52panelvan Samba Member
Posted: Fri Mar 07, 2008 11:53 am Post subject: Pre 48 Round Jacking points |
Hi,
I have has a good search and not found alot about them.
Im guessing they are tricky to obtain.
Does anyone know if they are they are available as reproductions and or what sort of money would you expect to pay for a pair of original vw ones?
Thanks for any help
Mark |
splitpartsunlimited Samba Member
Joined: January 18, 2006 Posts: 1302 Location: Good Ol`Buenos Aires, Argentina
Posted: Sat Mar 08, 2008 3:21 pm Post subject: |
just measure it from an existing 48 and buy same specs pipe ....installation of the part should be no rocket science if you also take a few pics of the og part ...
if you don`t want to get back to your house with dirty clothes , take a big mirror with you .... _________________ in my Garage:
1951 crotch cooler split
1958 convertible
1971 1302 convertible
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring |
Posted: Sat Mar 08, 2008 4:28 pm Post subject: |
i will take my mirror
Ok so i guess you are saying later ones can be modified with pipe to make earlier ones? Is the flat section that sits on the pan/ sill the same pressings as later ones?
Mark |
Posted: Sat Mar 08, 2008 5:45 pm Post subject: |
i guess so , but correct me if i am wrong , please _________________ in my Garage:
1958 convertible
billmetric Samba Member
Joined: March 16, 2006 Posts: 1062 Location: Columbus City USA
Posted: Sat Mar 08, 2008 9:58 pm Post subject: |
heres a photo of one, I'm guessing they are quite impossible to find, making one from scratch would be difficult but if you start with an early square one ( up to late 50s ) it shouldn't be that hard to make
_________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
47bug Samba Member
Posted: Sun Mar 09, 2008 7:45 am Post subject: |
Good luck with the replacement round hole jack.And if you happen to find an extra jack for one of these, let me know. Guy |
Posted: Mon Mar 10, 2008 4:27 pm Post subject: |
Thank you for your help.
Dont want to labour a point as there is not much more to know than you have written here on round jacking points other than the pair i have dont have the flat reinforcing bar at the bottom but look completely factory (as per billmetric's picture) with no obvious modifications or grinding? Also Dont appear to have been removed from the pan as factory spots are still there -odd.
Anyway thanks again
Mark |
erioco Samba Member
Joined: February 05, 2004 Posts: 382 Location: St. Louis, MO
Posted: Tue Mar 11, 2008 5:16 pm Post subject: Round jack points |
Mark, what year is your round jack point car? From some pix it is hard to see if there is a bar below, but then again I wasn't looking for that , my 47 has the bar below.
Eric
Mark,
found info via pix In the book Volkswagen Beetle: "The rise from the ashes" by Simon Parkinson
He has some good pix of very early REME cars,and bare chassis, ie 45-46 era showing no vertical flat bar underneath, so my guess is that the 'round only' were very early and they found that they were not stable, and added the bar below later. Either that or some were with and others without due to material probs, both are reasonable given the times. I would hang on to them, if not I might buy them.
Pix in question are on pp 63 of his book includes a bare chassis with jack point clearly visible and a pic of a sedan tipped on its side with the bottom of the jacking point visible but you need to look carefully. Also several pix of the Radclyffe Roadster (pp106) with just the round jack point, and that was built in 46, and I think that several pix of the first three Heb prototypes also show what could be a round jacking point (but harder to see). This might be a reason that the prototype cars for the Heb and the Karmann are referred to as early (read old) cars being used for prototype models. Many have thought that the round versus square was the point in question, but it might be the round alone versus round with bar was in question, which wiould make sense of the statements since the square didn't come in until late 48 or mid 49? and the statements were made while the round style was still being used, in production but with a vertical reinforcing bar beneath.
Eric
You have to realize that the jacking point was new during the war. The pix of most of the Kubels show scissor jacks. I am guessing that the jack point came in around 44, when the 40 liter gas tank came in and was built into the kubel at the same time. So it was about a year later that military production stopped and then a several month hiatus in "Production" (versus assembling some vehicles from parts available) so they didnt have much chance to reinforce this potential weak spot with the bar beneath. Don't forget that it took the plant 4 or 5 years to get rid of the round jacking points for a square one that didn't roll off the jack so easily.
One last point, given that damaged vehicles were taken back and refurbished, a "later" car could have very early characteristics, depending on what was damaged and what could be salvaged. So a "47 " may have a salvaged 45 or 46 chassis underneath, or at least parts from an earlier chassis, like jacking points.
Eric
beetlekey Samba Member
Posted: Tue Mar 18, 2008 1:38 pm Post subject: I have made a set of 6 repro jacked |
I had the same problem and made 6 peaces for some poor guys like me
I will post a pic next days. The price is 50 Euros each + shipping.
Best regards from germany
Marcus |
Posted: Wed Mar 19, 2008 6:27 am Post subject: |
Thanks very much for the information Gents - i think Erioco has the reason they have no bar then, i had only found a few pics of them all with the bar.
Im very sorry to say i dont have the whole car just some metal parts from it, i got for something else but wont be needing the jack points.
I will recheck the conditon first as i would trade(rather than sell) them if they are usefull to someone as i have no immediate use for them and I can only live in hope that i would have one day needed them for a very early beetle restoration.
Thanks again
Mark |
Genrich Samba Member
Posted: Fri Mar 21, 2008 7:25 pm Post subject: Round |
Here is a photo of my June of 48 round jack point.
From the chassis number I figure 200 VW's later they went to square!
Erich, Wendy and future 48 driver baby Karsten
_________________ 5 out of 4 people have problems with fractions. |
VW1948 Samba Member
Posted: Sat Mar 22, 2008 4:45 am Post subject: Re: Round |
Genrich wrote: |
I have a 48 that I am restoring, so it would be very interresting to know from which chassinumber VW went to square |
Posted: Sat Mar 22, 2008 6:28 am Post subject: There must be a little modification in 47 |
[img]https://www.thesamba.com/vw/classifieds/pix/1994995.jpg
the metalplate under the holder. IN 46 they have nothing like that.
[/img]http://www.kaeferschluessel.de |
Posted: Sat Mar 22, 2008 6:29 am Post subject: |
erioco Samba Member
Posted: Sat Mar 22, 2008 7:20 am Post subject: |
Genrich, what is the vin number when the jack point was changed to square?
I have been looking all over for info on the round jack points and there is hardly anything on them in the progressive changes, and nothing on changes within the round without bar and round with bar underneath.
Eric _________________ Radclyffe Roadster Replica proj based on an April 47 chassis |
Posted: Sat Mar 22, 2008 1:27 pm Post subject: |
Eric,
I checked my J.T. Garwood book and the first square jack point came on chassis number 1-0079649. This replaced the old round "Vigot" jack.
Erich Kircher _________________ 5 out of 4 people have problems with fractions. |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1478 Location: Finland
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
RichOakley Samba Member
Joined: August 30, 2004 Posts: 1115 Location: Midlands, UK
Posted: Sun Jul 14, 2013 2:05 pm Post subject: |
Outer diameter is 34mm |
