volkswagen60 Samba Member
Posted: Mon Feb 04, 2008 12:19 pm Post subject: Oil breather hose sludge |
It looks like I have off-white sludge coming out of the oil breather hose coming off the filler...
What's the deal? _________________ http://www.vw-trader.com |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Mon Feb 04, 2008 12:31 pm Post subject: |
It's from condensation.. .that it for a long drive and get it up to operating temp so the water is boiled off. _________________ Glenn
Member #1009
#BlueSquare |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Mon Feb 04, 2008 1:26 pm Post subject: |
Yep,It's from short drives,Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
74 Thing Samba Member
Posted: Mon Feb 04, 2008 3:56 pm Post subject: |
Change your oil a little more often in the winter or go for a long ride to get it up to operating temp and burn it off. |
Lag_Smurf Samba Member
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Mon Feb 04, 2008 4:43 pm Post subject: |
Lag_Smurf wrote: |
I have the same thing in my motor. cleaned some of it out today. did an oil change too. I drive about 100 miles a day. So long drives dont help. |
What kind of oil? Some are more prone to this condition... _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
nsracing Samba Member
Posted: Mon Feb 04, 2008 8:29 pm Post subject: |
YEap. Put the thermostat back in!
That is the only way you will get that condensation off.
All cooling systems that do NOT have any thermostatic controls will have this foaming problem. This includes the DTM.
It is not just cooling that you need to have. Correct temperature control for the motor is what you want. In this, the STOCK VW cooling set up with intact thermostat is very hard to beat. Summer or Winter...perfect everytime.
A good serpentine system like the one John (ACN) sells and a stock configuration cooling is very good for higher end power VWs. |
