am Post subject: |
front : 4.5" homemade narrowed w/ adjusters,no shocks,2.5" narrowed tie rods 145 65's continentals -soon to be added dropped spindles...
rear: 2 clicks on outer spline 165 85's khumo- soon extended plates
[img]
Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Sat Mar 08, 2008 9:33 pm Post subject: |
Anyone running a 4, 5 or 6 inch narrowed beam with 165's in the front???? |
ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Sun Mar 09, 2008 7:54 pm Post subject: |
Lee. wrote: |
6 1/4" narrowed, 165/45R15s. _________________ (O\U|U/O) Top Vw (o\UU/o) |
