captainpartytime Samba Member
Joined: December 04, 2005 Posts: 715 Location: Mission Viejo, CA
Posted: Sat Mar 29, 2008 7:51 pm Post subject: Fabricating Air Filter Hose to Snorkle - Pics |
I need help either tracking down or fabricating an oval-to-round air intake hose that goes from my air intake top (oval) to my air intake snorkel (round).
The oval air intake top is 3 1/2" x 2"
and it connects to a 2 1/2" round snorkel.
Any suggestions? The hose itself will only be about a foot in length at the most. _________________ -Kerry
1982 turbo diesel Westfalia |
reiney Samba Member
Joined: November 02, 2006 Posts: 120 Location: Santa Fe, NM
Posted: Sun Mar 30, 2008 12:58 am Post subject: |
Hmmm. Might try looking in Home Depot, etc. at those rubber connectors they have in the plumbing section. I just used them on my intercooler to make a 2-1/2 to 3 inch transition. Maybe you could soften the plastic on the oval and turn it into a 3" round? |
dokarex Samba Member
Joined: January 13, 2007 Posts: 251 Location: SHELBURNE NS
Posted: Sun Mar 30, 2008 6:19 am Post subject: |
you can get them from a dealer if you have to (I lost mine also)
I cant remember what the cost was but it was in their computer, but I believe it has to come from Brazil?
I did a search with the part # and I think it only showed results from Russia (can't rember part#) _________________ 1987 Doka 1.9TD from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2006 Jetta Wagen 1.9TDI
B6200 Kubota Diesel
16ft Freestyle catamaran
16 ft Sunray 85 Horse (sunk) |
Posted: Sun Mar 30, 2008 8:15 am Post subject: |
I'm kind of tired this morning so forgive me if my thinking is way off base.
Wouldn't you need a 2.75" ID tube to fit over the oval inlet? Flexable tubing of some sort to conform to the oval shape? That would leave a .25" difference at the snorkle outlet, yes? You could wrap the snorkle outlet with one wrap of .125" (1/8") rubber sheet to make up the difference. The rubber could be glued to the outlet or maybe you could use .125" plastic sheet and countersunk bevel headed pop rivets to hold it in place. Maybe? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sun Mar 30, 2008 12:50 pm Post subject: |
Thanks guys. I'll head over to Home Depot today. I thought there might be other VW's that use this configuration but I will try the ad-hoc method once again! I guess I have to start getting used to this if I'm going to hang on to the '82 diesel. _________________ -Kerry
Dogpilot Samba Member
Posted: Sun Mar 30, 2008 5:06 pm Post subject: |
Kerry,
You can also use aircraft SCAT tubing. IF you go to the FBO part at Orange County airport one of the FBO's may sell you a short piece, normally it comes in 3' sections cut to fit. It is a flexible rubberized tubing that is held rigid with a wire spiral inside. You snip out a bit of the wire on the end and it is very flexible so it will conform to any shape. We use it on air induction system on piston aircraft.
http://www.chiefaircraft.com/airsec/Aircraft/Hardware/AeroductScat.html _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
johntyberg Samba Member
Joined: March 28, 2008 Posts: 13 Location: Long Beach, CA
Posted: Sun Mar 30, 2008 11:33 pm Post subject: |
I need that part, too. Right now it's been held together by a substantial amount of duct tape. Keep us posted on what you end up doing.
It looks like it's either 068 129 967 (elbow F 24-C-200 000) or 068 129 967A (elbow F 24-D-000 001) if you want to order it.
They're both listed when you search busdepot, but they're not cheap.
Good to see another diesel vanagon person close by. |
allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Mon Mar 31, 2008 12:05 am Post subject: |
get something with the wire spiral in it. I used regular rubber tubing looks kind of like radiator hose. and that crap collapsed under the load of the engine. I was shocked but the guy at napa said its not rated for that kind of use. I wouldnt think it would pull enough air to do that though. Maybe something is not right on mine though. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
Posted: Mon Mar 31, 2008 8:29 pm Post subject: |
Loogy wrote: |
Wouldn't you need a 2.75" ID tube to fit over the oval inlet? Flexable tubing of some sort to conform to the oval shape? That would leave a .25" difference at the snorkle outlet, yes? |
Chris, you definitely didn't sleep through math class.
I used a little calculus today to figure out the circumference of the ellipse (oval) and came up with 8.95". From there I assumed that the circumference of the oval, if stretched into a circle, would be the same as the circumference of a circle and calc'd the diameter of the circle to be around 2.85"
I will try some 2 3/4" ID tubing (since I don't think they make 2 55/64") and see if I can't heat it up to get it to form into an oval. _________________ -Kerry
stineb Samba Member
Posted: Wed Apr 02, 2008 8:21 am Post subject: |
Go to your plumbing store and get a super thick rubber connector from the pvc pipe section, then use hose clamps and make up the difference with black pvc pipe.
I investigate all of this when I was going to try to make a new air snorkel set up. It should work pretty well. |
snoop Samba Member
Posted: Sun Apr 10, 2011 9:18 am Post subject: |
Looked like the best thread for this...
Been finding what looked like barbequed ruffle potato chips in the air box for the last several filter changes. Turns out they're pieces of the inner laminated paper from the snorkle tube. Took it out yesterday...wow, serious flow restriction in that sucker.
Went to Lowe's, got a section of 3"x8' flex aluminum duct, part#328922 ($9.46), deformed it into an oval and fitted the other snorkle parts onto it.
Then wrapped the whole kit'nkaboodle in duct tape
and reinstalled.
Very happy with the result. Hope this can help others who are finding snacks in their airbox! _________________ 87 Westy Camper |
vanjoe Samba Member
Joined: December 25, 2009 Posts: 606 Location: Santa Maria
Posted: Sun Apr 10, 2011 10:28 am Post subject: |
Beautiful, Thanks for the info on this. I just checked mine and it is all tweaked. It looks like a Home Depot visit today . _________________ 1990 VW Vanagon tin top weekender Carat
1998 Mercedes S420
"Why is there never time to do it right the first time, but there is always time to do it twice?"
"Back to the basics!" |
BrickFan Samba Member
Joined: September 12, 2007 Posts: 114 Location: Alaska
Posted: Sun Apr 10, 2011 11:44 am Post subject: |
I am also looking for this special hose. johntyberg, do you know which of those part numbers you listed is the hose or what the difference is between the numbers? _________________ '86 syncro
'82 westy diesel 1.6 n/a |
akyrie Samba Member
Joined: March 24, 2010 Posts: 519 Location: Driftless, Wisco
Posted: Sun Apr 10, 2011 1:34 pm Post subject: |
I have a 1.6 diesel out of a rabbit so my air intake manifold is slightly different. I am trying to connect the manifold to the snorkel, has anyone have any experience doing this?
You can get an idea bellow
[/img] |
akyrie Samba Member
Posted: Sun Apr 10, 2011 5:18 pm Post subject: |
Funny course of events. While I was in the engine compartment, I notice that I had previously failed to fully attach the hosing coming from the AFM away from the filter box. The hose was partially attached but not completely. I am wondering if this might effect back pressure in the pistons possibly exacerbating my normal oil leaks?
Also, would driving down the freeway with gas leaking from the tank cause a nasty film buildup on my rear windshield, besides it inherent explosive disadvantages? |
akyrie Samba Member
Posted: Mon Apr 11, 2011 7:59 am Post subject: |
any takers? Do I need to describe the situation better? Thanks,
A. |
brad131a4 Samba Member
Posted: Tue Apr 12, 2011 8:28 pm Post subject: |
Check out samco silicon hoses. They have sizes that reduce from 3" to 2 1/2 or 2 3/4. They will also conform to the oval and round easily.
There are a few other silicon hose manufactures that are less expensive just can't remember off the top of my head. |
vanjoe Samba Member
Posted: Fri Apr 29, 2011 9:25 pm Post subject: |
Went to Home Depot today to finally get a replacement hose for the air intake snorkel. I didn't want to spend $10 for the aluminum hose so in the roofing department I found a flexable downspout for $2.39. I got 2 and pieced them together. Here are the pics. I already put it all in and if fit nice and snug. Should last as long as the original I hope.
1998 Mercedes S420
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Sat Apr 30, 2011 9:41 am Post subject: |
Look at the air duct and how smooth it is compared to the bellows of the water ducting that you bought. Air likes smooth, otherwise it creates turbulence and slows the airflow. |
GrindGarage Samba Member
Joined: October 14, 2008 Posts: 710 Location: Ocean City, NJ
Posted: Sat Apr 30, 2011 10:57 am Post subject: |
akyrie wrote: |
Taste it. I had same thing happening and it was coolant _________________ -cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com |
