wanta23 Samba Member
Joined: March 31, 2007 Posts: 534 Location: At The Beach
Posted: Wed Feb 27, 2008 10:17 am Post subject: Fuel gauge sending unit |
| How do I know if my sending unit is good? My gauge only reads 3/4 when it's full and goes to empty with about a half a tank. My gauge needle also bounces around quite a bit. I've already checked the gauge ground and it's OK |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12565 Location: Over 2002 posts deleted!
Posted: Wed Feb 27, 2008 10:55 am Post subject: |
It's prolly dirty and/or corroded. The extremely fine wires inside it get that way after some 40+ years and only give a signal where clean. You can clean them up being very careful so as not to break them, or you can just replace the sending unit for a new one. Good luck!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Wed Feb 27, 2008 12:42 pm Post subject: |
| pyrOman wrote: |
It's prolly dirty and/or corroded. The extremely fine wires inside it get that way after some 40+ years and only give a signal where clean. You can clean them up being very careful so as not to break them, or you can just replace the sending unit for a new one. Good luck!  |
Since a new sender is only $31 at busdepot, if I'm pulling the engine and tank to work on the sender, I'm putting in a new one. Be sure to release the float on the new one or you'll be pulling it out again! |
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3082 Location: The PNW, where "going green" means rolling with moss.
Posted: Wed Feb 27, 2008 3:52 pm Post subject: |
| dstefun wrote: |
| pyrOman wrote: |
Dave, what do you mean by releasing the float? _________________
| cdennisg wrote: |
| Lawyers don't deserve buses. |
| zozo wrote: |
| Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Wed Feb 27, 2008 4:22 pm Post subject: |
sorry to but in it is a pin that is stickered to hold the float for shipping...how do i know? wellllllllll. luckily i was still able to pull it out without removing the engine or tank. 271-919-051b for $28 at wcm for a VDO of brazil.  _________________ once you realize im not impressed we will get along just fine |
zozo Samba Member
Joined: October 15, 2005 Posts: 5216 Location: South of Ol' San Antonio
Posted: Wed Feb 27, 2008 5:04 pm Post subject: |
| 420GOAT wrote: |
| luckily i was still able to pull it out without removing the engine or tank. |
The pin or the sending unit? |
Posted: Wed Feb 27, 2008 5:38 pm Post subject: |
| zozo wrote: |
| 420GOAT wrote: |
I'm assuming the pin. If I could get the whole unit out, yes I'd just replace it. But pulling the motor and tank might be a bit beyond for me, I'm still reading up on valve adjustments  |
pyrOman Fire Master
Posted: Wed Feb 27, 2008 7:08 pm Post subject: |
| wanta23 wrote: |
Then follow this procedure: Carry with you a gallon jug of gas. Fill up the tank, note the odometer reading down. Drive the bus to work, around town, etc., the way that you'd normally drive. Drive it all the way until it runs out of gas. Note the odometer reading down at this point. Figure out how many actual miles your bus will go on a full tank of gas. Pour the gallon of gas into it and go fill up the tank. Note the odometer reading now and every time you fill up. This way you'll know when to fill up BEFORE running out of gas.
Though my gauge "reads" okay, I still always carry a gallon and also note the odometer reading at every fill up.  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Old Skool Daddy Samba Member
Posted: Wed Feb 27, 2008 7:56 pm Post subject: |
Mine reads 3/4 too, but when I throw the headlights on, it reads full. Zany Splits.  _________________ 64 Standard
Sell my bus? Would Han Solo sell the Millenium Falcon? |
winmotors Samba Member
Joined: November 20, 2005 Posts: 99 Location: Monterey Park
Posted: Wed Feb 27, 2008 11:23 pm Post subject: |
I have the exact problem with my gauge....I usually just fill up when my needle gets to 1/4.
My questions is .... do you have to remove the tank to replace the sending unit?
Thanks |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
joe cool Samba Member
Joined: August 20, 2006 Posts: 1262 Location: Yolo County CA
Posted: Wed Feb 27, 2008 11:47 pm Post subject: |
| I replaced the sending unit and swapped gauges but my fuel gauge still only reads accurately between 1/4 and 3/4. Above and below that it can't be trusted. |
pyrOman Fire Master
Posted: Thu Feb 28, 2008 7:12 am Post subject: |
| joe cool wrote: |
Refer to my previous post!
The Dormy has a custom made 17.5 gallon aluminum tank and uses a bug sender. Also, not having any baffles causes the sender and thus the gauge needle to bounce quite a bit. Though I do keep track of how many miles since the last fill up, I know I HAVE TO get gas real soon when the needle stops bouncing!!!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
Vintage Split Samba Member
Joined: September 10, 2002 Posts: 222 Location: Southern California
Posted: Mon Jan 05, 2009 6:09 pm Post subject: |
Is there a way to test the sending unit outside of the bus? For that matter it is outside of the tank. I took it apart yesterday. Verified the tiny wire is in place and lightly cleaned the contact points on the float. As best I could, I verified continuity through the wire and terminal (old shoddy tester - I'm bringing another home tonight). It seems pretty simple.
Am I correct in thinking, "If the wire is in place, and the float goes up and down, and all the connections are clean it should work." Otherwise, any other tips?
1967 bus. Thanks,
Mike _________________ --Mike--
0-60...eventually. |
Clara  Samba Member
Posted: Mon Jan 05, 2009 6:20 pm Post subject: |
| Vintage Split wrote: |
1967 bus. Thanks,
Mike |
I've tested a sender outside a bus with a battery, a fuel guage and a bucket of water.
You can take the tube off the sender by uncrimping the 'washer' and undoing the nut at the end. You can polish up the wire and contact places with fine (1000 grit) sandpaper to restore the connections. That's what I did to the sender in my kombi, that was previously in a bus with a cruddy tank. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Mon Jan 05, 2009 6:28 pm Post subject: |
| Clara wrote: |
The internals look good so I'll test it like you suggested next.
Thanks,
Daddybus Samba Member
I've got a Baywindow tank (15 gallons) and sender (expensive little B) and a 6v bus gauge (12-90 ohms I believe). I had a 12v bus gauge before and they read the same...R means I have 3 gallons in the tank and a full tank reads almost full on the gauge. I will try a GM 0-90 ohm gauge next to see how it reads.
I also keep a mileage log as a back up. |
Posted: Mon Jan 05, 2009 10:43 pm Post subject: |
| Clara wrote: |
Thanks,
Mike |
Hmmm, so I did the test and all that it verified is my gauge works. Basically went to full once I connected the battery regardless of the float level. I double checked the wiring diagram. Ground to sender, sender to gauge, gauge to + on battery. Correct? Am I missing something, or this is an ok test? _________________ --Mike--
Clara  Samba Member
Posted: Mon Jan 05, 2009 10:48 pm Post subject: |
| Clara wrote: |
Thanks,
Mike |
Hmmm, so I did the test and all that it verified is my gauge works. Basically went to full once I connected the battery regardless of the float level. I double checked the wiring diagram. Ground to sender, sender to gauge, gauge to + on battery. Correct? Am I missing something, or this is an ok test? |
did you ground the guage? you know how the guage grounds where the U clamp hits the underside of the dash? ... clip a ground wire to one of the studs the U bracket goes on, and see if that works. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Mon Jan 05, 2009 11:05 pm Post subject: |
| Clara wrote: |
| Clara wrote: |
Thanks,
Mike |
did you ground the guage? you know how the guage grounds where the U clamp hits the underside of the dash? ... clip a ground wire to one of the studs the U bracket goes on, and see if that works. |
Doh! That worked Clara. I was working inside my wife's Toyota (available battery) and didn't ground the gauge like you said. Now I can put the tank back in... one step closer.
Thanks.
