mrafindley Samba Member
Joined: December 29, 2007 Posts: 642 Location: miami Florida
Posted: Sat Apr 19, 2008 7:31 pm Post subject: Help with Vacuume lines |
Ok I can see where all the vacuume lines go except for the egr valve any help on this? I searched the gallery to page 92 and got tired of looking
_________________ 73 THING
67 Beetle
http://w2.wolfsburgii.com/downloads.htm |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Sun Apr 20, 2008 6:52 am Post subject: |
To the front of the valve should be a vacumn port at the base of the carb. The hose will only be about 5 in. long |
Posted: Sun Apr 20, 2008 7:30 am Post subject: |
The only ports I see are the one on the intake that goes to the breather. The one on the leftside of the carb in the middle that goes to the advance. And the one behind the egr in the middle of the carb at the rear I see no where for the egr to plug into It dont really matter when I had the intake off cleaning all the carbon out of the heat risers i welded the hole shut anyways but I still want it to look like it is still working. No inspections here _________________ 73 THING
67 Beetle
germansupplyscott Samba Member
Posted: Sun Apr 20, 2008 10:25 am Post subject: |
there should be a nipple on the carb base pointing up at an angle, this is for the EGR. if the nipple is missing you have the wrong carb. there are many variations of the 34-pict 3. _________________ SL |
Posted: Sun Apr 20, 2008 4:05 pm Post subject: |
i think the distributor is right. _________________ SL |
Posted: Sun Apr 20, 2008 7:52 pm Post subject: |
Thats not my motor I just purchased a distributor that is dual advance. Mine has a 009 in it right now but ups should bring one to me tomorrow so hopefully no more flat spot. and a nice clean idle if not the dizzy goes to gleen for help and carb will go to kiefernet for help. I am getting tired of driving with 3 feet once the engine gets warm. _________________ 73 THING
67 Beetle
