CJG Samba Member
Joined: November 07, 2005 Posts: 571 Location: Phoenix
Posted: Thu Jan 31, 2008 9:14 pm Post subject: |
sorry that is not a strait cut gear noise, I have seen it done before with the fan. that is the fan making that noise, please  |
kekonaiii Samba Member
Posted: Thu Jan 31, 2008 9:18 pm Post subject: |
That is correct that is something we use to do in Hawaii back in the 80's |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Fri Feb 01, 2008 10:06 am Post subject: |
Eaallred wrote: |
Just remember: If you install some straight cut gears strictly for the sound, you lose all privelages of making fun of the ricers.
Nothing sounds more badder-ass than a 1776 with a set of Kadrons, a stinger, and a set of straight cuts.  |
Shoot, muffler aside, that's my combo right there... In all honesty, while I do like the sound of my Magnums, I also bought mine with the anticipation of future upgrades... |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1662 Location: Marshallville Ohio
Posted: Fri Feb 01, 2008 3:27 pm Post subject: |
That video doesn't sound like straight cut's to me. More like fan rubbing fanshroud noise. |
70VWkid Samba Member
Posted: Sat Feb 02, 2008 9:18 am Post subject: |
finally some people who are actually for them! |
Posted: Sat Feb 02, 2008 9:48 am Post subject: |
I like to use straight cut gears in stock motors. When I rebuild peoples stock motors I put Counter weighted cranks and straight cut gears and Double Thrust Cam Bearings. In my own opinion I feel this makes for a better stock motor, things that cause less wear...
For high performance do what you want to do. I would always put the straight cut in unless told not to by the customer.. |
jamestwo Samba Member
Posted: Sat Feb 02, 2008 10:05 am Post subject: |
It takes HP to make noise....energy is not free and noise is energy. _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17589 Location: Left coast, Canada
Posted: Sat Feb 02, 2008 2:29 pm Post subject: |
jamestwo wrote: |
It takes HP to make noise....energy is not free and noise is energy. |
So you are saying straight cut gears rob hp? _________________
millerje78 Samba Amishman
Joined: October 16, 2005 Posts: 2445 Location: Holmes County, Ohio
Posted: Sat Feb 02, 2008 3:11 pm Post subject: |
Glenn wrote: |
Eaallred wrote: |
I generally can't hear any sounds that are behind my car, so run whatever you like
Seriously... run what you like. The only you you need to please is yourself. |
Herr Ring does not need such things to improve the sound of his engine.
_________________ always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry |
Posted: Sat Feb 02, 2008 7:23 pm Post subject: |
not sure, just what i was thinking. what is greater loss, the noise or the friction of the side load on helical gears?
I'm in favor of them by the way, I just make them quiet.
How? offset cam bearings.one more secret out the bag for you, must be .5 hp there.
Bruce wrote: |
jamestwo wrote: |
So you are saying straight cut gears rob hp? |
shegel Samba Member
Joined: November 03, 2006 Posts: 378 Location: Kennewick, WA
Posted: Fri Feb 15, 2008 2:28 pm Post subject: |
just because i hear people talking about them everyonce and a while. what exactly is the benefit to running strait cut cam gears. just so you can run heavier valve springs? im kindof confused _________________ My stuff with engines
1969 Karmann Ghia
1999 Jetta tdi
1977 Honda gl1000
1993 Honda xr250L |
Arnolds64 Samba Member
Posted: Fri Feb 15, 2008 3:07 pm Post subject: Straight Cuts |
Put them in my street 2017. I did however buy the less noisy CB's. I really can't hear them that much from the drivers seat. Whe you rebuild why not improve it? If it gives me a few extra ponies and will let the valve train rev easier for not a bunch of money then why not. I looked at it this way. I did not go with light lifters so taking friction away may equal it out. My little stroker really revs well and it needs some tuning yet. the sound is more of a whining at idle and that is about it. I really don't notice much on my however just a hint. So if noise is loss of HP then the CB's must be the best?
I mean lets face it. With a merged Header and a big Dynomax hanging out back you can't tell much of a difference from one noisy thing to the other. If you want quiet you are into the wrong cars. Go to a Lexus forum or something. _________________ 64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels. |
